Re: 6502 with the RA8875
Posted: Thu Jan 08, 2026 8:43 pm
A list of things you'll need to change for the 800x480 display
This is taken from the Adafruit RA8875 library, which is what I based mine on.
// (_size == RA8875_800x480)
pixclk = RA8875_PCSR_PDATL | RA8875_PCSR_2CLK;
hsync_nondisp = 26;
hsync_start = 32;
hsync_pw = 96;
hsync_finetune = 0;
vsync_nondisp = 32;
vsync_start = 23;
vsync_pw = 2;
_voffset = 0;
writeReg(RA8875_PCSR, pixclk);
delay(1);
/* Horizontal settings registers */
writeReg(RA8875_HDWR, (_width / 8) - 1); // H width: (HDWR + 1) * 8 = 480
writeReg(RA8875_HNDFTR, RA8875_HNDFTR_DE_HIGH + hsync_finetune);
writeReg(RA8875_HNDR, (hsync_nondisp - hsync_finetune - 2) /
8); // H non-display: HNDR * 8 + HNDFTR + 2 = 10
writeReg(RA8875_HSTR, hsync_start / 8 - 1); // Hsync start: (HSTR + 1)*8
writeReg(RA8875_HPWR,
RA8875_HPWR_LOW +
(hsync_pw / 8 - 1)); // HSync pulse width = (HPWR+1) * 8
/* Vertical settings registers */
writeReg(RA8875_VDHR0, (uint16_t)(_height - 1 + _voffset) & 0xFF);
writeReg(RA8875_VDHR1, (uint16_t)(_height - 1 + _voffset) >> 8);
writeReg(RA8875_VNDR0, vsync_nondisp - 1); // V non-display period = VNDR + 1
writeReg(RA8875_VNDR1, vsync_nondisp >> 8);
writeReg(RA8875_VSTR0, vsync_start - 1); // Vsync start position = VSTR + 1
writeReg(RA8875_VSTR1, vsync_start >> 8);
writeReg(RA8875_VPWR,
RA8875_VPWR_LOW + vsync_pw - 1); // Vsync pulse width = VPWR + 1
/* Set active window X */
writeReg(RA8875_HSAW0, 0); // horizontal start point
writeReg(RA8875_HSAW1, 0);
writeReg(RA8875_HEAW0, (uint16_t)(_width - 1) & 0xFF); // horizontal end point
writeReg(RA8875_HEAW1, (uint16_t)(_width - 1) >> 8);
/* Set active window Y */
writeReg(RA8875_VSAW0, 0 + _voffset); // vertical start point
writeReg(RA8875_VSAW1, 0 + _voffset);
writeReg(RA8875_VEAW0,
(uint16_t)(_height - 1 + _voffset) & 0xFF); // vertical end point
writeReg(RA8875_VEAW1, (uint16_t)(_height - 1 + _voffset) >> 8);
