Page 3 of 15
Re: Breaking 6502 apart
Posted: Mon Jul 09, 2012 2:21 pm
by org
More progress on crazy logic :
Image no longer available: http://ogamespec.com/imgstore/whc4ffae6ac6ec5a.jpg
I began to understand how it works in general
PLA outputs are joined in "groups".
Groups on the left works with X,Y and S registers (resided underneath).
Groups on the middle are ALU related, which feed its inputs.
Groups on the right are branch/flag/compare and (possibly) interrupt/reset logic; instructions related to program counter (PC is resided on the bottom right side of the 6502).
Also there is intense metall layer crosspassing from the left to the right, for addressing calculations purposes.
Hope to crunch it fast, when I get full color schematics (good for LSD trips BTW
Posted: Mon Jul 09, 2012 5:05 pm
by org
In case someone interested, Visual6502 wiki has hidden section, which I found by poking Random page:
http://visual6502.org/wiki/index.php?ti ... atic_Notes
There is poor photos of 6502 blueprints.
Posted: Tue Jul 10, 2012 1:14 pm
by Unseen
Actually it's not a photo but a size-reduced version of a scan of the blueprint. A photo would have no or different artifacts at the places where overlapping sections are merged.
Posted: Wed Jul 11, 2012 6:04 am
by org
I mean images ) Sorry my language )
Posted: Wed Jul 11, 2012 1:02 pm
by org
Todays speccy: Random logic A/B groups.
I separated PLA outputs on groups A,B,C,D,E,F,G,H and K.
Here is preview of below schematics :
Image no longer available: http://ogamespec.com/imgstore/whc4ffd765f41d7c.jpg
Top part:
Bottom part:
Also there is small logic to generate internal 43 and 1247 lines, which are used on bottom part:
(I do not understand wtf is it... some kind of /ะค1 power-up?)
I labeled interconnections between groups by white text.
Posted: Wed Jul 11, 2012 7:19 pm
by org
More progress on ALU:
Image no longer available: http://ogamespec.com/imgstore/whc4ffdd1751cca0.jpg
Posted: Thu Jul 12, 2012 12:42 pm
by org
I updated my PLA utility :
http://ogamespec.com/6502/decoder.htm
Now you can input raw bits from PLA lines and get IR mask as well as T-cycle on output.
msb bit in sequence is equal to bottom PLA line (t1).
A
000101100000100100000
000000010110001000100
000000011010001001000
010100011001100100000
010101011010100100000
010110000001100100000
B
000000100010000001000
000001000000100010000
000000010101001001000
010101011001100010000
010110011001100010000
011010000001100100000
000101000000100010000
010101011010100010000
011001000000100010000
000110011001100010000
001010011001100100000
011001011010100010000
000100011001100100000
011001100000100100000
011001000001100100000
C
011001010101010100000
000101010101010100001
010100011001010100000
001010010101010100010
001000011001010100100
000110010101010100001
001010000000010010000
000000000000000001000
010110000000011000000
000010101001010100000
000000101001000001000
010101000000011000000
000000000100000001000
010000000000000000000
000000010001010101000
000000000001010100100
D
000001010101010100010
000110010101010100010
000000010101001000100
000000010110001000010
000000010110001001000
K
000000011001010100000 ->
010010011010100100000
000001000000000000000
000000101001000000100
000000100101000001000
000000010100001000001
0000000010100?0000010 ? is actually 0, but strange.. supposed to be vias there
000000000000010000000
001001011010100100000
00000001100000000 <-
Posted: Fri Jul 13, 2012 9:29 am
by org
Completed random logic color schematics.
Also I choosed another strategy to reverse this whole crap. I start from T0 only PLA lines, then continue on T1 lines only and so on.
Posted: Fri Jul 13, 2012 7:21 pm
by org
Completed ALU color map.
Posted: Fri Jul 13, 2012 7:35 pm
quick progress! But you missed a horizontal run of poly - see pic.
Posted: Fri Jul 13, 2012 7:52 pm
by org
Ehhehe, damn puzzle
I'll fix it in transistor level schematics )
EDIT: you don't need this poly line, it somes from from address latch )
EDIT2: ooops, or maybe need )
Posted: Sat Jul 14, 2012 11:18 am
by org
Todays speccy: ALU bit0
Pieces from left-to-right: B INPUT (BI), A INPUT (AI), LOGIC, ARITHMETIC, DECIMAL ADDER, ADDER HOLD REG (ADD), DECIMAL ADJUST, ACCUMULATOR (AC).
Posted: Sat Jul 14, 2012 11:36 am
Decimal adjust is a big random tangle! It's also not organised by bit slices. Joyful!
Posted: Sat Jul 14, 2012 11:38 am
by org
Posted: Mon Jul 16, 2012 9:27 am
by org
Todays speccy : PLA lines decoded!
A
01: 000101100000100100000 100XX100 TX STY
02: 000000010110001000100 XXX100X1 T3 OP ind, Y
03: 000000011010001001000 XXX110X1 T2 OP abs, Y
04: 010100011001100100000 1X001000 T0 DEY INY
05: 010101011010100100000 10011000 T0 TYA
06: 010110000001100100000 1100XX00 T0 CPY INY
B
01: 000000100010000001000 XXX1X1XX T2 OP zpg, X/Y & OP abs, X/Y
02: 000001000000100010000 10XXXX1X TX LDX STX A<->X S<->X
03: 000000010101001001000 XXX000X1 T2 OP ind, X
04: 010101011001100010000 1000101X T0 TXA
05: 010110011001100010000 1100101X T0 DEX
06: 011010000001100100000 1110XX00 T0 CPX INX
07: 000101000000100010000 100XXX1X TX STX TXA TXS
08: 010101011010100010000 1001101X T0 TXS
09: 011001000000100010000 101XXX1X T0 LDX TAX TSX
10: 000110011001100010000 1100101X TX DEX
11: 001010011001100100000 11101000 TX INX
12: 011001011010100010000 1011101X T0 TSX
13: 000100011001100100000 1X001000 TX DEY INY
14: 011001100000100100000 101XX100 T0 LDY
15: 011001000001100100000 1010XX00 T0 LDY TAY
C
01: 011001010101010100000 00100000 T0 JSR
02: 000101010101010100001 00000000 T5 BRK
03: 010100011001010100000 0X001000 T0 Push
04: 001010010101010100010 01100000 T4 RTS
05: 001000011001010100100 0X101000 T3 Pull
06: 000110010101010100001 01000000 T5 RTI
07: 001010000000010010000 011XXX1X TX ROR
08: 000000000000000001000 XXXXXXXX T2 T2 ANY
09: 010110000000011000000 010XXXX1 T0 EOR
10: 000010101001010100000 01X01100 TX JMP
11: 000000101001000001000 XXX011XX T2 RIGHT R ODD
12: 010101000000011000000 000XXXX1 T0 ORA
13: 000000000100000001000 XXXX0XXX T2 LEFT ALL
14: 010000000000000000000 XXXXXXXX T0 T0 ANY
15: 000000010001010101000 0XX0X000 T2 BRK JSR RTI RTS Push/pull
16: 000000000001010100100 0XX0XX00 T3 BRK JSR RTI RTS Push/pull + BIT JMP
D
01: 000001010101010100010 00X00000 T4 BRK JSR
02: 000110010101010100010 01000000 T4 RTI
03: 000000010101001000100 XXX000X1 T3 OP X, ind
04: 000000010110001000010 XXX100X1 T4 OP ind, Y
05: 000000010110001001000 XXX100X1 T2 OP ind, Y
06: 000000001010000000100 XXX11XXX T3 RIGHT ODD
07: 001000011001010100000 0X101000 TX Pull
08: 001010000000100010000 111XXX1X TX INC NOP
09: 000000010101001000010 XXX000X1 T4 OP X, ind
10: 000000010110001000100 XXX100X1 T3 OP ind, Y
11: 000010010101010100000 01X00000 TX RTI RTS
12: 001001010101010101000 00100000 T2 JSR
13: 010010000001100100000 11X0XX00 T0 CPY CPX INY INX
14: 010110000000101000000 110XXXX1 T0 CMP
15: 011010000000101000000 111XXXX1 T0 SBC
16: 011010000000001000000 X11XXXX1 T0 ADC SBC
17: 001001000000010010000 001XXX1X TX ROL
E
01: 000010101001010100100 01X01100 T3 JMP
02: 000001000000010010000 00XXXX1X TX ASL ROL
03: 001001010101010100001 00100000 T5 JSR
04: 000000010001010101000 0XX0X000 T2 BRK JSR RTI RTS Push/pull
06: 100000000000011000000 0XXXXXX1 T1 UPPER ODD
07: 101010000000001000000 X11XXXX1 T1 ADC SBC
08: 100000011001010010000 0XX0101X T1 ASL ROL LSR ROR
09: 010101011001100010000 1000101X T0 TXA
10: 011010011001010100000 01101000 T0 PLA
11: 011001000000101000000 101XXXX1 T0 LDA
12: 010000000000001000000 XXXXXXX1 T0 ALL ODD
13: 011001011001100100000 10101000 T0 TAY
14: 010000011001010010000 0XX0101X T0 ASL ROL LSR ROR
15: 011001011001100010000 1010101X T0 TAX
16: 011001100001010100000 0010X100 T0 BIT
17: 011001000000011000000 001XXXX1 T0 AND
18: 000000001010000000010 XXX11XXX T4 RIGHT ODD
19: 000000010110001000001 XXX100X1 T5 OP ind, Y
F
01: 010000010110000100000 XXX10000 T0 <- Branch + BranchReady line
02: 000110011001010101000 01001000 T2 PHA
03: 010010011001010010000 01X0101X T0 LSR ROR
04: 000010000000010010000 01XXXX1X TX LSR ROR
05: 000101010101010101000 00000000 T2 BRK
06: 001001010101010100100 00100000 T3 JSR
07: 000101000000101000000 100XXXX1 TX STA
08: 000000010110000101000 XXX10000 T2 Branch
09: 000000100100000001000 XXXX01XX T2 zero page
10: 000000010100001001000 XXXX00X1 T2 ALU indirect
11: 000000001000000001000 XXXX1XXX T2 RIGHT ALL
12: 001010010101010100001 01100000 T5 RTS
13: 000000000000000000010 XXXXXXXX T4 T4 ANY
14: 000000000000000000100 XXXXXXXX T3 T3 ANY
15: 010100010101010100000 0X000000 T0 BRK RTI
16: 010010101001010100000 01X01100 T0 JMP
17: 000000010101001000001 XXX000X1 T5 OP X, ind
18: 000000001000000000100 XXXX1XXX T3 RIGHT ALL
G
01: 000000010110001000010 XXX100X1 T4 OP ind, Y
02: 000000001010000000100 XXX11XXX T3 RIGHT ODD
03: 000000010110000100100 XXX10000 T3 Branch
04: 000100010101010100000 0X000000 TX BRK RTI
05: 001001010101010100000 00100000 TX JSR
06: 000010101001010100000 01X01100 TX JMP
07: 000000011001010100000 0XX01000 TX Push/pull
08: 000101000000100000000 100XXXXX TX 80-9F
09: 000101010101010100010 00000000 T4 BRK
10: 000101011001010101000 00001000 T2 PHP
11: 000100011001010101000 0X001000 T2 Push
12: 000010101001010100010 01X01100 T4 JMP
13: 000010010101010100001 01X00000 T5 RTI RTS
14: 001001010101010100001 00100000 T5 JSR
H
01: 000110101001010101000 01001100 T2 JMP
02: 001000011001010100100 0X101000 T3 Pull
03: 000010000000000010000 X1XXXX1X TX LSR ROR DEC INC DEX NOP (4x4 bottom right)
04: 000001000000010010000 00XXXX1X TX ASL ROL
05: 010010011010010100000 01X11000 T0 CLI SEI
06: 101001100001010100000 0010X100 T1 BIT
07: 010001011010010100000 00X11000 T0 CLC SEC
08: 000000100110000000100 XXX101XX T3 OP zpg, X
09: 101010000000001000000 X11XXXX1 T1 ADC SBC
10: 011001100001010100000 0010X100 T0 BIT
11: 011001011001010100000 00101000 T0 PLP
12: 000110010101010100010 01000000 T4 RTI
13: 100110000000101000000 110XXXX1 T1 CMP
14: 100010101001100100000 11X01100 T1 CPY CPX
15: 100001011001010010000 00X0101X T1 ASL ROL
16: 100010000101100100000 11X00X00 T1 CPY CPX
K
KX: 000000011001010100000 0XX01000 TX Not actually line. Controls K09 to except push/pull opcodes --->
01: 010010011010100100000 11X11000 T0 CLD SED
02: 000001000000000000000 X0XXXXXX TX 00-3F 80-BF
03: 000000101001000000100 XXX011XX T3 RIGHT R EVEN
04: 000000100101000001000 XXX001XX T2 LEFT R EVEN
05: 000000010100001000001 XXXX00X1 T5 ALU indirect
06: 0000000010100?0000010 XXX11XXX T4 RIGHT ODD (? is actually 0, but strange.. 0XX11XXX T4 if supposed to be vias there)
07: 000000000000010000000 0XXXXXXX TX UPPER ALL
08: 001001011010100100000 10111000 TX CLV
09: 000000011000000...... XXXX10X0 TX All flags + DEY TAY INY INX - 0XX01000 <--- controlled by KX
Explanations:
A-K - line groups
01-09 - line number
000000001000000001000 - PLA bit assignment
X1XXXX1X TX - IR condition to fire line + T-step (T0-T5, TX mean "any")
+ short description which opcodes are affected by this line. "OP" mean any opcode.
PLA lines sorted by T-step:
A04: 010100011001100100000 1X001000 T0 DEY INY
A05: 010101011010100100000 10011000 T0 TYA
A06: 010110000001100100000 1100XX00 T0 CPY INY
B04: 010101011001100010000 1000101X T0 TXA
B05: 010110011001100010000 1100101X T0 DEX
B06: 011010000001100100000 1110XX00 T0 CPX INX
B08: 010101011010100010000 1001101X T0 TXS
B09: 011001000000100010000 101XXX1X T0 LDX TAX TSX
B12: 011001011010100010000 1011101X T0 TSX
B14: 011001100000100100000 101XX100 T0 LDY
B15: 011001000001100100000 1010XX00 T0 LDY TAY
C01: 011001010101010100000 00100000 T0 JSR
C03: 010100011001010100000 0X001000 T0 Push
C09: 010110000000011000000 010XXXX1 T0 EOR
C12: 010101000000011000000 000XXXX1 T0 ORA
C14: 010000000000000000000 XXXXXXXX T0 T0 ANY
D13: 010010000001100100000 11X0XX00 T0 CPY CPX INY INX
D14: 010110000000101000000 110XXXX1 T0 CMP
D15: 011010000000101000000 111XXXX1 T0 SBC
D16: 011010000000001000000 X11XXXX1 T0 ADC SBC
E05: 010101011010100100000 10011000 T0 TYA
E09: 010101011001100010000 1000101X T0 TXA
E10: 011010011001010100000 01101000 T0 PLA
E11: 011001000000101000000 101XXXX1 T0 LDA
E12: 010000000000001000000 XXXXXXX1 T0 ALL ODD
E13: 011001011001100100000 10101000 T0 TAY
E14: 010000011001010010000 0XX0101X T0 ASL ROL LSR ROR
E15: 011001011001100010000 1010101X T0 TAX
E16: 011001100001010100000 0010X100 T0 BIT
E17: 011001000000011000000 001XXXX1 T0 AND
F01: 010000010110000100000 XXX10000 T0 <- Branch + BranchReady line
F03: 010010011001010010000 01X0101X T0 LSR ROR
F15: 010100010101010100000 0X000000 T0 BRK RTI
F16: 010010101001010100000 01X01100 T0 JMP
H05: 010010011010010100000 01X11000 T0 CLI SEI
H07: 010001011010010100000 00X11000 T0 CLC SEC
H10: 011001100001010100000 0010X100 T0 BIT
H11: 011001011001010100000 00101000 T0 PLP
K01: 010010011010100100000 11X11000 T0 CLD SED
E06: 100000000000011000000 0XXXXXX1 T1 UPPER ODD
E07: 101010000000001000000 X11XXXX1 T1 ADC SBC
E08: 100000011001010010000 0XX0101X T1 ASL ROL LSR ROR
H06: 101001100001010100000 0010X100 T1 BIT
H09: 101010000000001000000 X11XXXX1 T1 ADC SBC
H13: 100110000000101000000 110XXXX1 T1 CMP
H14: 100010101001100100000 11X01100 T1 CPY CPX
H15: 100001011001010010000 00X0101X T1 ASL ROL
H16: 100010000101100100000 11X00X00 T1 CPY CPX
A03: 000000011010001001000 XXX110X1 T2 OP abs, Y
B01: 000000100010000001000 XXX1X1XX T2 OP zpg, X/Y & OP abs, X/Y
B03: 000000010101001001000 XXX000X1 T2 OP ind, X
C08: 000000000000000001000 XXXXXXXX T2 T2 ANY
C11: 000000101001000001000 XXX011XX T2 RIGHT R ODD
C13: 000000000100000001000 XXXX0XXX T2 LEFT ALL
C15: 000000010001010101000 0XX0X000 T2 BRK JSR RTI RTS Push/pull
D05: 000000010110001001000 XXX100X1 T2 OP ind, Y
D12: 001001010101010101000 00100000 T2 JSR
E04: 000000010001010101000 0XX0X000 T2 BRK JSR RTI RTS Push/pull
F02: 000110011001010101000 01001000 T2 PHA
F05: 000101010101010101000 00000000 T2 BRK
F08: 000000010110000101000 XXX10000 T2 Branch
F09: 000000100100000001000 XXXX01XX T2 zero page
F10: 000000010100001001000 XXXX00X1 T2 ALU indirect
F11: 000000001000000001000 XXXX1XXX T2 RIGHT ALL
G10: 000101011001010101000 00001000 T2 PHP
G11: 000100011001010101000 0X001000 T2 Push
H01: 000110101001010101000 01001100 T2 JMP
K04: 000000100101000001000 XXX001XX T2 LEFT R EVEN
A02: 000000010110001000100 XXX100X1 T3 OP ind, Y
C05: 001000011001010100100 0X101000 T3 Pull
C16: 000000000001010100100 0XX0XX00 T3 BRK JSR RTI RTS Push/pull + BIT JMP
D03: 000000010101001000100 XXX000X1 T3 OP X, ind
D06: 000000001010000000100 XXX11XXX T3 RIGHT ODD
D10: 000000010110001000100 XXX100X1 T3 OP ind, Y
E01: 000010101001010100100 01X01100 T3 JMP
F06: 001001010101010100100 00100000 T3 JSR
F14: 000000000000000000100 XXXXXXXX T3 T3 ANY
F18: 000000001000000000100 XXXX1XXX T3 RIGHT ALL
G02: 000000001010000000100 XXX11XXX T3 RIGHT ODD
G03: 000000010110000100100 XXX10000 T3 Branch
H02: 001000011001010100100 0X101000 T3 Pull
H08: 000000100110000000100 XXX101XX T3 OP zpg, X
K03: 000000101001000000100 XXX011XX T3 RIGHT R EVEN
C04: 001010010101010100010 01100000 T4 RTS
D01: 000001010101010100010 00X00000 T4 BRK JSR
D02: 000110010101010100010 01000000 T4 RTI
D04: 000000010110001000010 XXX100X1 T4 OP ind, Y
D09: 000000010101001000010 XXX000X1 T4 OP X, ind
E18: 000000001010000000010 XXX11XXX T4 RIGHT ODD
F13: 000000000000000000010 XXXXXXXX T4 T4 ANY
G01: 000000010110001000010 XXX100X1 T4 OP ind, Y
G09: 000101010101010100010 00000000 T4 BRK
G12: 000010101001010100010 01X01100 T4 JMP
H12: 000110010101010100010 01000000 T4 RTI
K06: 0000000010100?0000010 XXX11XXX T4 RIGHT ODD (? is actually 0, but strange.. 0XX11XXX T4 if supposed to be vias there)
C02: 000101010101010100001 00000000 T5 BRK
C06: 000110010101010100001 01000000 T5 RTI
E03: 001001010101010100001 00100000 T5 JSR
E19: 000000010110001000001 XXX100X1 T5 OP ind, Y
F12: 001010010101010100001 01100000 T5 RTS
F17: 000000010101001000001 XXX000X1 T5 OP X, ind
G13: 000010010101010100001 01X00000 T5 RTI RTS
G14: 001001010101010100001 00100000 T5 JSR
K05: 000000010100001000001 XXXX00X1 T5 ALU indirect
A01: 000101100000100100000 100XX100 TX STY
B02: 000001000000100010000 10XXXX1X TX LDX STX A<->X S<->X
B07: 000101000000100010000 100XXX1X TX STX TXA TXS
B10: 000110011001100010000 1100101X TX DEX
B11: 001010011001100100000 11101000 TX INX
B13: 000100011001100100000 1X001000 TX DEY INY
C07: 001010000000010010000 011XXX1X TX ROR
C10: 000010101001010100000 01X01100 TX JMP
D07: 001000011001010100000 0X101000 TX Pull
D08: 001010000000100010000 111XXX1X TX INC NOP
D11: 000010010101010100000 01X00000 TX RTI RTS
D17: 001001000000010010000 001XXX1X TX ROL
E02: 000001000000010010000 00XXXX1X TX ASL ROL
F04: 000010000000010010000 01XXXX1X TX LSR ROR
F07: 000101000000101000000 100XXXX1 TX STA
G04: 000100010101010100000 0X000000 TX BRK RTI
G05: 001001010101010100000 00100000 TX JSR
G06: 000010101001010100000 01X01100 TX JMP
G07: 000000011001010100000 0XX01000 TX Push/pull
G08: 000101000000100000000 100XXXXX TX 80-9F
H03: 000010000000000010000 X1XXXX1X TX LSR ROR DEC INC DEX NOP (4x4 bottom right)
H04: 000001000000010010000 00XXXX1X TX ASL ROL
K02: 000001000000000000000 X0XXXXXX TX 00-3F 80-BF
K07: 000000000000010000000 0XXXXXXX TX UPPER ALL
K08: 001001011010100100000 10111000 TX CLV
K09: 000000011000000...... XXXX10X0 TX All flags + DEY TAY INY INX - 0XX01000 <--- controlled by KX
