Not your run of the mill control flow
Re: Not your run of the mill control flow
I mentioned elsewhere that [BEGIN] and [UNTIL] may not be needed on a system with EVALUATE .
These are reasonably generic versions of the new LOAD and THRU .
VARIABLE HISTORY
: LOAD ( BLK# -- )
DUP 0= ABORT" CAN'T LOAD 0"
BLK @ >IN @ 2>R
>IN OFF BLK !
INTERPRET
BLK @ HISTORY !
2R> >IN ! BLK ! ;
: THRU ( U1 U2 -- )
>R
BEGIN
5 ?CR
DUP U. LOAD
R@ HISTORY @ 1+ TUCK U<
DONE? OR
UNTIL
R> 2DROP ;
Only words from the Forth-83 Standard are used in the versions presented below. INTERPRET is from the controlled reference words and 2DROP is from the double number extension word set. All other words are from the required wordset.
VARIABLE HISTORY
: LOAD ( BLK# -- )
BLK @ >IN @ >R >R
0 >IN ! BLK !
INTERPRET
BLK @ HISTORY !
R> R> >IN ! BLK ! ;
: THRU ( U1 U2 -- )
>R
BEGIN
DUP U. LOAD
HISTORY @ 1+ R@ OVER U<
UNTIL
R> 2DROP ;
In the definition of LOAD it may be tempting to store the value of BLK in HISTORY before INTERPRET when it is stored in BLK . Don't do it! With the version of LOAD which saves BLK in HISTORY it must be done AFTER INTERPRET because INTERPRET could change the block number if a screen has --> or the fancier version of [UNTIL] .
I mentioned in a previous post that a version of THRU which is compatible with --> makes it possible to chain together all the screens for a word spanning multiple screens without causing problems if those same screens are also in a range loaded with THRU. It is my hope that this will encourage Forth programmers keeping source in screens to use a structured layout rather than that unreadable horizontal format for source. I'm definitely in support of tools which encourage readable source.
This:
SCR# 125
// NUMBER?
: NUMBER? ( ADR -- D FLAG )
RB
1+ DUP C@ ASCII # - DUP 3 U<
IF
BASE.TABLE + C@ BASE !
COUNT
THEN
DROP
DPL ON
COUNT ASCII - <> DUP>R +
COUNT DIGIT DUP>R AND 0
ROT
SCR# 126
// NUMBER?
BEGIN
1- CONVERT COUNT VALID?
WHILE
DPL OFF
DUP C@ VALID?
UNTIL
THEN
1- C@ BL = R> AND
R> ?EXIT
>R DNEGATE R> ;
vs this:
SCR# 125
// NUMBER?
: NUMBER? ( ADR -- D FLAG ) RB 1+ DUP C@ ASCII # - DUP 3 U<
IF BASE.TABLE + C@ BASE ! COUNT THEN DROP DPL ON COUNT
ASCII - <> DUP>R + COUNT DIGIT DUP>R AND 0 ROT BEGIN 1-
CONVERT COUNT VALID? WHILE DPL OFF DUP C@ VALID? UNTIL
THEN 1- C@ BL = R> AND R> ?EXIT >R DNEGATE R> ;
JimBoyd wrote:
This post concerns a technique used on Forth systems with indirect threaded code (ITC). It may work with other threading models.
Although the example from M. L. Gassanenko's paper "Dynamically Structured Codes" wasn't really self modifying code, it certainly is not your run of the mill control flow.
Just as EXECUTE takes the address of a word's Code Field and launches that word, ENTER takes the address of a fragment of threaded code and 'launches' that fragment. The address must align on what Gassanenko calls an active 'threaded code element', or a TCE. An active TCE is an address which holds the CFA of a Forth word. The 'threaded code fragment' must also exit (or branch somewhere which exits or aborts).
: ENTER ( T-ADR -- ) >R ;
An address is placed on the return stack followed by EXIT or its equivalent, which is compiled by semicolon.
Here is a functionally equivalent definition of ENTER .
[ ASSEMBLER ] IP [ FORTH ] ! -;
Since -; does not compile EXIT , this version of ENTER is the same size.
Although do-colon changes the value of IP , what I wish to point out is that it first pushes the current value in IP onto the return stack. The address on the data stack is stored in IP . This version only works because ! (store) is a primitive. It stores the address in IP , drops the two values from the data stack and goes to NEXT . NEXT resumes address interpretation starting at the address T-ADR . When an EXIT is encountered, execution resumes in the word which called ENTER .
High level Forth words can branch using ?BRANCH and BRANCH . ENTER is similar to a subroutine call for high level Forth, with one major difference. The destination of the "subroutine call" is specified at run time which is like a computed GOSUB from BASIC .
I have the following in a few places in my Forth's system loader.
XXXX ENTER
where XXXX is a literal number known, or computed, at compile time. This is like a high level subroutine call, or a non computed GOSUB.
The following uses of ENTER are like a computed GOSUB .
R@ ENTER
<SOME.VARIABLE> @ ENTER
<SOME.VALUE> ENTER
or even just ENTER by itself if the word using it requires an address to be on the data stack.
: TEXECUTE ( T-ADR -- ) \ Execute trailing part of a high level word.
ENTER ;
An STC version of ENTER would not just compile a subroutine call to an address known at compile time. It would not be this:
$20 C, , ; IMMEDIATE
An STC version of ENTER for the 6502 would look like this:
1- >R ;
In an STC Forth for the 6502, any time an address is copied from the return stack for use with ENTER it would need adjusted.
For example, FORK would change from this:
: FORK ( -- FLAG )
TRUE R@ ENTER FALSE ;
to this:
: FORK ( -- FLAG )
TRUE R@ 1+ ENTER FALSE ;
Which is why I initially stated that it is a technique for an ITC Forth.
- GARTHWILSON
- Forum Moderator
Re: Not your run-of-the-mill control flow
Thanks. This kind of thing has crossed my mind before, but I never did it. I don't remember what I might have wanted it for (and ended up taking a different approach). Do you have real-life example usages?
I've mentioned before that my Forth has EVALUATE . Since WORD parses from a BLOCK or the text input buffer, my Forth's EVALUATE saves the current values of TIB and #TIB as well as BLK and >IN .
: EVALUATE ( ADR N -- )
TIB #TIB @ 2>R
#TIB ! (IS) TIB
BLK 2@ 2>R
BLK OFF >IN OFF
INTERPRET
2R> BLK 2!
2R> #TIB ! (IS) TIB ;
(IS) gets compiled by IS and TO . Although IS will only write to the PFA of a DEFERred word and TO will only write to the body of a VALUE , (IS) will write to the body of anything.
This version of EVALUATE has a section which is similar to LOAD or LINELOAD . I can't have EVALUATE call LOAD or LINELOAD directly because both abort if trying to "load" block zero. I can use ENTER to enter the body of LINELOAD , which is used by LOAD , and return. The following is used twice in EVALUATE
#TIB ! (IS) TIB
I can reuse this section without factoring out a word useless for anything else.
: EVALUATE ( ADR CNT -- )
TIB #TIB @ 2>R
LIT [ >MARK ] ENTER
0 0 LIT
[ ' LINELOAD >BODY DUP TRUE
" LOAD 0" COUNT MATCH ?HUH
ENTER
2R>
[ >RESOLVE ]
#TIB ! (IS) TIB ;
The following line:
searches for the string in LINELOAD and returns the offset to the end.
: LINELOAD ( LINE# BLK# -- )
DUP 0=
BLK 2@ 2>R
BLK ! C/L * >IN !
INTERPRET 2R>
BRANCH [ BLK.2! , ] -;
Here is the decompilation of EVALUATE
SEE EVALUATE
EVALUATE
16390 2761 TIB
16392 2623 #TIB
16394 3593 @
16396 4768 2>R
16398 3286 LIT 16416
16402 13953 ENTER
16404 3325 0
16406 3325 0
16408 3286 LIT 11109
16412 13953 ENTER
16414 4791 2R>
16416 2623 #TIB
16418 2230 !
16420 7834 (IS)
16422 2761 TIB
16424 2480 EXIT
36
OK
This version of EVALUATE is 14 bytes smaller. ENTER has a body size of 4 bytes, a 2 byte code field, 6 byte name field and a 2 byte link field for a total of 14 bytes.
I also saved a couple of bytes with two other words: VOCS and ORDER . VOCS shows the VOCABULARY tree structure and is recursive, but not in the sense that the entire word is recursively called.
: VOCS ( -- )
[ ' FORTH >BODY ] LITERAL 0 CR
[ <MARK ]
?STACK DUP>R SPACES
DUP BODY> >NAME ID. CR
VOC-LINK @
BEGIN
2DUP 2- @ =
IF
DUP 2- 2- R@ 2+ LIT
CS-ROT [ <RESOLVE ] ENTER
THEN
@ ?DUP 0=
UNTIL
R> 2DROP ;
The first line does not take part in the recursion; however, everything that follows does take part. The original version of VOCS factored out the recursive part as a :NONAME word. Although this version is only two bytes smaller, it's much easier to use with TRACE . Tracing by hand is fine when initially working out the logic for a word. Once a word is defined, the TRACE word is much more convenient. With the original version, I would have to either manually enter the addresses for <IP and IP> , the start and end limits for the trace range, or give the headerless word a name.
It's also possible to have a word with a recursive part within a larger recursive part.
ORDER is not recursive. It reuses a section of code.
: ORDER ( -- )
CONTEXT
LIT [ >MARK ] ENTER
CURRENT
[ >RESOLVE ]
CR DUP BODY> >NAME ID. ." : "
BEGIN
2+ @ ?DUP 0EXIT
9 SPACES
AGAIN -;
ENTER can also be used with other tools for diagnostics.
Tracing my Forth's new FORGET can be problematic. The new FORGET has NEXT> . NEXT> restores NEXT which switches off tracing. The word which was in the process of being traced resumes normal execution without tracing. Since The trace word I use, a modification of Blazin' Forth's trace word, single steps and waits for a key-press to continue, ENTER can help.
TRACE FORGET OK
.S EMPTY OK
FORGET BAD.WORD
NAME EMPTY
CURRENT 29282
@ 29282 2604
DUP 29282 9637
CONTEXT 29282 9637 9637
! 29282 9637 9637 2590
29282 9637
?HUH 29278 65535
>LINK 29278
NEXT> 29267 TRACING OFF
Trace prints the name of the word which is about to be called and displays the data stack contents. The last line is where I pressed the RUN/STOP key to stop tracing before NEXT> was called. This not only stops the trace, it calls quit.
The following shows where I resume tracing FORGET . Instead of calling FORGET directly, I use ENTER to "GOSUB" into the body of FORGET . Including the headerless word for FORGET's new (FIND) , there are ten words to skip.
TRACE FORGET OK
' FORGET >BODY 20 + ENTER
UNLINK 29267
SINGLE 29267
DUP>R 29267
FENCE 29267
@ 29267 2531
LIT 29267 29218
UMAX 29267 29218 12054
U< 29267 29218
(ABORT") 0
VOC-LINK EMPTY
R@ 2675
TRIM 2675 29267
VOC-LINK EMPTY
@ 2675
DUP 26741
2- 26741 26741
2- 26741 26739
R@ 26741 26737
TRIM 26741 26737 29267
@ 26741
?DUP 24043
0= 24043 24043
?BRANCH 24043 0
DUP 24043
2- 24043 24043
2- 24043 24041
R@ 24043 24039
TRIM 24043 24039 29267
@ 24043
?DUP 24027
0= 24027 24027
?BRANCH 24027 0
DUP 24027
2- 24027 24027
2- 24027 24025
R@ 24027 24023
TRIM 24027 24023 29267
@ 24027
?DUP 24010
0= 24010 24010
?BRANCH 24010 0
DUP 24010
2- 24010 24010
2- 24010 24008
R@ 24010 24006
TRIM 24010 24006 29267
@ 24010
?DUP 14303
0= 14303 14303
?BRANCH 14303 0
DUP 14303
2- 14303 14303
2- 14303 14301
R@ 14303 14299
TRIM 14303 14299 29267
@ 14303
?DUP 12165
0= 12165 12165
?BRANCH 12165 0
DUP 12165
2- 12165 12165
2- 12165 12163
R@ 12165 12161
TRIM 12165 12161 29267
@ 12165
?DUP 9641
0= 9641 9641
?BRANCH 9641 0
DUP 9641
2- 9641 9641
2- 9641 9639
R@ 9641 9637
TRIM 9641 9637 29267
@ 9641
?DUP 0
0= 0
?BRANCH 65535
R> EMPTY
DUP 29267
DP 29267 29267
! 29267 29267 872
LIT 29267
@ 29267 2077
UMIN 29267 29218
LIT 29218
! 29218 2077
HERE EMPTY
LIT 29267
BRANCH 29267 3053 OK
ENTER can be used to enter into the body of a high level word, with or without tracing, for diagnostic purposes. It can not be used to enter into the middle of a DO LOOP without causing problems, nor can it be used to enter into the middle of code which temporarily places items on the return stack; however, a word could be written which places the appropriate parameters on the return stack and calls ENTER .
In summary, not only can ENTER save a few bytes, it is also a handy diagnostic tool.
Regarding what M.L.Gassanenko mentions in his papers, I'll need to study that further.
[Edit: Corrected spelling: I just noticed that I misspelled M.L.Gassanenko's last name.]
JimBoyd wrote:
One of the words I added to my version of FIG Forth is NIF (short for "not if").
IFF -- IF FALSE
WHILEF -- WHILE FALSE
UNTILF -- UNTIL FALSE
JimBoyd wrote:
: FORK ( -- FLAG )
: enter 1- >r ; ok
: fork true R@ 1+ enter false ; ok
fork . 0 ok
: test fork . ; ok
test -1 0 ok
: print01 if 1 else 0 then 1 u.r ; ok
5 print01 1 ok
0 print01 0 ok
: testmany fork print01 fork print01 fork print01 cr ; ok
testmany 111
0
01
0
011
0
01
0
okCode: Select all
variable dig1 ok
variable dig2 ok
variable dig3 ok
: printdigs dig1 @ print01 dig2 @ print01 dig3 @ print01 cr ; ok
printdigs 000
ok
: testmany fork dig1 ! fork dig2 ! fork dig3 ! printdigs ; redefined testmany ok
testmany 111
110
101
100
011
010
001
000
okRe: Not your run of the mill control flow
JimBoyd wrote:
This works on my system. A negative argument to SPACES (used by .R) prints nothing. Other systems might need print01 defined as this:
: PRINT01 1 AND 1 .R ;
Although it seems reasonable to me that a negative argument to SPACES should result in zero spaces without an error because SPACES takes a signed value.
SamCoVT wrote:
JimBoyd wrote:
: FORK ( -- FLAG )
: enter 1- >r ; ok
fork . 0 ok
: test fork . ; ok
test -1 0 ok
5 print01 1 ok
0 print01 0 ok
testmany 111
0
01
0
011
0
01
0
okCode: Select all
variable dig1 ok
variable dig2 ok
variable dig3 ok
printdigs 000
ok
testmany 111
110
101
100
011
010
001
000
okCode: Select all
: TESTMANY
FORK 1 AND $30 + PAD C!
FORK 1 AND $30 + PAD 1+ C!
FORK 1 AND $30 + PAD 2+ C!
PAD 3 TYPE CR ;
Using ASCII for clarity:
: TESTMANY
FORK 1 AND ASCII 0 + PAD C!
FORK 1 AND ASCII 0 + PAD 1+ C!
FORK 1 AND ASCII 0 + PAD 2+ C!
PAD 3 TYPE CR ;
ANSI Forth:
: TESTMANY
FORK 1 AND [CHAR] 0 + PAD C!
FORK 1 AND [CHAR] 0 + PAD 1+ C!
FORK 1 AND [CHAR] 0 + PAD 2+ C!
PAD 3 TYPE CR ;
JimBoyd wrote:
... it seems reasonable to me that a negative argument to SPACES should result in zero spaces without an error because SPACES takes a signed value.
ANS 2012 wrote:
SPACES ( n -- ) If n is greater than zero, display n spaces.
JimBoyd wrote:
ANSI Forth:
: TESTMANY
PAD 3 TYPE CR ;Re: Not your run of the mill control flow
SamCoVT wrote:
2+ isn't in the 2012 ANS standard. Once I wrote it, this compiled and worked great. I totally forgot about PAD and that this is exactly what it was intended to be used for.
: TESTMANY
FORK 1 AND [CHAR] 0 + PAD 2 + C!
PAD 3 TYPE CR ;
The nice thing about words like 2+ and DUP>R , it's easy to see where to split the name in the source to make it compatible.
I believe FOR...NEXT is in the newest standards, probably as a concession to reduce newcomers' resistance to Forth, but I do like DO...LOOP and friends. I have 32-bit equivalents too, at http://wilsonminesco.com/Forth/32DOLOOP.FTH .
I think the FOR NEXT loop may have been a low memory alternative to DO LOOPs for memory constrained systems.
Gforth has FOR and NEXT but not AFT , and it's not the only Forth system to have the FOR NEXT loop without AFT , not that anyone would claim Gforth is a minimal system.
I found some interesting control flow words in the Forth literature. The word GEN , for generator, uses these control flow words. Here is the source for GENTEST , a word to test GEN .
: GENTEST ( -- )
2 GEN CR .
4 GEN CR 2 .R
3 GEN CR 3 .R ;
Here is the test run:
GENTEST
0
0
0
1
2
1
0
1
2
2
0
1
2
3
0
1
2
1
0
0
1
2
1
0
1
2
2
0
1
2
3
0
1
2 OK
I will show what these words are and what they do in an upcoming post.
Now for the brain teaser. Can anyone figure out what GEN is doing and how?
