Page 4 of 15
Re: Breaking 6502 apart
Posted: Thu Jul 12, 2012 12:42 pm
by org
I updated my PLA utility :
http://ogamespec.com/6502/decoder.htm
Now you can input raw bits from PLA lines and get IR mask as well as T-cycle on output.
6502.org wrote:
msb bit in sequence is equal to bottom PLA line (t1).
A
000101100000100100000
000000010110001000100
000000011010001001000
010100011001100100000
010101011010100100000
010110000001100100000
B
000000100010000001000
000001000000100010000
000000010101001001000
010101011001100010000
010110011001100010000
011010000001100100000
000101000000100010000
010101011010100010000
011001000000100010000
000110011001100010000
001010011001100100000
011001011010100010000
000100011001100100000
011001100000100100000
011001000001100100000
C
011001010101010100000
000101010101010100001
010100011001010100000
001010010101010100010
001000011001010100100
000110010101010100001
001010000000010010000
000000000000000001000
010110000000011000000
000010101001010100000
000000101001000001000
010101000000011000000
000000000100000001000
010000000000000000000
000000010001010101000
000000000001010100100
D
000001010101010100010
000110010101010100010
000000010101001000100
000000010110001000010
000000010110001001000
K
000000011001010100000 ->
010010011010100100000
000001000000000000000
000000101001000000100
000000100101000001000
000000010100001000001
0000000010100?0000010 ? is actually 0, but strange.. supposed to be vias there
000000000000010000000
001001011010100100000
00000001100000000 <-
Posted: Fri Jul 13, 2012 9:29 am
by org
Completed random logic color schematics.
Also I choosed another strategy to reverse this whole crap. I start from T0 only PLA lines, then continue on T1 lines only and so on.
Posted: Fri Jul 13, 2012 7:21 pm
by org
Completed ALU color map.
Posted: Fri Jul 13, 2012 7:35 pm
quick progress! But you missed a horizontal run of poly - see pic.
Posted: Fri Jul 13, 2012 7:52 pm
by org
Ehhehe, damn puzzle :mrgreen:
I'll fix it in transistor level schematics )
EDIT: you don't need this poly line, it somes from from address latch )
EDIT2: ooops, or maybe need )
Posted: Sat Jul 14, 2012 11:18 am
by org
Todays speccy: ALU bit0
Pieces from left-to-right: B INPUT (BI), A INPUT (AI), LOGIC, ARITHMETIC, DECIMAL ADDER, ADDER HOLD REG (ADD), DECIMAL ADJUST, ACCUMULATOR (AC).
Posted: Sat Jul 14, 2012 11:36 am
Decimal adjust is a big random tangle! It's also not organised by bit slices. Joyful!
Posted: Sat Jul 14, 2012 11:38 am
by org
Its like tentacles, if you know what I mean :mrgreen: :mrgreen: :mrgreen:
Posted: Mon Jul 16, 2012 9:27 am
by org
Todays speccy : PLA lines decoded!
A
01: 000101100000100100000   100XX100 TX     STY
02: 000000010110001000100   XXX100X1 T3     OP ind, Y
03: 000000011010001001000   XXX110X1 T2     OP abs, Y
04: 010100011001100100000   1X001000 T0     DEY INY
05: 010101011010100100000   10011000 T0     TYA
06: 010110000001100100000   1100XX00 T0     CPY INY
B
01: 000000100010000001000   XXX1X1XX T2     OP zpg, X/Y & OP abs, X/Y
02: 000001000000100010000   10XXXX1X TX     LDX STX A<->X S<->X
03: 000000010101001001000   XXX000X1 T2     OP ind, X
04: 010101011001100010000   1000101X T0     TXA
05: 010110011001100010000   1100101X T0     DEX
06: 011010000001100100000   1110XX00 T0     CPX INX
07: 000101000000100010000   100XXX1X TX     STX TXA TXS
08: 010101011010100010000   1001101X T0     TXS
09: 011001000000100010000   101XXX1X T0     LDX TAX TSX
10: 000110011001100010000   1100101X TX     DEX
11: 001010011001100100000   11101000 TX     INX
12: 011001011010100010000   1011101X T0     TSX
13: 000100011001100100000   1X001000 TX     DEY INY
14: 011001100000100100000   101XX100 T0     LDY
15: 011001000001100100000   1010XX00 T0     LDY TAY
C
01: 011001010101010100000   00100000 T0     JSR
02: 000101010101010100001   00000000 T5     BRK
03: 010100011001010100000   0X001000 T0     Push
04: 001010010101010100010   01100000 T4     RTS
05: 001000011001010100100   0X101000 T3     Pull
06: 000110010101010100001   01000000 T5     RTI
07: 001010000000010010000   011XXX1X TX     ROR
08: 000000000000000001000   XXXXXXXX T2     T2 ANY
09: 010110000000011000000   010XXXX1 T0     EOR
10: 000010101001010100000   01X01100 TX     JMP
11: 000000101001000001000   XXX011XX T2     RIGHT R ODD
12: 010101000000011000000   000XXXX1 T0     ORA
13: 000000000100000001000   XXXX0XXX T2     LEFT ALL
14: 010000000000000000000   XXXXXXXX T0     T0 ANY
15: 000000010001010101000   0XX0X000 T2     BRK JSR RTI RTS Push/pull
16: 000000000001010100100   0XX0XX00 T3     BRK JSR RTI RTS Push/pull + BIT JMP
D
01: 000001010101010100010   00X00000 T4     BRK JSR
02: 000110010101010100010   01000000 T4     RTI
03: 000000010101001000100   XXX000X1 T3     OP X, ind
04: 000000010110001000010   XXX100X1 T4     OP ind, Y
05: 000000010110001001000   XXX100X1 T2     OP ind, Y
06: 000000001010000000100   XXX11XXX T3     RIGHT ODD
07: 001000011001010100000   0X101000 TX     Pull
08: 001010000000100010000   111XXX1X TX     INC NOP
09: 000000010101001000010   XXX000X1 T4     OP X, ind
10: 000000010110001000100   XXX100X1 T3     OP ind, Y
11: 000010010101010100000   01X00000 TX     RTI RTS
12: 001001010101010101000   00100000 T2     JSR
13: 010010000001100100000   11X0XX00 T0     CPY CPX INY INX
14: 010110000000101000000   110XXXX1 T0     CMP
15: 011010000000101000000   111XXXX1 T0     SBC
16: 011010000000001000000   X11XXXX1 T0     ADC SBC
17: 001001000000010010000   001XXX1X TX     ROL
E
01: 000010101001010100100   01X01100 T3     JMP
02: 000001000000010010000   00XXXX1X TX     ASL ROL
03: 001001010101010100001   00100000 T5     JSR
04: 000000010001010101000   0XX0X000 T2     BRK JSR RTI RTS Push/pull
06: 100000000000011000000   0XXXXXX1 T1     UPPER ODD
07: 101010000000001000000   X11XXXX1 T1     ADC SBC
08: 100000011001010010000   0XX0101X T1     ASL ROL LSR ROR
09: 010101011001100010000   1000101X T0     TXA
10: 011010011001010100000   01101000 T0     PLA
11: 011001000000101000000   101XXXX1 T0     LDA
12: 010000000000001000000   XXXXXXX1 T0     ALL ODD
13: 011001011001100100000   10101000 T0     TAY
14: 010000011001010010000   0XX0101X T0     ASL ROL LSR ROR
15: 011001011001100010000   1010101X T0     TAX
16: 011001100001010100000   0010X100 T0     BIT
17: 011001000000011000000   001XXXX1 T0     AND
18: 000000001010000000010   XXX11XXX T4     RIGHT ODD
19: 000000010110001000001   XXX100X1 T5     OP ind, Y
F
01: 010000010110000100000   XXX10000 T0 <-  Branch + BranchReady line
02: 000110011001010101000   01001000 T2     PHA
03: 010010011001010010000   01X0101X T0     LSR ROR
04: 000010000000010010000   01XXXX1X TX     LSR ROR
05: 000101010101010101000   00000000 T2     BRK
06: 001001010101010100100   00100000 T3     JSR
07: 000101000000101000000   100XXXX1 TX     STA
08: 000000010110000101000   XXX10000 T2     Branch
09: 000000100100000001000   XXXX01XX T2     zero page
10: 000000010100001001000   XXXX00X1 T2     ALU indirect
11: 000000001000000001000   XXXX1XXX T2     RIGHT ALL
12: 001010010101010100001   01100000 T5     RTS
13: 000000000000000000010   XXXXXXXX T4     T4 ANY
14: 000000000000000000100   XXXXXXXX T3     T3 ANY
15: 010100010101010100000   0X000000 T0     BRK RTI
16: 010010101001010100000   01X01100 T0     JMP
17: 000000010101001000001   XXX000X1 T5     OP X, ind
18: 000000001000000000100   XXXX1XXX T3     RIGHT ALL
G
01: 000000010110001000010   XXX100X1 T4     OP ind, Y
02: 000000001010000000100   XXX11XXX T3     RIGHT ODD
03: 000000010110000100100   XXX10000 T3     Branch
04: 000100010101010100000   0X000000 TX     BRK RTI
05: 001001010101010100000   00100000 TX     JSR
06: 000010101001010100000   01X01100 TX     JMP
07: 000000011001010100000   0XX01000 TX     Push/pull
08: 000101000000100000000   100XXXXX TX     80-9F
09: 000101010101010100010   00000000 T4     BRK
10: 000101011001010101000   00001000 T2     PHP
11: 000100011001010101000   0X001000 T2     Push
12: 000010101001010100010   01X01100 T4     JMP
13: 000010010101010100001   01X00000 T5     RTI RTS
14: 001001010101010100001   00100000 T5     JSR
H
01: 000110101001010101000   01001100 T2     JMP
02: 001000011001010100100   0X101000 T3     Pull
03: 000010000000000010000   X1XXXX1X TX     LSR ROR DEC INC DEX NOP (4x4 bottom right)
04: 000001000000010010000   00XXXX1X TX     ASL ROL
05: 010010011010010100000   01X11000 T0     CLI SEI
06: 101001100001010100000   0010X100 T1     BIT
07: 010001011010010100000   00X11000 T0     CLC SEC
08: 000000100110000000100   XXX101XX T3     OP zpg, X
09: 101010000000001000000   X11XXXX1 T1     ADC SBC
10: 011001100001010100000   0010X100 T0     BIT
11: 011001011001010100000   00101000 T0     PLP
12: 000110010101010100010   01000000 T4     RTI
13: 100110000000101000000   110XXXX1 T1     CMP
14: 100010101001100100000   11X01100 T1     CPY CPX
15: 100001011001010010000   00X0101X T1     ASL ROL
16: 100010000101100100000   11X00X00 T1     CPY CPX
K
KX: 000000011001010100000   0XX01000 TX     Not actually line. Controls K09 to except push/pull opcodes --->
01: 010010011010100100000   11X11000 T0     CLD SED
02: 000001000000000000000   X0XXXXXX TX     00-3F 80-BF
03: 000000101001000000100   XXX011XX T3     RIGHT R EVEN
04: 000000100101000001000   XXX001XX T2     LEFT R EVEN
05: 000000010100001000001   XXXX00X1 T5     ALU indirect
06: 0000000010100?0000010   XXX11XXX T4     RIGHT ODD (? is actually 0, but strange.. 0XX11XXX T4 if supposed to be vias there)
07: 000000000000010000000   0XXXXXXX TX     UPPER ALL
08: 001001011010100100000   10111000 TX     CLV
09: 000000011000000......   XXXX10X0 TX     All flags + DEY TAY INY INX - 0XX01000 <--- controlled by KX
Explanations:
A-K - line groups
01-09 - line number
000000001000000001000 - PLA bit assignment
X1XXXX1X TX - IR condition to fire line + T-step (T0-T5, TX mean "any")
+ short description which opcodes are affected by this line. "OP" mean any opcode.
PLA lines sorted by T-step:
A04: 010100011001100100000   1X001000 T0     DEY INY
A05: 010101011010100100000   10011000 T0     TYA
A06: 010110000001100100000   1100XX00 T0     CPY INY
B04: 010101011001100010000   1000101X T0     TXA
B05: 010110011001100010000   1100101X T0     DEX
B06: 011010000001100100000   1110XX00 T0     CPX INX
B08: 010101011010100010000   1001101X T0     TXS
B09: 011001000000100010000   101XXX1X T0     LDX TAX TSX
B12: 011001011010100010000   1011101X T0     TSX
B14: 011001100000100100000   101XX100 T0     LDY
B15: 011001000001100100000   1010XX00 T0     LDY TAY
C01: 011001010101010100000   00100000 T0     JSR
C03: 010100011001010100000   0X001000 T0     Push
C09: 010110000000011000000   010XXXX1 T0     EOR
C12: 010101000000011000000   000XXXX1 T0     ORA
C14: 010000000000000000000   XXXXXXXX T0     T0 ANY
D13: 010010000001100100000   11X0XX00 T0     CPY CPX INY INX
D14: 010110000000101000000   110XXXX1 T0     CMP
D15: 011010000000101000000   111XXXX1 T0     SBC
D16: 011010000000001000000   X11XXXX1 T0     ADC SBC
E05: 010101011010100100000   10011000 T0     TYA
E09: 010101011001100010000   1000101X T0     TXA
E10: 011010011001010100000   01101000 T0     PLA
E11: 011001000000101000000   101XXXX1 T0     LDA
E12: 010000000000001000000   XXXXXXX1 T0     ALL ODD
E13: 011001011001100100000   10101000 T0     TAY
E14: 010000011001010010000   0XX0101X T0     ASL ROL LSR ROR
E15: 011001011001100010000   1010101X T0     TAX
E16: 011001100001010100000   0010X100 T0     BIT
E17: 011001000000011000000   001XXXX1 T0     AND
F01: 010000010110000100000   XXX10000 T0 <-  Branch + BranchReady line
F03: 010010011001010010000   01X0101X T0     LSR ROR
F15: 010100010101010100000   0X000000 T0     BRK RTI
F16: 010010101001010100000   01X01100 T0     JMP
H05: 010010011010010100000   01X11000 T0     CLI SEI
H07: 010001011010010100000   00X11000 T0     CLC SEC
H10: 011001100001010100000   0010X100 T0     BIT
H11: 011001011001010100000   00101000 T0     PLP
K01: 010010011010100100000   11X11000 T0     CLD SED
E06: 100000000000011000000   0XXXXXX1 T1     UPPER ODD
E07: 101010000000001000000   X11XXXX1 T1     ADC SBC
E08: 100000011001010010000   0XX0101X T1     ASL ROL LSR ROR
H06: 101001100001010100000   0010X100 T1     BIT
H09: 101010000000001000000   X11XXXX1 T1     ADC SBC
H13: 100110000000101000000   110XXXX1 T1     CMP
H14: 100010101001100100000   11X01100 T1     CPY CPX
H15: 100001011001010010000   00X0101X T1     ASL ROL
H16: 100010000101100100000   11X00X00 T1     CPY CPX
A03: 000000011010001001000   XXX110X1 T2     OP abs, Y
B01: 000000100010000001000   XXX1X1XX T2     OP zpg, X/Y & OP abs, X/Y
B03: 000000010101001001000   XXX000X1 T2     OP ind, X
C08: 000000000000000001000   XXXXXXXX T2     T2 ANY
C11: 000000101001000001000   XXX011XX T2     RIGHT R ODD
C13: 000000000100000001000   XXXX0XXX T2     LEFT ALL
C15: 000000010001010101000   0XX0X000 T2     BRK JSR RTI RTS Push/pull
D05: 000000010110001001000   XXX100X1 T2     OP ind, Y
D12: 001001010101010101000   00100000 T2     JSR
E04: 000000010001010101000   0XX0X000 T2     BRK JSR RTI RTS Push/pull
F02: 000110011001010101000   01001000 T2     PHA
F05: 000101010101010101000   00000000 T2     BRK
F08: 000000010110000101000   XXX10000 T2     Branch
F09: 000000100100000001000   XXXX01XX T2     zero page
F10: 000000010100001001000   XXXX00X1 T2     ALU indirect
F11: 000000001000000001000   XXXX1XXX T2     RIGHT ALL
G10: 000101011001010101000   00001000 T2     PHP
G11: 000100011001010101000   0X001000 T2     Push
H01: 000110101001010101000   01001100 T2     JMP
K04: 000000100101000001000   XXX001XX T2     LEFT R EVEN
A02: 000000010110001000100   XXX100X1 T3     OP ind, Y
C05: 001000011001010100100   0X101000 T3     Pull
C16: 000000000001010100100   0XX0XX00 T3     BRK JSR RTI RTS Push/pull + BIT JMP
D03: 000000010101001000100   XXX000X1 T3     OP X, ind
D06: 000000001010000000100   XXX11XXX T3     RIGHT ODD
D10: 000000010110001000100   XXX100X1 T3     OP ind, Y
E01: 000010101001010100100   01X01100 T3     JMP
F06: 001001010101010100100   00100000 T3     JSR
F14: 000000000000000000100   XXXXXXXX T3     T3 ANY
F18: 000000001000000000100   XXXX1XXX T3     RIGHT ALL
G02: 000000001010000000100   XXX11XXX T3     RIGHT ODD
G03: 000000010110000100100   XXX10000 T3     Branch
H02: 001000011001010100100   0X101000 T3     Pull
H08: 000000100110000000100   XXX101XX T3     OP zpg, X
K03: 000000101001000000100   XXX011XX T3     RIGHT R EVEN
C04: 001010010101010100010   01100000 T4     RTS
D01: 000001010101010100010   00X00000 T4     BRK JSR
D02: 000110010101010100010   01000000 T4     RTI
D04: 000000010110001000010   XXX100X1 T4     OP ind, Y
D09: 000000010101001000010   XXX000X1 T4     OP X, ind
E18: 000000001010000000010   XXX11XXX T4     RIGHT ODD
F13: 000000000000000000010   XXXXXXXX T4     T4 ANY
G01: 000000010110001000010   XXX100X1 T4     OP ind, Y
G09: 000101010101010100010   00000000 T4     BRK
G12: 000010101001010100010   01X01100 T4     JMP
H12: 000110010101010100010   01000000 T4     RTI
K06: 0000000010100?0000010   XXX11XXX T4     RIGHT ODD (? is actually 0, but strange.. 0XX11XXX T4 if supposed to be vias there)
C02: 000101010101010100001   00000000 T5     BRK
C06: 000110010101010100001   01000000 T5     RTI
E03: 001001010101010100001   00100000 T5     JSR
E19: 000000010110001000001   XXX100X1 T5     OP ind, Y
F12: 001010010101010100001   01100000 T5     RTS
F17: 000000010101001000001   XXX000X1 T5     OP X, ind
G13: 000010010101010100001   01X00000 T5     RTI RTS
G14: 001001010101010100001   00100000 T5     JSR
K05: 000000010100001000001   XXXX00X1 T5     ALU indirect
A01: 000101100000100100000   100XX100 TX     STY
B02: 000001000000100010000   10XXXX1X TX     LDX STX A<->X S<->X
B07: 000101000000100010000   100XXX1X TX     STX TXA TXS
B10: 000110011001100010000   1100101X TX     DEX
B11: 001010011001100100000   11101000 TX     INX
B13: 000100011001100100000   1X001000 TX     DEY INY
C07: 001010000000010010000   011XXX1X TX     ROR
C10: 000010101001010100000   01X01100 TX     JMP
D07: 001000011001010100000   0X101000 TX     Pull
D08: 001010000000100010000   111XXX1X TX     INC NOP
D11: 000010010101010100000   01X00000 TX     RTI RTS
D17: 001001000000010010000   001XXX1X TX     ROL
E02: 000001000000010010000   00XXXX1X TX     ASL ROL
F04: 000010000000010010000   01XXXX1X TX     LSR ROR
F07: 000101000000101000000   100XXXX1 TX     STA
G04: 000100010101010100000   0X000000 TX     BRK RTI
G05: 001001010101010100000   00100000 TX     JSR
G06: 000010101001010100000   01X01100 TX     JMP
G07: 000000011001010100000   0XX01000 TX     Push/pull
G08: 000101000000100000000   100XXXXX TX     80-9F
H03: 000010000000000010000   X1XXXX1X TX     LSR ROR DEC INC DEX NOP (4x4 bottom right)
H04: 000001000000010010000   00XXXX1X TX     ASL ROL
K02: 000001000000000000000   X0XXXXXX TX     00-3F 80-BF
K07: 000000000000010000000   0XXXXXXX TX     UPPER ALL
K08: 001001011010100100000   10111000 TX     CLV
K09: 000000011000000......   XXXX10X0 TX     All flags + DEY TAY INY INX - 0XX01000 <--- controlled by KX
Posted: Tue Jul 17, 2012 7:10 pm
by org
More progress on ALU.
Posted: Wed Jul 18, 2012 2:25 pm
by org
More progress on random logic.
I recognized branch processing logic, some flags and their connections with internal data bus.
Missing parts are matter of time.
Posted: Thu Jul 19, 2012 1:38 pm
by org
Almost completed random logic
Posted: Thu Jul 19, 2012 5:27 pm
Although it seems a tangle, it is much easier to read than the layout!
I like the DBZ and Z_FLAG logic - very simple and fast!
Posted: Thu Jul 19, 2012 8:51 pm
by org
Todays evening progess on ALU :D
Decimal subtract adjust and accumulator are still missing.
DAA and DSA are really nightmare at first look.....
ALU input drivers :
/DB/ADD (inverted DB -> B input)
DB/ADD (DB -> B input)
ADL/ADD (ADL -> B input)
SB/ADD (SB -> A input)
0/ADD (0 -> A input)
ORS (logical or)
SRS (shift right)
ANDS (logical and)
EORS (logical xor)
I/ADDC (carry in)
SUMS (arithmetic sum)
DAA (decimal addition adjust)
ADD/SB7 (adder result -> SB7)
ADD/SB06 (adder result -> SB0-6)
ADD/ADL (adder result -> ADL)
DSA (decimal subtract adjust)
SB/DB (SB <-> DB)
SB/AC (SB -> accumulator)
AC/SB (accumulator -> SB)
AC/DB (accumulator -> DB)
SB/ADH (SB -> ADH)
0/ADH0 (0 -> ADH0)
0/ADH17 (0 -> ADH1-7)
ALU outputs :
AVR (overflow out)
ACR (carry out)
Making it nice "blackbox" for educational purposes :D
Posted: Fri Jul 20, 2012 2:42 pm
by org
Transistor level schematics of random logic is complete. Now need to trace interconnections.
I already recognized ready control, timing generation logic and some flags.
http://postimage.org/image/cnrz9ndjp/full/
