I have got the Sym development system running again and begun preparing the sources for release. But before the source itself I will release this patch for RAE to give it access to the disk services of symbiosys. It is a standard RAE disk patch to enable the LO, EN and DC commands, I used the patch in RAE NOTES Issue No. 1.
This really does fully integrate the development environment so far as to be able to write the operating system itself.
http://b5.net/sym1/raepatch
Upload the raepatch.bin.ptape to the sym1 and make the executable with this command
# store * raepatch 7d00 274
You must cold start RAE the first time with a mon command to drop out to supermon then .g b000, (I'll rig a symbiosys command to do this procedure next)
Then return to symbiosys with a .g 9000 then run
# raepatch
will patch in the commands and warm entry you into RAE.
set the memory model in RAE to assemble the kernel with
>set $2000 $5ffc $1000 $1ffc
>clear
you will now be able to drop out of RAE with the DC command with no parameters. Return to RAE with the command
# rae
With DC you can also put any symbiosys command line as a parameter and it will be passed to the kernel for execution from within RAE.
The raepatch source code has comments to explain it's use.
I'll post the code here so you can check it out. As usual, not well commented.
0020 ; RAE patch for Symbiosys V
0030 ; Based on the RAE patch published in RAE NOTES Issue 1
0040 ;
0050 ; By House Harris. XI June MMXII
0060 ; Author: Michael Brown, symbiosys@b5.net
0070 ;
0080 ; resides at $7d00-$7f74, patches into RAE to provide
0090 ; ENTER, LOAD and DC commands for use within RAE to
0100 ; call symbiosys disk file services.
0110 ;
0120 .os
0130 ;
0140 RAE.tpres .de $d3 ;present end of RAE text
0150 diskc.vec .de $ec ;disck command vector
0160 diski.flag .de $ee ;RAE tape/disk input flag
0170 disko.flag .de $ef ;RAE tape/disk output flag
0180 disko.vec .de $f0 ;RAE disk output vector
0190 diski.vec .de $f2 ;RAE disk input vector
0200 RAE.txtst .de $100 ;start of RAE text area
0210 RAE.txten .de $102 ;end of RAE text area
0220 RAE.crt .de $135 ;RAE input buffer
0230 ;
0240 usrent .de $8035
0250 nibasc .de $8309
0260 ascnib .de $8275
0270 access .de $8b86
0280 outbyte .de $82fa
0290 outchar .de $8a47
0300 crlf .de $834d
0310 space .de $8342
0320 tout .de $8aa0
0330 intchr .de $8a58
0340 ;
0350 outvec .de $a663
0360 invec .de $a660
0370 ;
0380 RAE.cold .de $b000 ;RAE cold start
0390 RAE.warm .de $b003
0400 RAE.hot .de $b05e ;RAE warm start no message
0410 RAE.error .de $b00e ;RAE error subroutine vector
0420 ;
0430 zflag .de $eb
0440 zargc .de $4f
0450 zargv[0] .de $50
0460 filenum .de $39c
0470 xfer.bytes .de $398
0480 xfer.addr .de $396
0490 ;
0500 pattern .de $350
0510 ivmp.addr .de $37c
0520 osflags .de $39f
0530 OpenedFile .de $3a0
0540 monst.ctab .de $3fc
0550 ilba0 .de $390
0560 ilba8 .de $391
0570 ilba16 .de $392
0580 ilba24 .de $393
0590 dta.ptr .de $394
0600 ;
0610 call.bdos .de $9006
0620 disk.init .de $00
0630 writebytes .de $06
0640 readbytes .de $08
0650 writefile .de $0a
0660 readfile .de $0c
0670 load.sect .de $02
0680 execfile .de $16
0690 ;
0700 lib.puts .de $9013
0710 proc.flist .de $9031
0720 dir.prnt .de $9025
0730 lib.parse .de $9016
0740 proc.cmnd .de $9019
0750 symbiosys .de $9003
0760 istr.prnt .de $9028
0770 ;
0780 sectr.buff .de $200
0790 line.bvff .de $300
0800 dirnt.buff .de $500
0810 ;
0820 file.color .de $00
0830 file.name .de file.color+1
0840 file.ver .de file.name+30
0850 file.size .de file.ver+1
0860 file.ctime .de file.size+8
0870 file.mtime .de file.ctime+8
0880 file.atrib .de file.mtime+8
0890 file.load .de file.atrib+4
0900 file.loc .de file.load+4
0910 ;
0920 of.bvffer .de $3a0
0930 ;
0940 of.lba .de $00
0950 of.size .de of.lba+3
0960 of.flptr .de of.size+2
0970 of.flags .de of.flptr+2
0980 ;
0990 of.RAE .de $3ef
1000 ;
1010 ;
1020 showprgrs .de %10000000
1030 readfrwrd .de %00000001
1040 verifymode .de %00000010
1050 ;
1060 del .de $7f
1070 bs .de $08
1080 ;
1090 !!!sb .md (oldchar newchar)
1100 cmp #oldchar
1110 bne =+3
1120 lda #newchar
1130 .me
1140 ;
1150 !!!fill .md (value dest bytes)
1160 lda #value
1170 ldx #bytes
1180 loop... dex
1190 sta dest,x
1200 bne loop...
1210 .me
1220 ;
1230 !!!memcpy .md (source dest bytes)
1240 ldx #bytes
1250 loop... lda source-1,x
1260 sta dest-1,x
1270 dex
1280 bne loop...
1290 .me
1300 ;
1310 !!!parsarg .md (locvs.line)
1320 lda #l,locvs.line
1330 ldy #h,locvs.line
1340 jsr lib.parse
1350 .me
1360 ;
1370 !!!proccmd .md (monst.cmnds)
1380 lda monst.cmnds
1390 ldy monst.cmnds+1
1400 jsr proc.cmnd
1410 .me
1420 ;
1430 !!!exec .md (zargv)
1440 lda *zargv
1450 ldy *zargv+1
1460 ldx #execfile
1470 jsr call.bdos
1480 .me
1490 ;
1500 !!!setosfl .md (mask)
1510 lda #mask
1520 ora osflags
1530 sta osflags
1540 .me
1550 ;
1560 !!!bdos .md (funct)
1570 ldx #funct
1580 jsr call.bdos
1590 .me
1600 ;
1610 !!!puts .md (outstr)
1620 lda #l,outstr
1630 ldy #h,outstr
1640 jsr lib.puts
1650 .me
1660 ;
1670 !!!proc .md (function)
1680 lda #l,function
1690 sta ivmp.addr
1700 lda #h,function
1710 sta ivmp.addr+1
1720 jsr proc.flist
1730 .me
1740 ;
1750 !!!xfrdbl .md (src dst)
1760 lda src
1770 sta dst
1780 lda src+1
1790 sta dst+1
1800 .me
1810 ;
1820 !!!stdbl .md (src dst)
1830 lda #l,src
1840 sta dst
1850 lda #h,src
1860 sta dst+1
1870 .me
1880 ;
1890 !!!diag .md (byte)
1900 php
1910 pha
1920 lda byte
1930 jsr outbyte
1940 pla
1950 plp
1960 .me
1970 ;
1980 !!!gethex .md (byte)
1990 lda RAE.crt,y
2000 jsr ascnib
2010 bcc ...skip
2020 ldx #$48
2030 jmp (RAE.error)
2040 ...skip asl a
2050 asl a
2060 asl a
2070 asl a
2080 sta byte
2090 iny
2100 lda RAE.crt,y
2110 jsr ascnib
2120 bcc ...skip2
2130 ldx #$49
2140 jmp (RAE.error)
2150 ...skip2 and #%00001111
2160 ora byte
2170 sta byte
2180 .me
2190 ;
2200 !!!adddbl .md (first second)
2210 pha
2220 clc
2230 lda first
2240 adc second
2250 sta first
2260 lda first+1
2270 adc second+1
2280 sta first+1
2290 pla
2300 .me
2310 ;
2320 !!!subdbl .md (first second)
2330 pha
2340 sec
2350 lda first
2360 sbc second
2370 sta first
2380 lda first+1
2390 sbc second+1
2400 sta first+1
2410 pla
2420 .me
2430 ;
2440 !!!cmpdbl .md (first second temp)
2450 sec
2460 lda first
2470 sbc second
2480 sta temp
2490 lda first+1
2500 sbc second+1
2510 ora temp
2520 .me
2530 ;
2540 ; .ba $f000
2550 .ba $7d00
2560 ; .ba $6000
2570 patch stdbl (load.file diski.vec)
2580 stdbl (save.file disko.vec)
2590 stdbl (disk.cmnd diskc.vec)
2600 stdbl (crtin invec+1)
2610 ; stdbl (crtout outvec+1)
2620 jmp RAE.warm
2630 ;
2640 ; load.file is the entry point for the LOAD command
2650 ; this version requires 1 parameter, a symbiosys filename
2660 ; it will load the file if it exists with the ':' attribute
2670 ; in the current directory
2680 ; An overflow error (31) will occur if the RAE text area
2690 ; is overrun.
2700 ; A '+' preceeding the filename will append the file to the end
2710 ; of the current file
2720 ;
2730 ;
2740 load.file cpy #$50 ;if y=50 filename is missing
2750 bne have.lparm ;y points to filename params
2760 ldx #$30
2770 jmp (RAE.error) ;error 30=no filename parameters
2780 ;
2790 have.lparm ldx #0
2800 stx *diski.flag ;re-enable tape input
2810 stx *zflag
2820 lda RAE.crt,y
2830 cmp #'+ ;if first char is +
2840 bne not.append
2850 iny
2860 sta *zflag
2870 not.append ldx #$ff
2880 cpyloop inx
2890 lda RAE.crt,y
2900 iny
2910 sta pattern,x
2920 cmp #$20
2930 bne cpyloop
2940 lda #0
2950 sta pattern,x
2960 sta osflags
2970 setosfl (verifymode)
2980 proc (fetchload)
2990 bcs overflow
3000 jmp uniexit
3010 overflow ldx #$31
3020 jmp (RAE.error) ;error 31=text area overflow
3030 ;
3040 fetchload pla
3050 pla
3060 ;
3070 lda *zflag
3080 cmp #'+
3090 beq fldappend
3100 jsr falloc
3110 sta of.RAE
3120 tax
3130 lda sectr.buff+file.size
3140 sta of.bvffer+of.size,x
3150 lda sectr.buff+file.size+1
3160 sta of.bvffer+of.size+1,x
3170 ;
3180 fldappend ldx #0
3190 buffloop3 lda sectr.buff,x
3200 sta dirnt.buff,x
3210 inx
3220 bne buffloop3
3230 xfrdbl (RAE.txtst dirnt.buff+file.load) ;dirnt.buff+file.load set to
3240 lda *zflag
3250 cmp #'+
3260 bne fload.cont
3270 xfrdbl (RAE.tpres dirnt.buff+file.load) ;set to end of text for
3280 fload.cont jsr crlf
3290 setosfl (showprgrs)
3300 bdos (readfile) ;do the read from disk
3310 jsr crlf
3320 adddbl (xfer.addr xfer.bytes) ;add bytes read to dest = end file
3330 xfrdbl (xfer.addr RAE.tpres) ;set RAE end of text pointer
3340 lda #$00
3350 ldy #$02
3360 sta (RAE.tpres),y ;set end + 2 bytes to 0 for RAE
3370 fload.exit cmpdbl (RAE.tpres RAE.txten tmp.byte)
3380 rts
3390 ;
3400 ; save.file is the entry point for the ENTER command
3410 ; This version requires 1 parameter, a symbiosys filename
3420 ; it will save the RAE text area to a file in the current
3430 ; directory with the default rae attribute ':'
3440 ;
3450 ; If the parameter is '~' instead of a filename then it
3460 ; will save the RAE text area into the currently opened file,
3470 ; which can be seen as the first file returned by the 'lsof'
3480 ; command (DC lsof) special file handle 0 reserved for RAE
3490 ;
3500 save.file cpy #$50 ;if y=50 filename is missing
3510 bne have.sparm ;y points to filename
3520 ldx #$30
3530 jmp (RAE.error) ;error 30=no filename
3540 ;
3550 have.sparm ldx #$00
3560 stx *disko.flag ;re-enable tape output
3570 lda RAE.crt,y
3580 cmp #'~
3590 bne newfile
3600 ;
3610 lda of.RAE
3620 beq sfexit ;errnofile
3630 tax
3640 lda of.bvffer+of.lba,x
3650 sta ilba0
3660 lda #0
3670 sta ilba8
3680 lda of.bvffer+of.lba+1,x
3690 sta ilba16
3700 lda of.bvffer+of.lba+2,x
3710 sta ilba24
3720 stdbl (dirnt.buff dta.ptr)
3730 bdos (load.sect)
3740 jmp existingfl
3750 ;
3760 sfexit jmp uniexit ;existingfl
3770 newfile fill ($00 dirnt.buff $ff)
3780 lda #':
3790 sta dirnt.buff+file.color
3800 ldx #$ff
3810 fnameloop inx
3820 lda RAE.crt,y
3830 iny
3840 sta dirnt.buff+file.name,x
3850 cmp #$20
3860 bne fnameloop
3870 lda #0
3880 sta dirnt.buff+file.name,x
3890 existingfl lda #showprgrs
3900 sta osflags
3910 xfrdbl (RAE.txtst dirnt.buff+file.load)
3920 xfrdbl (RAE.tpres dirnt.buff+file.size)
3930 subdbl (dirnt.buff+file.size dirnt.buff+file.load)
3940 bdos (disk.init)
3950 bdos (writefile)
3960 ;
3970 jsr falloc
3980 sta of.RAE
3990 tax
4000 lda dirnt.buff+file.size
4010 sta of.bvffer+of.size,x
4020 lda dirnt.buff+file.size+1
4030 sta of.bvffer+of.size+1,x
4040 ;
4050 savefexit jmp uniexit
4060 ;
4070 ;
4080 ; disk.cmnd is the entry point for the DC command
4090 ; this version requires a parameter the same as
4100 ; a regular Symbiosys command line which it will
4110 ; pass to the kernel for execution.
4120 ; The DC command with no parameters will exit to
4130 ; the symbiosys command prompt. Return to RAE with the
4140 ; rae command.
4150 ;
4160 disk.cmnd cpy #$50
4170 bne dc.cont
4180 jmp symbiosys ;no parms jump to sybiosys prompt
4190 ldx #$32
4200 jmp (RAE.error)
4210 dc.cont ldx #0
4220 dc.loop lda RAE.crt,y
4230 sta line.bvff,x
4240 iny
4250 inx
4260 cmp #$20
4270 bne dc.loop
4280 lda RAE.crt,y
4290 cmp #$20
4300 bne dc.loop
4310 lda #0
4320 sta line.bvff-1,x
4330 sta osflags
4340 puts (line.bvff)
4350 jsr space
4360 parsarg (line.bvff)
4370 lda *zargc
4380 beq dc.exit
4390 proccmd (monst.ctab)
4400 bcs dc.exit ; command found internally
4410 exec (zargv[0])
4420 bne dc.exit ; command found in filesystem
4430 jsr istr.prnt
4440 .by 'command not found' $00
4450 dc.exit jmp uniexit
4460 ;
4470 uniexit ldx #$ff
4480 txs
4490 jmp RAE.hot
4500 ;
4510 crtin jsr intchr
4520 sb (del bs)
4530 rts
4540 ;
4550 crtout sb (bs del)
4560 jmp tout
4570 ;
4580 falloc ldx #1 ;of.bvffer
4590 ldy #0
4600 cplba.loop lda ilba8,y
4610 sta of.bvffer,x
4620 inx
4630 iny
4640 cpy #3
4650 bne cplba.loop
4660 lda #0
4670 sta of.bvffer,x
4680 inx
4690 sta of.bvffer,x
4700 inx
4710 sta of.bvffer,x
4720 inx
4730 sta of.bvffer,x
4740 inx
4750 lda #1
4760 sta of.bvffer,x
4770 inx
4780 ; lda #1 ;of.bvffer
4790 ; stx of.bvffer
4800 rts
4810 ;
4820 tmp.byte .by $00
4830 ;
4840 .en
