Page 4 of 12
Re: Wolin - a minimal Kotlin-like language compiler for 65xx
Posted: Sun Jun 23, 2019 7:52 pm
by Chromatix
The normal bitwise operators also work if you define 1 as true. The principle advantage of using -1 is that you can use (A & F)|(B & !F) as a selection operator, versus (A * F)|(B * !F) - given that the 6502 isn't good at multiplication.
Posted: Mon Jun 24, 2019 3:11 am
by dmsc
Hi!
I think the way BBC Basic does booleans is nice: booleans are integers, 0 is false and anything else is true. But -1 is a kind of official true. With these definitions, boolean logic can use the same operators as bitwise logic. (I think this is similar to old-fashioned C, although C has different operators for boolean and bitwise operations.)
-1 in your case would indeed be 255.
In a compiler you can have different representations than the visible values.
For example, in FastBasic, all booleans are internally set to "0" or "1", and represented with only one byte. The compiler takes care of transforming any non-zero integer value to 1 before passing to operators expecting a boolean. So, " A = B OR C " is compiled to " A = (B<>0) OR (C<>0) ".
Posted: Mon Jun 24, 2019 9:35 am
by qus
It works in a different way here, since Kotlin is strongly typed, you can't really put anything other than boolean where boolean is expected, so C's favorite error:
if(a=1) { ... }
Will fail at compile time, since value of assignment operation is of type unit (= void in C) and if requires bool.
I have two types of operations:
- ones that preserve expression type and require just two stack registers (one from previous op, one created), i.e. addition gets operands from two top registers, adds them, stores result in the one below top register and frees top register, thus now we have addition result on top and it can be used by "surrounding" expression
- ones that change result type and require new register, like comparison, that evaluates to bool:
evaleq SP(?dest)[bool] = SP(?left)[ubyte], SP(?right)[ubyte] -> """
    lda #1 // put true in dest reg
    sta {dest},x
    lda {left},x
    cmp {right},x
    beq +
    lda #0 // aaaaw... so they're false after all...
    sta {dest},x
These require three registers - one from previous op and two created and freed after evaluation, the result again in top register. Excatly like in the stack treatsie :D
Posted: Tue Jul 16, 2019 5:23 am
by qus
Being frustrated by trying to create nice code for assigning things to array elements I decided to implement "when" statement. "When" is like if...elseif...elseif or switch...case on steroids. It has two kinds of syntax:
    when {
        b == 1 -> c++
        b == 2 -> c--
meaning: "when b equals 1, increment c, when b equals 2, decrement c"
But Kotlin IDE would tell you to rewrite this case simply with:
    when (b) {
        1 -> c++
        2 -> c--
And that's second syntax. In Wolin these get compiled to:
alloc SP<__wolin_reg0>, #2 // for block level expression when{\nb==1->c++\nb==2->c--\n}
alloc SP<__wolin_reg1>, #1 // for condition result
alloc SP<__wolin_reg2>, #1 // for evaluating when condition
label __wolin_lab_whenLabel_0
alloc SP<__wolin_reg3>, #1 // LEFT equality check: evaleq
let SP(0)<__wolin_reg3>[ubyte] = __wolin_pl_qus_wolin_test_b<pl.qus.wolin.test.b>[ubyte] // simple id from var
alloc SP<__wolin_reg4>, #1 // RIGHT equality check: evaleq
let SP(0)<__wolin_reg4>[ubyte] = #1[ubyte] // atomic ex
evaleq SP(2)<__wolin_reg2>[bool] = SP(1)<__wolin_reg3>[ubyte], SP(0)<__wolin_reg4>[ubyte] // two sides
free SP<__wolin_reg4>, #1 // RIGHT equality check: evaleq
free SP<__wolin_reg3>, #1 // LEFT equality check: evaleq
bne SP(2)<__wolin_reg0>[uword] = #1[bool], __wolin_lab_whenLabel_1[adr]
add __wolin_pl_qus_wolin_test_c<pl.qus.wolin.test.c>[uword] = __wolin_pl_qus_wolin_test_c<pl.qus.wolin.test.c>[uword], #1[byte] // simple id
goto __wolin_lab_whenEndLabel_0[adr]
label __wolin_lab_whenLabel_1
alloc SP<__wolin_reg5>, #1 // LEFT equality check: evaleq
let SP(0)<__wolin_reg5>[ubyte] = __wolin_pl_qus_wolin_test_b<pl.qus.wolin.test.b>[ubyte] // simple id from var
alloc SP<__wolin_reg6>, #1 // RIGHT equality check: evaleq
let SP(0)<__wolin_reg6>[ubyte] = #2[ubyte] // atomic ex
evaleq SP(2)<__wolin_reg2>[bool] = SP(1)<__wolin_reg5>[ubyte], SP(0)<__wolin_reg6>[ubyte] // two sides
free SP<__wolin_reg6>, #1 // RIGHT equality check: evaleq
free SP<__wolin_reg5>, #1 // LEFT equality check: evaleq
bne SP(2)<__wolin_reg0>[uword] = #1[bool], __wolin_lab_whenEndLabel_0[adr]
sub __wolin_pl_qus_wolin_test_c<pl.qus.wolin.test.c>[uword] = __wolin_pl_qus_wolin_test_c<pl.qus.wolin.test.c>[uword], #1[byte] // simple id
label __wolin_lab_whenEndLabel_0
free SP<__wolin_reg2>, #1 // for evaluating when condition
free SP<__wolin_reg1>, #1 // for condition result
free SP<__wolin_reg0>, #2 // for block level expression when{\nb==1->c++\nb==2->c--\n}, type = uword
for first syntax, and into this for second syntax:
alloc SP<__wolin_reg0>, #2 // for block level expression when(b){\n1->c++\n2->c--\n}
let SP(0)<__wolin_reg0>[uword] = __wolin_pl_qus_wolin_test_b<pl.qus.wolin.test.b>[ubyte] // simple id from var
alloc SP<__wolin_reg2>, #2 // for evaluating when condition
let SP(0)<__wolin_reg2>[uword] = #1[ubyte] // atomic ex
evaleq SP(1)<__wolin_reg1>[bool] = SP(2)<__wolin_reg0>[uword], SP(0)<__wolin_reg2>[ubyte]
bne SP(1)<__wolin_reg1>[bool] = #1[bool], __wolin_lab_whenLabel_1[adr]
let SP(0)<__wolin_reg2>[ubyte] = #2[ubyte] // atomic ex
evaleq SP(2)<__wolin_reg1>[bool] = SP(3)<__wolin_reg0>[uword], SP(0)<__wolin_reg2>[uword]
bne SP(2)<__wolin_reg1>[bool] = #1[bool], __wolin_lab_whenEndLabel_0[adr]
free SP<__wolin_reg2>, #2 // for evaluating when condition
free SP<__wolin_reg0>, #2 // for block level expression when(b){\n1->c++\n2->c--\n}, type = uword
I still need to work on type flow, as I assume there should be no implicit/default type conversions, so each two operand pseudo-asm mnemonic should process only values of the same type, unlike here (byte is added to uword):
Posted: Tue Jul 16, 2019 7:57 am
by qus
And now resulting code for:
var b: ubyte
var c: uword
var d: uword
fun main() {
    when(b) {
        1 -> c++
        2 -> c--
        else -> c =0
Result:
__wolin_pl_qus_wolin_test_main:
; allocSP<__wolin_reg0>,#2
    dex
    dex
; allocSP<__wolin_reg1>,#1
    dex
; letSP(0)<__wolin_reg1>[ubyte]=__wolin_pl_qus_wolin_test_b<pl.qus.wolin.test.b>[ubyte]
    lda __wolin_pl_qus_wolin_test_b
    sta 0,x
; allocSP<__wolin_reg2>,#1
    dex
; allocSP<__wolin_reg3>,#1
    dex
; label__wolin_lab_whenLabel_0
__wolin_lab_whenLabel_0:
; letSP(0)<__wolin_reg3>[ubyte]=#1[ubyte]
    lda #1
    sta 0,x
; evaleqSP(1)<__wolin_reg2>[bool]=SP(2)<__wolin_reg1>[ubyte],SP(0)<__wolin_reg3>[ubyte]
    lda #1 // rowne
    sta 1,x
    lda 2,x
    cmp 0,x
    beq +
    lda #0 // jednak rozne
    sta 1,x
; bneSP(1)<__wolin_reg2>[bool]=#1[bool],__wolin_lab_whenLabel_1[adr]
    lda 1,x
    cmp #1
    bne __wolin_lab_whenLabel_1
; add__wolin_pl_qus_wolin_test_c<pl.qus.wolin.test.c>[uword]=__wolin_pl_qus_wolin_test_c<pl.qus.wolin.test.c>[uword],#1[uword]
    clc
    lda __wolin_pl_qus_wolin_test_c
    adc #<1
    sta __wolin_pl_qus_wolin_test_c
    lda __wolin_pl_qus_wolin_test_c+1
    adc #>1
    sta __wolin_pl_qus_wolin_test_c+1
; goto__wolin_lab_whenEndLabel_0[adr]
    jmp __wolin_lab_whenEndLabel_0
; label__wolin_lab_whenLabel_1
__wolin_lab_whenLabel_1:
; letSP(0)<__wolin_reg3>[ubyte]=#2[ubyte]
    lda #2
    sta 0,x
    lda #1 // rowne
    sta 1,x
    lda 2,x
    cmp 0,x
    beq +
    sta 1,x
; bneSP(1)<__wolin_reg2>[bool]=#1[bool],__wolin_lab_whenLabel_2[adr]
    lda 1,x
    cmp #1
    bne __wolin_lab_whenLabel_2
; sub__wolin_pl_qus_wolin_test_c<pl.qus.wolin.test.c>[uword]=__wolin_pl_qus_wolin_test_c<pl.qus.wolin.test.c>[uword],#1[uword]
    sec
    sbc #<1
    sbc #>1
; label__wolin_lab_whenLabel_2
__wolin_lab_whenLabel_2:
; allocSP<__wolin_reg4>,#2
    dex
    dex
; allocSP<__wolin_reg5>,#2
    dex
    dex
; letSP(0)<__wolin_reg5>[uword]=#0[ubyte]
    lda #0
    sta 0,x
    lda #0
    sta 0+1,x
; let__wolin_pl_qus_wolin_test_c<pl.qus.wolin.test.c>[uword]=SP(0)<__wolin_reg5>[uword]
    lda 0,x
    lda 0+1,x
; freeSP<__wolin_reg5>,#2
    inx
    inx
; freeSP<__wolin_reg4>,#2
    inx
    inx
; label__wolin_lab_whenEndLabel_0
__wolin_lab_whenEndLabel_0:
; freeSP<__wolin_reg3>,#1
    inx
; freeSP<__wolin_reg2>,#1
    inx
; freeSP<__wolin_reg1>,#1
    inx
; freeSP<__wolin_reg0>,#2
    inx
    inx
; ret
    rts
Posted: Wed Jul 17, 2019 9:20 am
by qus
Today I've finally fixed variable initialization on declaration, so both:
var b = 2
and
var b: ubyte = 2
compile properly:
    dex
    lda #2
    sta 0,x
    lda 0,x
    sta __wolin_pl_qus_wolin_test_b
    inx
(of course it will get optimized in pseudo asm to simple lda/sta without stupid passing of #2 by additional SP reg)
Posted: Wed Jul 17, 2019 1:46 pm
by Druzyek
This is a neat project. I've been following along as you post updates.
How do you plan to do the optimizing? I saw that you were planning some peephole stuff on the first page. Will it be pseudo asm like LLVM?
Posted: Wed Jul 17, 2019 5:00 pm
by qus
Well, from what I see the best-est way would be to do two optimizations - one in pseudo asm, and another one in 6502. Regarding the first - I find interesting cases as I go, for example, consider this simple lambda function:
(a: ubyte, b: ubyte) → a+b
that gets pseudo-compiled to this bloated pseudo-code:
label lambda_function_0
alloc SP<r.temp12>, #1 // for statement a+b
let SP(0)<r.temp12>[ubyte] = SPF(1)<pl.qus.wolin.test.lambda_function_0.a>[ubyte] // simple id from var
alloc SP<r.temp13>, #1 // for right side
let SP(0)<r.temp13>[ubyte] = SPF(0)<pl.qus.wolin.test.lambda_function_0.b>[ubyte] // simple id from var
add SP(1)<r.temp12>[ubyte] = SP(1)<r.temp12>[ubyte], SP(0)<r.temp13>[ubyte] // two sides
free SP<r.temp13>, #1 // for right side, type =ubyte
let SPF(2)<lambdaReturn>[ubyte] = SP(0)<r.temp12>[ubyte] // LAMBDA return assignment
free SP<r.temp12>, #1 // for statement a+b, type = ubyte
free SPF, #2 // free fn arguments and locals for lambda_function_0
ret
1) pl.qus.wolin.test.lambda_function_0.b is put into temp13 and never written, so all occurences of temp13 can be replaced with b + remove assignment:
// KROK1 allokacja temp13
// KROK1 podstawienie temp13
add SP(1)<r.temp12>[ubyte] = SP(1)<r.temp12>[ubyte], **SPF(0)<pl.qus.wolin.test.lambda_function_0.b>[ubyte]** // two sides
// KROK1 deallokacja temp13
ret
2) temp12 is put in lambdaReturn and freed immediately, so I can replace ALL occurences of temp12 with lambdaReturn:
// KROK2 allokacja temp12
KROK2 let SPF(2)<lambdaReturn>[ubyte] = SPF(1)<pl.qus.wolin.test.lambda_function_0.a>[ubyte] // simple id from var
KROK2 add SPF(2)<lambdaReturn>[ubyte] = SPF(2)<lambdaReturn>[ubyte], **SPF(0)<pl.qus.wolin.test.lambda_function_0.b>[ubyte]** // two sides
KROK2 let SPF(2)<lambdaReturn>[ubyte] = SPF(2)<lambdaReturn>[ubyte] // LAMBDA return assignment
// KROK2 deallokacja temp12
ret
3) eliminate identities:
// KROK2 KROK3 tożsamość
ret
4) a is put in lambdaReturn, starting from first write (inclusice) lambdaReturn I can use a instead of lambdaReturn on RHS and remove assignment:
KROK2 KROK4 // podstawienie a do lambdaReturn
KROK2 add SPF(2)<lambdaReturn>[ubyte] = SPF(1)<pl.qus.wolin.test.lambda_function_0.a>[ubyte], **SPF(0)<pl.qus.wolin.test.lambda_function_0.b>[ubyte]** // two sides
ret
5) finally getting what this function really does :D, namely - taking two function stack registers a and b and storing result of their addition in return value on function stack:
ret
(there are more interesting cases in Main.kt, although with Polish comments)
But I feel it will still require some obvious and well known optimizations directly in 6502 code. Is there such assembler in existence?
Posted: Wed Jul 17, 2019 5:57 pm
by Chromatix
An "optimising assembler" is a bit of a contradiction in terms. But the 6502 is so simple a machine that optimisations are either really obvious to compilers (like the ones above) or fairly obtuse.
An earlier example resulted in a lot of consecutive INX instructions. You could replace those with TXA : CLC : ADC #n : TAX, modulo prior knowledge of the state of the C flag and any need to preserve the contents of A.
For a more general approach, I would try to generate code that moves data around "lazily". Only flush a result out of A when something else needs to come into A (or when you need all values consistent in memory). Likewise, only issue a load to A when you need to actually operate on that value, and then load it by the shortest reliable path. Try to perform operations that use a value that is already loaded, rather than those that need to flush something out first. Applying those principles at the code generation stage will reduce the amount of optimisation you need to do later, and may result in a faster and less resource hungry compiler overall.
Some operations can be done without first loading things into a register; INC, DEC, ASL, LSR, ROL, ROR. Chains of these, sometimes with conditional branches, are idiomatic for dealing with types wider than one byte, or for operating on operand pairs of dissimilar width. An example of the latter: adding an 8-bit value to a 32-bit accumulator.
 LDA a+0
 CLC
 ADC b
 STA a+0
 BCC :+
 INC a+1 ; INC doesn't affect C
 BNE :+
 INC a+2
 BNE :+
 INC a+3
: ; sum complete
Make sure these idioms are built into your code generator.
Posted: Thu Jul 18, 2019 6:34 am
by qus
Isn't my example in pseudo-asm indeed "optimising pseud-assembler"? :D Well - if you assume that it's a human who writes the code, it might be contradiction. But if you create a compiler that writes directly to 6502 asm, you can get a lot of places with
inx
dex
or
jsr xxxx
rts
Which are obvious cases for in-assembler optimizations!
Nice one! Thanks! Added to templates:
alloc SP, #?count -> """
    txa
    sec
    sbc #{count}
    tax"""
Although how many dex would it take for the above code to be faster? Note also that I will be suming consecutive "alloc SP / free SP" into one, so unles there's a very complex expression there shound not be a chain of inx/dex like in my examples.
In Kotlin it's rather obvious, as you explicitly declare variables as mutable (var) or immutable (val).
 LDA a+0
 CLC
 ADC b
 STA a+0
 BCC :+
 BNE :+
 INC a+2
 BNE :+
 INC a+3
: ; sum complete
Yep, but that would be done by my pseudo-asm templates.
What I suspect, that even after pseudo-asm optimizations there will be pretty obvious optimization candidates in 6502 code. Besides, an assembler that could properly assemble something like "bne 130" without complaining about range would be a nice thing for compiler-generated code!
Posted: Thu Jul 18, 2019 6:48 am
by Chromatix
One of the hallmarks of an assembler is that it does not second-guess you; there is a one-to-one correspondence between mnemonics specified and instructions issued. If you write INX : DEX, then it assumes that you have a good reason for it - a timing loop, perhaps, or the side-effect of setting flags, or maybe you are even writing a test suite of some kind. Although "optimising assemblers" do exist for some weird platforms, these do things like organising the code in memory, not changing the code itself. (A famous example was an ancient drum-memory computer, where the location of the next instruction was explicitly specified for each one executed; optimisation in this context consisted of placing each instruction under the read heads just when the previous one completed.)
So eliding those cases falls to the responsibility of a peephole optimiser, which can use information from higher levels of the code generation process than an assembler can. It would know, for example, that you are not writing timing loops or CPU test suites, and whether or not the NZ flags resulting from the INX : DEX sequence are subsequently used. Only when those prerequisites are met is deleting the pair a safe optimisation.
Or, preferably, you could use the "lazy evaluation" technique to track the stack pointer evolution as it goes, and only insert instructions to update it just before the stack pointer is actually used. That would relieve that particular burden from the peephole optimiser.
Most 6502 assemblers do support macros, and you can use those to support long branches with clean syntax. You may find these useful.
Posted: Thu Jul 18, 2019 6:51 am
(Crossed in post.)
I did a quick search and there are a few pages of results when you search this site for 'peephole' - nothing jumped out as a fully-functional example, but it's a well known term for this kind of local pattern-recognition. Compilers these days spoil us with their many and varied tactics for optimising - we shouldn't forget that there's plenty of scope for optimisation which falls well short of that but it is still very worthwhile.
Indeed a search for "6502 peephole" looks fruitful too.
So this comment really was too strong:
Posted: Thu Jul 18, 2019 9:25 am
by John West
Almost every 6502 assembler is an optimising assembler.
It isn't quite one-to-one. Consider
    LDA variable
LDA could assemble to AD or A5, depending on the value of variable. The programmer doesn't have to explicitly say which to use in each case. That's a minor optimisation, but it's an important one. We're just so used to it happening that we don't think about it.
I realise that's probably not what you meant: you're saying that every instruction in the source code will produce exactly one instruction in the output. That's true (although macros and conditionals blur the lines a bit). But that's not the only kind of optimisation.
Posted: Thu Jul 18, 2019 9:33 am
by Chromatix
I actually consider that case a misfeature of 6502 assembly - it makes for an ambiguity between ZP and absolute addressing. In most cases that doesn't matter - *if* you are assembling for a 6502, and *if* you are not planning to use self-modifying code.
As soon as you start writing code for a 65816, however, distinguishing between Direct Page (replacing ZP), Absolute, and Long addresses is essential, since the same address can map to three different physical addresses for those three modes (DP is qualified by DPR but not DBR, Absolute is qualified by DBR, Long uses neither). The standard 6502-derived syntax for '816 assembly doesn't give you any help with that, precisely because of this ambiguity introduced by an "optimisation".
Posted: Thu Jul 25, 2019 5:18 pm
by qus
Small update. Since in Kotlin EVERYTHING is an expression, you can do neat tricks. So instead of
fun main() {
    if(d == 0)
        {b=6}
        else
        {b=9}
You'd do:
fun main() {
    b = if(d == 0)
        6
        else
        9
(because expression value == value of last expression in a block)
The same applies to when expression and is now supported in Wolin.
