Page 4 of 5
Re: Learning Verilog or VHDL from some good books/sources?
Posted: Sat Jan 26, 2013 3:16 am
by MichaelM
I moved/renamed the wiki page that BigEd linked to. The page is found here.
Posted: Sun Jan 27, 2013 3:13 pm
Great to see all your wiki updates go by in my RSS reader Michael! I've updated the link in my post.
Posted: Sun Jan 27, 2013 8:55 pm
by MichaelM
How does that work? I'm definitely behind the times.
Posted: Fri Feb 08, 2013 8:03 am
Another seam of resources:
http://eesun.free.fr/DOC/VERILOG/synvlg.html
via
http://people.ece.cornell.edu/land/courses/ece5760/
(includes video lectures)
Posted: Wed Feb 13, 2013 8:11 pm
by ElEctric_EyE
In Verilog:
Is it safe to make the assumption that 'always @ *', 'assign', 'output', and 'wire' all belong to the class of asynchronous signals?
While 'always @(posedge clk)', 'output reg', and 'reg' are meant to be synchronous only signals?
Posted: Wed Feb 13, 2013 9:59 pm
by MichaelM
reg does not mean FF.
Try the following code fragment in a module:
module Reg_Test(
    input  Rst,
    input  Clk,
    input  WE,
    input  OE,
    input  [7:0] DI,
    output reg [7:0] DO
reg   [7:0] Q;
always @(posedge Clk)
begin
    if(Rst)
         Q <= #1 0;
    else if(WE)
         Q <= #1 DI;
end
always @* DO <= (OE ? Q : 0);
endmodule
Notice DO is declared as a reg. Change the definition from reg to wire, and try to synthesize the module.
The lesson is that only a reg implemented within an always @(posedge Clk) block will synthesize to a synchronous element.
Posted: Tue Feb 26, 2013 9:48 pm
by ElEctric_EyE
What is the difference between the following 2 statements?
Assign SRD = SRDO;
and
always @*
     SRD <= SRDO;
Are they not both combinatorial circuits?
Posted: Tue Feb 26, 2013 9:55 pm
by Arlet
In synthesis, these are the same.
In simulation, there will be a difference. In the 'assign' case, SRD is always the same as SRDO. In the second case, SRD only follows SRDO when the latter changes value. So, if SRD is initialized as '0', and SRDO is initialized as '1', and SRDO never changes, SRD will remain '0'.
Posted: Tue Feb 26, 2013 10:12 pm
I might expect a simulation performance difference too, although I haven't checked.
Address Decoding
Posted: Mon Mar 25, 2013 2:32 pm
by ElEctric_EyE
I have another question regarding address decoding. I currently use comparators for a ROM decoder which works:
if ( (cpuAB >= 32'hffff_f000) && (cpuAB <= 32'hffff_ffff) )        //4Kx16 'initialized RAM' ROM address decode
		rom1CS <= 0;
		else rom1CS <= 1;
When I try to do it a different way, it doesn't work and I'm wondering why.
if (cpuAB == 32'b1111_1111_1111_1111_1111_xxxx_xxxx_xxxx)		//4Kx16 'initialized RAM' ROM address decode
		rom1CS <= 0;
		else rom1CS <= 1;
Posted: Mon Mar 25, 2013 2:56 pm
by Arlet
It's because 0 == x or 1 == x result in a false result. If you want to treat 'x' as don't care, you need to use casex/casez.
You could compare cpuAB[31:12] with 20'hFFFFF;
Posted: Mon Mar 25, 2013 3:49 pm
by ElEctric_EyE
Thanks, it was becoming cumbersome to use comparators, especially for decoding only for a few consecutive addresses for I/O ports. I'll work with the casex structure now.
Posted: Mon Mar 25, 2013 9:21 pm
by ElEctric_EyE
I like it much better! Easier on the eyes too.
always @*
	casex(cpuAB [31:0])
		32'b1111_1111_1111_1111_1111_xxxx_xxxx_xxxx:     //$FFFF_F000-$FFFF_FFFF
				rom1CS <= 0;
	default: rom1CS <= 1;
endcase
For us who follow Verilog
Posted: Mon Mar 25, 2013 11:58 pm
by ElEctric_EyE
I just got home and tried it in the project and it doesn't fit.
Seems like it's best to have 2 comparators for linear memory addressing (beginning and end, code @ bottom) Chip Select signals vs. all the 'x's and the MUX's (maybe for a non-linear addressing, code @ below).
This is what I had for the MUX's (slow):
module A_D ( input cpuWE,
					  input [31:0] cpuAB,
					  input [15:0] ZPP,				//from CPU, zeropage pointer
					  input [15:0] SPP,				//from CPU, stackpage pointer
					  output reg ram1CS = 0,
					  output reg ram1WE = 0,		//pre-init to '0', not selected
					  output reg ram2CS = 0,
					  output reg ram2WE = 0,		//pre-init to '0', not selected
					  output reg rom1CS = 0,		//pre-init to '0', selected
					  output reg vramCS = 0,
					  output reg rndgCS = 0,
					  output reg cntrCS = 0
// address decoding for internal blockRAMs
always @* begin
	ram1WE <= ( !ram1CS && cpuWE );
	ram2WE <= ( !ram2CS && cpuWE );
end
always @*
	casex(cpuAB [31:0])
				rom1CS <= 0;
endcase
always @*
	casex(cpuAB [31:0])
		{SPP,16'b1111_1100_xxxx_xxxx}:
				ram2CS <= 0;
	default: ram2CS <= 1;
endcase
always @*
	casex(cpuAB [31:0])
		{ZPP,16'b0000_00xx_xxxx_xxxx}:
				ram1CS <= 0;
	default: ram1CS <= 1;
endcase
always @*
	casex(cpuAB [31:0])
		32'b0000_0010_xxxx_xxxx_0000_0010_xxxx_xxxx:
				vramCS <= 1;
	default: vramCS <= 0;
endcase
always @*
	casex(cpuAB [31:0])
		32'b1100_0000_0000_0000_0000_0000_0000_000x:
				cntrCS <= 1;
	default: cntrCS <= 0;
endcase
always @*
	casex(cpuAB [31:0])
		32'b1010_0000_0000_0000_0000_0000_0000_0000:
				rndgCS <= 1;
	default: rndgCS <= 0;
endcase
endmodule
This is what I have reverted back too:
					  input [31:0] cpuAB,
					  output reg rom1CS = 0,		//pre-init to '0', not selected
always @* begin
	if ( (cpuAB >= {ZPP,16'h0000}) && cpuAB <= ({ZPP,16'h03ff}) )		//1Kx16 zeropage RAM address decode w/ZPP reg as the MSB pointer
		ram1CS <= 0;
		else ram1CS <= 1;
	if ( (cpuAB >= {SPP,16'hfc00}) && cpuAB <= ({SPP,16'hffff}) )		//1Kx16 stackpage RAM address decode w/SPP reg as the MSB pointer
		ram2CS <= 0;
		else ram2CS <= 1;
		rom1CS <= 0;
		else rom1CS <= 1;
	if (cpuAB >= 32'h0000_0000 && cpuAB <= 32'h0280_01e0) 				//video space
		vramCS <= 1;
		else vramCS <= 0;
	if (cpuAB == 32'ha000_0000)													//random number generator, read only
		rndgCS <= 1;
		else rndgCS <= 0;
	if (cpuAB >= 32'hc000_0000 && cpuAB <= 32'hc0000_0001)				//cycle counter
		cntrCS <= 1;
		else cntrCS <= 0;
end
endmodule
Posted: Tue Mar 26, 2013 12:23 am
by ElEctric_EyE
The bottom still failed, using smartxplorer, with a score of '14', very close to '0'. One usually sees values in the 'thousands' if there is no hope...
So I am accommodating the logic, especially the video space and cycle counter decoding. These would take formulas down to the last bit I would think. I can afford for those resources not to be eaten up!
This passes. My project is nearing max for the XC6SLX9-144:
...if (cpuAB >= 32'h0000_0000 && cpuAB <= 32'h03ff_03ff) 				//video space, 1024x1024
		vramCS <= 1;
		else vramCS <= 0;
		rndgCS <= 1;
		else rndgCS <= 0;
	if (cpuAB >= 32'hc000_0000 && cpuAB <= 32'hcfff_ffff)				//cycle counter
		cntrCS <= 1;
		else cntrCS <= 0;
end...
