The Case for Lead-based Solder
Re: The Case for Lead-based Solder
This does seem to be one of those things where people have already made up their minds and are sticking to what they believe. (Including me, of course.)
- BigDumbDinosaur
anomie wrote:
Not that I know or can claim much about the actual effects and what levels are needed, etc - just that any people who actually did experience significant cognitive decline, or other deleterious effect, due to lead exposure would pretty probably not be here to counteract the “we did this and we’re all fine” side of it.
Ironically, the authorities who have stated that lead exposure in any amount is deleterious are in the same boat as you (and me). How would they know that without having been sufficiently exposed to lead to cause them physiological problems?
Bottom line, of course, is to use a modicum of common sense when working with substances that have to potential to cause harm. I think the science on lead exposure is fairly clear. However, when politics gets involved, truth is usually a casualty.
Although I’m interested in who these authorities who have stated “lead exposure in any amount is deleterious” actually are. Even in California, the prop 65 regulations (see 27 CCR § 25705) define lead as “Posing No Significant Risk” at an exposure level of lower than 15 micrograms orally per day. Maybe that limit is too low, I don’t claim to know - but I can claim thats certainly a higher exposure level than “any amount”.
As far as I can tell the current state is something along the lines of “companies doing risk analysis judge that slapping a sticker on at pennies-or-less per unit will cost less long term than proving in court whether or not the product contains any of the chemicals on the list and at exactly what level; especially given the list will change and presumably so will the regulations declaring levels”.
Edit: I now find myself wondering how that 15 microgram limit was codified and whether or not it’s at all related to the EPA limit for lead in drinking water being 15 micrograms/liter.
sburrow wrote:
I sometimes use 'tubes' of lead solder and stick the tube in my mouth.
https://www.mouser.com/ProductDetail/Ch ... 8BhQ%3D%3D
I haven't done that in a while though, I normally find other ways now-a-days. What I need to get is some sticky-tack or play-dough, I've seen some folks use those on repair videos to hold things in just the right spot.
I also use a rubber thimble to protect my fingers a bit from the heat when supporting components that are being soldered, as I am oversensitive to heat.
I did a video many years back showing soldering up one of a little project board I did for the Raspberry Pi that I sold at the time - the video got more views than I expected - it's an overly long/rambling video, but here is a cut to the chase:
https://youtu.be/K5zrgEDsxSQ?t=1278
my secret weapon/third hand is blue tack ...
- BigDumbDinosaur
You should learn to play the upright bass, like Jeff and me.
After a while, the calluses on some of your fingers will get to where you might not be able to tell when you’ve bumped them with the soldering iron tip...at least until the “aroma” of burning skin reaches your nostrils.
I've always thought the double bass is a lovely instrument though, if you have enough space to keep it!
