Page 3 of 5
Concatenation in Verilog
Posted: Thu Oct 24, 2013 12:45 am
by ElEctric_EyE
Another n00b question regarding Verilog and concatenation of bits using the '{}' operator.
Is it {MSb,LSb}? which I would have found more logical, but has always thrown me in a loop.
Or {LSb,MSb}? I just need confirmation. Is this really correct thinking?
Re: n00b Verilog Questions
Posted: Thu Oct 24, 2013 12:59 am
by Rob Finch
It's {MSB...LSB}. MSB on the left, LSBs to the right.
I've been following along, and I don't understand why the VSYNC signal would need significant delays. It can't be out more than a few clock cycles. Shouldn't the propagation delay in the VSYNC be about the same as the delay in the HSYNC ?
Posted: Thu Oct 24, 2013 1:16 am
by ElEctric_EyE
That's what I would have thought as well... Thanks Rob!
Let me finish the block diagram... My lack of understanding hinders me, but I still make progress...
What I can say is any delays I have put on any of the signals that affect VSYNC do not actually delay pixel output vertically. Which is why I've had to resort to delaying horizontally "a great many cycles" in order to align vertically. For example, in order to delay 2 pixels vertically, I have had to delay the 'hstart' signal by 2x1024 cycles.
This has worked but it is not efficient and I am puzzled why delaying a VSYNC signal differs from delaying an HSYNC signal.
Posted: Thu Oct 24, 2013 5:22 am
by Arlet
For vertical offset, keep in mind that you'd have to delay vsync in steps of a whole line, which is in effect "a great many cycles" if you count the pixels, but is only a small number if you count hlines.
But the question remains why you'd need such fixed offsets anyway.
Posted: Fri Oct 25, 2013 1:28 am
by ElEctric_EyE
...But the question remains why you'd need such fixed offsets anyway.
I think it may have to do with how I am attempting to sync the state machines used in your vga module between successive boards.
When a positive HSYNCin or VSYNCin is detected, it resets the appropriate counters just like the hcount_ done and vcount_done signals do.
...// adjust down counter. Reload when it's done.
always @(posedge clk)
if ( HSYNCin | hcount_done )
hcount <= { 1'b0, hload };...
if( venable ) begin
if ( VSYNCin | vcount_done )
vcount <= { 1'b0, vload };...
Also, when HSYNCin or VSYNCin goes active, The state machine is forced to the VIDEO state. Maybe this is wrong? But when I try to sync to any other state, I see no video.
...// when down counter is done, go to next state
if( hcount_done )
case( hstate )
VIDEO : hstate <= FRONT;
FRONT : hstate <= SYNC;
SYNC : hstate <= BACK;
BACK : hstate <= VIDEO;
endcase
else if (HSYNCin)
hstate <= VIDEO;...
if( venable & vcount_done )
case( vstate )
VIDEO : vstate <= FRONT;
FRONT : vstate <= SYNC;
SYNC : vstate <= BACK;
BACK : vstate <= VIDEO;
endcase
else if (VSYNCin)
vstate <= VIDEO;...
Posted: Wed Nov 06, 2013 7:50 pm
by ElEctric_EyE
...unrelated to previous questions...
For a signal that is common to some modules, is it best to have the logic that derives that signal on the top level?
For example, if I need a display enable signal, 3 signals are needed to generate it: hstart, hblank and vblank. I could generate the display enable within it's own module and output it to other modules, or I could generate it on the top_level. What is the accepted method in Verilog?
Posted: Wed Nov 06, 2013 8:01 pm
by MichaelM
I would place it at the level most appropriate for the functional decomposition of your system. If you have a sub-module whose function is video control, I'd put it in that module, and bring it up to the top module and distribute it from there. However, if you don't have a module whose function is video control, I'd generate the signal in the top module until such time as there's a need to create a video control module.
Posted: Wed Nov 06, 2013 9:17 pm
by ElEctric_EyE
Michael, thanks for the pointer, what you say makes sense maybe I'm getting tunnel vision. Just FYI, Arlet's original .vga controller outputs hstart, hblank, vstart and vblank. Maybe it's a clue...
But let's say for arguments' sake that I modify that video control module to output a display enable signal:
//display enable
if ( hstart )
countflag <= 1;
else if ( hblank | vblank )
countflag <= 0;
So it uses 3 signals and no other modules use those signals. But another module, the external RAM interface, uses the vstart signal to start the pixel counter used for the address:
// pixel counters for 2MBx18 external SyncRAM
reg [9:0] X;
reg [9:0] Y;
if ( vstart | X == 1023 & Y == 767 ) begin
X <= 0;
Y <= 0;
end
else if ( X == 1023 ) begin
Y <= Y + 1;
X <= 0;
end
else if ( countflag )
X <= X + 1;
If the situation were reversed and 3 signals were used externally, and 1 internal would it be best to have this code present in the top module? What about 2 external and 2 internal? or will the tools just figure this stuff out?
So far in my testing I haven't noticed any change but I am chasing down a problem, so I'm 'getting my ducks in a row'. Thanks!
Posted: Wed Nov 06, 2013 9:21 pm
by Arlet
I would probably make a separate module to fetch bitmaps from memory, and send the pixel data to the video output, so that the external RAM interface would just offer a multi-port generic memory interface, without any dependency on pixels or screen sizes.
Posted: Wed Nov 06, 2013 10:06 pm
by ElEctric_EyE
Arlet, I think you're right. Everything seems jumbled now. I am dealing with code that I wrote when I first started learning Verilog. I had some early successes, but they weren't necessarily correct. I'm now having a problem generating a simple border using one video board!
I hate to realize this, but I may have to start from scratch...
But before I do I would like to ask you Verilog experts how to go about making a piece of code sleeker. It is the Line and circle hardware plotter...
I put delays in there to make the simulations look correct and in real life it works, but the code is not pretty. What is the simplest structural change I can make to make this more efficient?
Thanks for your input all!
`timescale 1ns / 1ps
module LineGen ( input clk,
input lineCS,
input [15:0] cpuDO,
input [3:0] cpuAB,
input countflag,
input [15:0] SRD,
output reg RAMWE,
output reg LGREADY,
output reg [aw:0] X,
output reg [aw:0] Y,
output reg [15:0] color,
output reg [15:0] border
parameter aw = 10; //2048
//blitter variables
reg [15:0] bXlen, bYlen;
reg [aw:0] bXc, bYc, bXp, bYp;
//linegen variables
reg [aw:0] x0, x1, dx, x0t, x1t, y0, y1, dy, y0t, y1t; //internal module registers
reg [aw+1:0] D; //error accumulator + carry bit. if D[aw+1] = 1, it is negative
reg [0:0] steep, //1 when dy>dx
dyneg, //1 when dy is negative
dxneg; //1 when dx is negative
//circle variables
reg [aw:0] xc, yc, rad, x, y = 0;
reg [aw+1:0] raderr;
reg [4:0] state;
parameter WAIT = 0, LOAD = 1, SLOPE = 2, DXDY = 3, CALC1 = 4, CALC2 = 5, PLOT = 6,
CALC3 = 7, CALC4 = 8, OCT1 = 9, OCT2 = 10, OCT3 = 11, OCT4 = 12, OCT5 = 13, OCT6 = 14, OCT7 = 15, OCT8 = 16,
DEL1 = 17, DEL2 = 18, DEL3 = 19, DEL4 = 20, DEL5= 21, DEL6 = 22, DEL7 = 23, DEL8 = 24;
always @(posedge clk) begin
if (lineCS && cpuAB == 4'b0000) //variables for line generator
x0t <= cpuDO;
if (lineCS && cpuAB == 4'b0001)
y0t <= cpuDO;
if (lineCS && cpuAB == 4'b0010)
x1t <= cpuDO;
if (lineCS && cpuAB == 4'b0011)
y1t <= cpuDO;
if (lineCS && cpuAB == 4'b0100) //variables for circle generator
xc <= cpuDO;
if (lineCS && cpuAB == 4'b0101)
yc <= cpuDO;
if (lineCS && cpuAB == 4'b0110)
rad <= cpuDO;
if (lineCS && cpuAB == 4'b0111) //color variable
color <= cpuDO;
if (lineCS && cpuAB == 4'b1000) //X length of blitter
bXlen <= cpuDO;
if (lineCS && cpuAB == 4'b1001) //Y length of blitter
bYlen <= cpuDO;
if (lineCS && cpuAB == 4'b1010) //X start copy
bXc <= cpuDO;
if (lineCS && cpuAB == 4'b1011) //Y start copy
bYc <= cpuDO;
if (lineCS && cpuAB == 4'b1100) //X start paste
bXp <= cpuDO;
if (lineCS && cpuAB == 4'b1101) //Y start paste
bYp <= cpuDO;
if (lineCS && cpuAB == 4'b1110) //border color
border <= cpuDO;
end
state <= WAIT;
case (state)
WAIT:
begin
if (lineCS && cpuAB == 3'b011) //draw a line
state <= LOAD;
else if (lineCS && cpuAB == 3'b110) //draw a circle
state <= CALC3;
else state <= WAIT;
end
LOAD:
state <= SLOPE;
SLOPE:
state <= DXDY;
DXDY:
state <= CALC1;
CALC1:
state <= CALC2;
CALC2:
state <= PLOT;
PLOT:
begin
if (!dyneg && steep) //e.g. (0,0) to (2,10)
if (y0 != y1)
state <= CALC2;
else state <= WAIT;
if (!dyneg && !steep) //e.g. (0,0) to (10,10)
if (x0 != x1)
state <= CALC2;
else state <= WAIT;
if (dyneg && !steep) //e.g. (0,10) to (10,0)
if (x0 != x1)
state <= CALC2;
else state <= WAIT;
if (dyneg && steep) //e.g. (0,20) to (2,0)
if (y0 != y1)
state <= CALC2;
else state <= WAIT;
end
CALC3:
state <= OCT1;
CALC4:
state <= OCT1;
OCT1:
if ( x >= y )
state <= DEL1;
else state <= WAIT;
DEL1:
state <= OCT2;
OCT2:
state <= DEL2;
DEL2:
state <= OCT3;
OCT3:
state <= DEL3;
DEL3:
state <= OCT4;
OCT4:
state <= DEL4;
DEL4:
state <= OCT5;
OCT5:
state <= DEL5;
DEL5:
state <= OCT6;
OCT6:
state <= DEL6;
DEL6:
state <= OCT7;
OCT7:
state <= DEL7;
DEL7:
state <= OCT8;
OCT8:
state <= DEL8;
DEL8:
state <= CALC4;
endcase
end
case (state)
WAIT:
begin
RAMWE <= 0;
LGREADY <= 1;
if (x0t > x1t)
dxneg <= 1;
else dxneg <= 0;
end
LOAD:
begin
LGREADY <= 0;
if (dxneg)
begin
x0 <= x1t;
y0 <= y1t;
x1 <= x0t;
y1 <= y0t;
end
else begin
x0 <= x0t;
y0 <= y0t;
x1 <= x1t;
y1 <= y1t;
end
end
SLOPE:
if (y0 > y1)
dyneg <= 1;
else dyneg <= 0;
DXDY:
begin
dx <= x1 - x0;
RAMWE <= 1;
X <= x0;
Y <= y0;
if (dyneg)
dy <= y0 - y1;
else dy <= y1 - y0;
end
CALC1:
begin
RAMWE <= 0;
if (dx >= dy) begin
steep <= 0;
D <= (dy*2 - dx);
end
else begin
steep <= 1;
D <= (dx*2 - dy);
end
end
CALC2:
begin
RAMWE <= 0;
if (steep) begin
if ( D[10] == 0 ) begin
x0 <= x0 + 1;
y0 <= dyneg ? y0 - 1:
y0 + 1;
D <= D + (dx*2 - dy*2);
end
else begin
y0 + 1;
D <= D + dx*2;
end
end
else if ( D[10] == 0 ) begin
x0 <= x0 + 1;
y0 + 1;
D <= D + (dy*2 - dx*2);
end
else begin
x0 <= x0 + 1;
D <= D + dy*2;
end
end
PLOT:
begin
RAMWE <= 1;
X <= x0;
Y <= y0;
end
CALC3:
begin
x <= rad;
y <= 0;
raderr <= 1 - x;
LGREADY <= 0;
RAMWE <= 0;
end
CALC4:
begin
RAMWE <= 0;
y <= y + 1;
if ( raderr[10] )
raderr <= raderr + (y+1);
else begin
x <= x - 1;
raderr <= raderr + (y-x)+1;
end
end
OCT1: // |
begin // |
RAMWE <= 1; // -------
X <= xc + (x); // | Oct1
Y <= yc + y; // |
end
OCT2:
begin // |
RAMWE <= 1; // |
X <= xc + (y); // -------
Y <= yc + (x); // |
end // | Oct2
OCT3: // |
begin // |
X <= xc - x; // Oct3 |
Y <= yc + y; // |
end
OCT4: // |
begin // |
X <= xc - (y); // |
Y <= yc + (x); // Oct4 |
end
OCT5: // |
begin // Oct5 |
X <= xc - (x); // |
Y <= yc - y; // |
end
OCT6: // Oct6 |
begin // |
X <= xc - (y); // |
Y <= yc - x; // |
end
OCT7: // |
begin // | Oct7
X <= xc + (x); // |
Y <= yc - y; // |
end
OCT8: // | Oct8
begin // |
X <= xc + (y); // |
Y <= yc - (x); // |
end
DEL1:
RAMWE <= 1;
//DEL2:
// RAMWE <= 1;
//DEL3:
// RAMWE <= 1;
//DEL4:
// RAMWE <= 1;
//DEL5:
// RAMWE <= 1;
//DEL6:
// RAMWE <= 1;
//DEL7:
// RAMWE <= 1;
//DEL8:
// RAMWE <= 1;
endcase
end
endmodule
Posted: Tue Dec 24, 2013 7:24 pm
by ElEctric_EyE
All those 'if' statements:
if (lineCS && cpuAB == 5'b00000) //variables for line generator
x0t <= cpuDO;
if (lineCS && cpuAB == 5'b00001)
y0t <= cpuDO;
if (lineCS && cpuAB == 5'b00010)
x1t <= cpuDO;
if (lineCS && cpuAB == 5'b00011)
y1t <= cpuDO;
if (lineCS && cpuAB == 5'b00100) //variables for circle generator
xc <= cpuDO;
if (lineCS && cpuAB == 5'b00101)
yc <= cpuDO;
if (lineCS && cpuAB == 5'b00110)
rad <= cpuDO;
if (lineCS && cpuAB == 5'b00111) //color variable
color <= cpuDO;
if (lineCS && cpuAB == 5'b01000) //X length of blitter
bXlen <= cpuDO;
if (lineCS && cpuAB == 5'b01001) //Y length of blitter
bYlen <= cpuDO;
if (lineCS && cpuAB == 5'b01010) //X start copy
bXc <= cpuDO;
if (lineCS && cpuAB == 5'b01011) //Y start copy
bYc <= cpuDO;
if (lineCS && cpuAB == 5'b01100) //X start paste
bXp <= cpuDO;
if (lineCS && cpuAB == 5'b01101) //Y start paste
bYp <= cpuDO;
if (lineCS && cpuAB == 5'b01110) //border color
border <= cpuDO;
if (lineCS && cpuAB == 5'b10000) //horizontal offset
hoffset <= cpuDO;
if (lineCS && cpuAB == 5'b10001) //vertical offset
voffset <= cpuDO;
end
can be replaced by a more succinct:
// Register addresses
if ( lineCS )
case ( cpuAB [4:0] )
5'b00000: x0t <= cpuDO; //variables for line generator
5'b00001: y0t <= cpuDO;
5'b00010: x1t <= cpuDO;
5'b00011: y1t <= cpuDO;
5'b00100: xc <= cpuDO; //variables for circle generator
5'b00101: yc <= cpuDO;
5'b00110: rad <= cpuDO;
5'b00111: color <= cpuDO; //pixel color variable
5'b01000: bXlen <= cpuDO; //X length of blitter
5'b01001: bYlen <= cpuDO; //Y length of blitter
5'b01010: bXc <= cpuDO; //X start copy
5'b01011: bYc <= cpuDO; //Y start copy
5'b01100: bXp <= cpuDO; //X start paste
5'b01101: bYp <= cpuDO; //Y start paste
5'b01110: border <= cpuDO; //border color
endcase
Posted: Wed Dec 25, 2013 3:27 am
by player55328
hoffset <= cpuDO;
voffset <= cpuDO;
Are you not missing these in your new case statement?
I would suggest you add a default to your case statement just in case you get a situation you are not expecting.
Posted: Wed Dec 25, 2013 2:46 pm
by ElEctric_EyE
hoffset <= cpuDO;
voffset <= cpuDO;
Are you not missing these in your new case statement?...
Good eye! But I actually don't need those delay registers on my final output board.
...I would suggest you add a default to your case statement just in case you get a situation you are not expecting.
That seems to be a good practice, but I'm not sure how I would go about that in this case.
Posted: Wed Dec 25, 2013 3:53 pm
by MichaelM
When I read EEyE's post yesterday, I had the same thought initially, but I changed my mind.
First, the
if construction that he's using in a single
always block is correct. It could be expanded into 17 separate
always blocks and the structure would generate the expected logic behavior. That is, only when the condition is true is the register updated, and at all other times the register holds its last value.
Second, it is true that the
case statement in the second example, nested inside an
if statement, is missing the recommended
default clause that prevents the generation of inferred latches. However, since these two statements are inside a clocked
always block, there is no need to add the
default clause.
I also have the same thought. I generally include a
default clause to all
case statements, and in particular, to
case statements in combinatorial
always blocks. However, I think this is an example where that general recommendation is not appropriate. In my opinion, adding a
default clause to this case statement will reduce the readability of the code.
Posted: Wed Dec 25, 2013 6:14 pm
by Rob Finch
Just a note: I've found out that sometimes case statements provide better performance than if/else if statements. This is with the Webpack synthesis tools.
