Page 4 of 4
Re: What do the operands and symbols mean? Anyone?
Posted: Thu Oct 07, 2021 2:08 pm
by Jmstein7
Got another one. I'm trying to port a program for the 65c816, and I encountered this bit of code:
; D - Disassemble Memory
cmp #'D' ; Memory display?
bne NotDisassemble
ldx #ADDR_S ; Parse start address
jsr GetAddr
bcc $+5
jmp ShowError
ldx #ADDR_E ; Parse end address
jsr GetAddr
bcc $+5
jmp ShowError
php
pla
sta FLAGS
My assembler doesn't like the "$+5". I think the code is trying to advance the PC five addresses forward, if the carry flag is cleared,in which case I think I could do:
Is this correct, anybody? I've not encountered "$+" before.
Jon
Posted: Thu Oct 07, 2021 2:39 pm
by drogon
bne NotDisassemble
jsr GetAddr
bcc $+5
jmp ShowError
jsr GetAddr
bcc $+5
jmp ShowError
php
pla
sta FLAGS
Does it work with *+5?
To remove confusion, I'd be inclined to replace them with labels though.
so:
jsr GetAddr
bcc startOk
jmp ShowError
startOK:
jsr GetAddr
bcc endOK
jmp ShowError
endOK:
and so on.
Posted: Thu Oct 07, 2021 3:09 pm
by Jmstein7
so:
jsr GetAddr
bcc startOk
jmp ShowError
startOK:
jsr GetAddr
bcc endOK
jmp ShowError
endOK:
and so on.
Great idea! There are thousands of lines of code, so it would be hard to debug. The other item I'm having trouble with is this:
.macro MNEM(P,Q,R)
.dword ((((P-'@')<<5)|(Q-'@'))<<5)|(R-'@')
.endmacro
It is telling me that this is an "Unsupported format of parameters" with regards to
Argh!
Posted: Thu Oct 07, 2021 3:19 pm
by John West
It's taking three characters and packing them into a 16 bit word. P is given the top 6 bits, Q is given the next 5, and R the lowest 5. @ is encoded as 0, A as 1, B as 2, and so on. Unwrapping it: P-'@' subtracts the code for @ from P, giving 0, 1, 2, ... Then it shifts that up 5 bits. Q-'@' does the same to Q, these two result get ORed together by the |, then the result of that is shifted five bits up. Finally the value from R gets ORed in.
Your assembler obviously doesn't like this expression as it is, but I couldn't guess exactly what it's complaining about. It's not the most helpful error message. I'd start by stripping the expression down the the bare minimum and gradually adding bits back until it fails. So
.dword P
.dword P-'@'
.dword (P-'@')<<5
and so on. Knowing which bit of syntax it's unhappy about will help a lot in trying to write something that it does like.
Posted: Thu Oct 07, 2021 3:21 pm
by drogon
.macro MNEM(P,Q,R)
.endmacro
Argh!
It's compressing 3 characters into 2 bytes. Woz did this in his disassembler and one-line assembler. If this is failing for you, then your assembler doesn't support those actions, so short of changing assembler, you might need to work it out the hard way.
Although checking now - .dword - that might imply a double word and maybe 4 bytes, so compressing 3 characters into 4 bytes is odd, so I guess it really means a 16-bit word. I checked it in ca65 and it seems OK, but the syntax is different, so:
.macro MNEM P,Q,R
.word ((((P-'@')<<5)|(Q-'@'))<<5)|(R-'@')
.endmacro
MNEM 'L','D','A'
works with the output:
So, L,D,A -> $81, $30.
Posted: Thu Oct 07, 2021 4:32 pm
by Jmstein7
No matter how I try, it just won’t work - word, double word, bytes, etc.
This is driving me bananas.
Posted: Thu Oct 07, 2021 7:26 pm
by barrym95838
Can you link us to your assembler's documentation, if any? There should be a way to get the job done without hand-translating and hard-coding the hex data.
Posted: Thu Oct 07, 2021 7:38 pm
by Jmstein7
Mike,
Here it is:
https://enginedesigns.net/download/retroassembler.html
Jon
Posted: Sun Oct 10, 2021 2:25 am
.macro MNEM(P,Q,R)
.endmacro
Argh!
I tried that in the Kowalski assembler, which uses curly brackets instead of parentheses for determining evaluation precedence. It works as expected.
However, .DWORD in the retroassembler causes the generation of a 32-bit, little-endian value. Replace the .DWORD in the above expression with .WORD to produce the 16-bit, little-endian value expected by the mnemonic parser.
Posted: Mon Oct 11, 2021 1:28 pm
by Jmstein7
It didn't work with .word, but it
did work with
.textz . Weird.
Posted: Mon Oct 11, 2021 3:02 pm
by teamtempest
.macro MNEM(P,Q,R)
.endmacro
It is telling me that this is an "Unsupported format of parameters" with regards to .dword ((((P-'@')<<5)|(Q-'@'))<<5)|(R-'@')
It's telling you something is wrong with 'P', 'Q' , and/or 'R'. The expression itself is not a problem as the documentation says all the operators used are supported (same as C syntax).
Perhaps the problem is that P, Q, and R are not interpreted as characters but as labels? Subtracting a character from a label won't work. Are you writing
instead of
by any chance?
Also '.dword' generates a 32-bit value. Better is '.word' to generate a 16-bit one.
Posted: Mon Oct 11, 2021 7:44 pm
It's telling you something is wrong with 'P', 'Q' , and/or 'R'...Perhaps the problem is that P, Q, and R are not interpreted as characters but as labels? Subtracting a character from a label won't work. Are you writing
That would definitely upset the apple cart, depending on if any of those are even defined and if so, what values they hold.
As I noted in my post...
