Re: POC VERSION TWO: Is RDY really...er...Ready?
Posted: Mon May 21, 2018 7:10 pm
BillO wrote:
to have one board at 16mHz, one at 14mHz, one at 10mHz one at 4mHz and one at about 2 mHz.
* W65C816S PROOF OF CONCEPT SINGLE-BOARD COMPUTER *
* Copyright (c)1991-2018 by BCS Technology Limited. All rights reserved. *
* Permission is hereby granted to use, copy, modify and distribute this software, *
* provided this copyright notice remains unaltered in the source code and proper *
* attribution is given. Redistribution, in any form, must be at no charge to the *
* end user. This code or any part thereof, including any derivation, MAY NOT be *
* incorporated into any package intended for sale unless written permission to do *
* so has been granted by the copyright holder. *
* THERE IS NO WARRANTY OF ANY KIND WITH THIS SOFTWARE. *
* While it is believed that all code will perform as intended, the user assumes *
* all risk in connection with the incorporation of this software into any system. *
* VERSION HISTORY *
Ver Rev Date Revision
0.1.0 2014/11/25 Original version.
0.5.0 2016/08/16 Added D-block RAM decoding & HIRAM write protection.
0.5.1 2018/05/20 Redesign wait-state logic & reduced wait-state duration to
one clock cycle.
Name glue;
PartNo B402170001;
Date 2014/11/25;
Revision 0.5.1;
Designer BDD;
Company BCS Technology Limited;
Assembly POC V2;
Location U2;
Device f1504ispplcc44;
R P
V V E V H G A A
D R W C P S D I N 1 1
1 D D C A B A 2 D 3 1
____________________________________
/ 6 5 4 3 2 1 44 43 42 41 40 \
TDI | 7 39 | A10
D2 | 8 38 | TDO
D0 | 9 37 | A9
GND | 10 36 | A8
IO0 | 11 35 | VCC
IO1 | 12 ATF1504AS 34 | A12
TMS | 13 44-Lead PLCC 33 | D3
STP | 14 32 | TCK
VCC | 15 31 | RST
IO2 | 16 30 | GND
IO3 | 17 29 | ROM
| 18 19 20 21 22 23 24 25 26 27 28 |
\____________________________________/
I A A A G V R A A R R
O 1 1 1 N C W 1 1 A A
4 8 6 7 D C B 5 4 M M
1 0
property atmel {cascade_logic=on};
property atmel {logic_doubling=off};
property atmel {output_fast=off};
property atmel {pin_keep=off};
property atmel {preassign=keep};
property atmel {security=off};
property atmel {xor_synthesis=on};
PIN ASSIGNMENTS
pin 1 = RESB; /* system reset */
pin 2 = VPA; /* valid program address */
pin 4 = !WD; /* write data */
pin 5 = !RD; /* read data */
pin 6 = D1; /* data line */
pin 8 = D2; /* data line */
pin 9 = D0; /* data line */
pin 11 = !IO1; /* I/O device 'B' select */
pin 12 = !IO0; /* I/O device 'A' select */
pin 14 = STP; /* wait-state control */
pin 16 = !IO2; /* I/O device 'C' select */
pin 17 = !IO3; /* I/O device 'D' select */
pin 18 = !IO4; /* I/O device 'E' select */
pin 19 = A18; /* address line */
pin 20 = A16; /* address line */
pin 21 = A17; /* address line */
pin 24 = RWB; /* read/write */
pin 25 = A15; /* address line */
pin 26 = A14; /* address line */
pin 27 = !RAM1; /* RAM chip select */
pin 28 = !RAM0; /* RAM chip select */
pin 29 = !ROM; /* ROM chip select */
pin 31 = !RST; /* inverted reset */
pin 33 = D3; /* data line */
pin 34 = A12; /* address line */
pin 36 = A8; /* address line */
pin 37 = A9; /* address line */
pin 39 = A10; /* address line */
pin 40 = A11; /* address line */
pin 41 = A13; /* address line */
pin 43 = PHI2; /* system clock */
pin 44 = VDA; /* valid data address */
MACHINE ARCHITECTURE & HARDWARE MANAGEMENT UNIT DEFINTIONS
+--------------------------+ $0FFFFF
| Extended RAM (960 KB) |
+-------+--------------------------+ $010000
| HIRAM | HIROM (8 KB) |
+-------+--------------------------+ $00E000
| Hardware Management Unit |
+--------------------------+ $00DF00
| D8RAM (1.75 KB) |
+-------+--------------------------+ $00D800
| IORAM | IODEV (2 KB) |
+-------+--------------------------+ $00D000
| LOROM | LORAM (4 KB) |
+-------+--------------------------+ $00C000
| BASRAM (48 KB) |
+--------------------------+ $000000
1 KB = 1024 bytes
HMU
Register Address Register Description Type Bit Function
hmumcfg $00DF00 System configuration: R/W 0 0: RAM at $00C000-$00CFFF (default)
1: ROM at $00C000-$00CFFF
1 0: ROM at $00E000-$00FFFF (default)
1: RAM at $00E000-$00FFFF
2 0: I/O at $00D000-$00D7FF (default)
1: RAM at $00D000-$00D7FF
3 0: HIRAM write-enabled (default)
1: HIRAM write-protected
Notes: 1) Writing to ROM "bleeds through" to RAM at same address. This behavior will be
inhibited when writing to HIROM if HIRAM has been write-protected.
2) The HMU itself is read/write & cannot be mapped out.
$DEFINE cblkmap hmumcfg0 /* LORAM/LOROM control */
$DEFINE dblkmap hmumcfg2 /* IODEV/IORAM control */
$DEFINE eblkmap hmumcfg1 /* HIROM/HIRAM control */
$DEFINE eblkctl hmumcfg3 /* HIRAM write control */
BURIED LOGIC DECLARATIONS
pinnode = [blatch0..3]; /* bank address registers */
pinnode = [hmumcfg0..3]; /* hardware management unit registers */
pinnode = bank0; /* 1 = address is $000000-$00FFFF */
pinnode = basram; /* 1 = address is $000000-$00BFFF */
pinnode = bavalid; /* 1 = bank address valid */
pinnode = cblk; /* 1 = address is $00C000-$00CFFF */
pinnode = dblk; /* 1 = address is $00D000-$00DFFF */
pinnode = eblk; /* 1 = address is $00E000-$00FFFF */
pinnode = extram; /* 1 = address is $010000-$07FFFF */
pinnode = hmusel; /* 1 = HMU being accessed */
pinnode = hiramwp; /* 1 = HIRAM write-protected */
pinnode = ioblk; /* 1 = I/O address space being accessed */
pinnode = iosel; /* 1 = I/O device selected */
pinnode = mcfgsel; /* 1 = HMU configuration being accessed */
pinnode = ramsel; /* 1 = RAM selected */
pinnode = rhflag; /* 1 = data fetch on high clock */
pinnode = romsel; /* 1 = ROM selected */
pinnode = wsext; /* 1 = hold bus & control states */
pinnode = vab; /* 1 = address bus valid */
pinnode = wsff; /* wait-state flip-flop */
pinnode = wsflag; /* 1 = wait-state in progress */
RESETS
$REPEAT i = [0..3]
hmumcfg{i}.AR = !RESB;
$REPEND
wsff.AR = !RESB;
INTERMEDIATE CONTROL LOGIC
vab = VDA # VPA; /* true if valid address */
rhflag = RWB & PHI2; /* true if fetch on high clock */
bavalid = vab & !PHI2; /* true if bank address valid */
A16-A19 LATCHING LOGIC
[blatch0..3].LE = bavalid & !wsext; /* open latches, unless in wait-state */
[blatch0..3].L = [D0..3] & bavalid & !wsext; /* capture bank, unless in wait-state */
bank0 = [blatch0..3]:'b'0000; /* true if bank = $00 */
extram = !bank0; /* true if bank != $00 */
MEMORY MAP BASIC LOGIC
basram = bank0 & (!A15 # !A14); /* $000000-$00BFFF */
cblk = bank0 & A15 & A14 & !A13 & !A12; /* $00C000-$00CFFF */
dblk = bank0 & A15 & A14 & !A13 & A12; /* $00D000-$00DFFF */
eblk = bank0 & A15 & A14 & A13; /* $00E000-$00FFFF */
ioblk = dblk & !A11; /* $00D000-$00D7FF */
d8ram = dblk & A11 & !(A10 & A9 & A8); /* $00D800-$00DEFF */
hmu = dblk & A11 & A10 & A9 & A8; /* $00DF00-$00DFFF */
RAM SELECTION LOGIC
ramsel = basram # /* select if BASRAM, or... */
(cblk & (!RWB # !cblkmap)) # /* LORAM if mapped, or... */
ioblk & dblkmap # /* IORAM if mapped, or... */
d8ram # /* D8RAM, or... */
eblk & (!RWB # eblkmap) # /* HIRAM if mapped, or... */
extram; /* extended RAM */
/* HIRAM write-protection rule... */
hiramwp = eblk & eblkctl; /* true if HIRAM is write protected */
ROM SELECTION LOGIC
romsel = RWB & ((cblk & cblkmap) # /* C-ROM if mapped, or... */
(eblk & !eblkmap)); /* E-ROM if mapped */
I/O DEVICES SELECTION LOGIC
iosel = ioblk & !dblkmap; /* $00D0xx-$00DExx if mapped */
WAIT-STATE LOGIC
wsflag = iosel # romsel; /* wait-state if I/O or ROM & enabled */
wsff.CK = PHI2;
wsff.D = !wsff & wsflag;
wsext = PHI2 # wsff; /* 1 = wait-state in progress */
OUTPUT STATEMENTS
[A16..18] = [blatch0..2] & vab; /* A16-A18 address bits */
IO0 = iosel & vab & !A10 & !A9 & !A8; /* I/O device 'A' select */
IO1 = iosel & vab & !A10 & !A9 & A8; /* I/O device 'B' select */
IO2 = iosel & vab & !A10 & A9 & !A8; /* I/O device 'C' select */
IO3 = iosel & vab & !A10 & A9 & A8; /* I/O device 'D' select */
IO4 = iosel & vab & A10 & !A9 & !A8; /* I/O device 'E' select */
RAM0 = ramsel & !blatch3 & vab; /* RAM0 chip enable */
RAM1 = ramsel & blatch3 & vab; /* RAM1 chip enable */
RD = wsext & RWB & vab; /* read */
STP = !wsff; /* MPU wait-state */
STP.oe = wsflag; /* active if wait-stating */
ROM = romsel & vab; /* ROM chip enable */
RST = RESB; /* inverted reset */
WD = wsext & !RWB & !hiramwp & vab; /* write, but not to protected HIRAM */
HMU REGISTER READ/WRITE STATEMENTS
[D0..3].oe = hmu & rhflag; /* enable output on D0-D3 */
[D0..3] = hmu & [hmumcfg0..3] & rhflag; /* HMU bit pattern on D0-D3 */
[hmumcfg0..3].LE = hmu & !RWB & PHI2; /* open HMU latches */
[hmumcfg0..3].L = hmu & [D0..3] & !RWB & PHI2; /* D0-D3 bit pattern on HMU */
/* * * * * E N D O F F I L E * * * * */
