Fleet Forth design considerations
JimBoyd
Re: Fleet Forth design considerations
Post by JimBoyd »
Fleet Forth has been revised since I last posted how it handles the text stream. This is how the current version of Fleet Forth handles the text stream.
First, Fleet Forth's QUIT loop.
Fleet Forth has a word WHERE which shows where an error occurred. The first thing WHERE does is store the address of EXIT in its first cell. This prevents recursive error handling if WHERE should cause an error; however, this means QUIT must restore the first cell of WHERE .
: QUIT  ( -- )
   [COMPILE] [
   BEGIN
         RP!                 // CLEAR RETURN STACK
         ['] LIT (IS) WHERE  // RESTORE WHERE
         CR QUERY INTERPRET
         STATE @ 0=
      CS-DUP UNTIL  // CONTINUE IF COMPILING
      ."  OK"
   AGAIN -;         // LOOP FOREVER
QUERY is the Forth-83 Standard word to read text from the input device (usually the keyboard) and store it in the text input buffer.
QUERY is the only word which places text in the text input buffer. Fleet Forth's QUERY has support for any word which may point TIB to an address other than the text input buffer by pointing TIB to the actual text input buffer before using TIB .
: QUERY  ( -- )
   'TIB IS TIB  TIB #80 EXPECT
   SPAN C@ #TIB !
   0 0
   LABEL BLK.2!
   BLK 2! ;
'TIB is a metacompiler macro which evaluates to $2A7, the address for the text input buffer.
BLK is actually a double variable. The first cell is normally accessed by words using BLK . >IN is a constant which points to the second cell of BLK . The ability to fetch the values of both BLK and >IN with a single 2@ and store both values with a single 2! results in a smaller Fleet Forth kernel.
QUERY uses EXPECT to read text into the text input buffer ( TIB ) and stores the value of SPAN in #TIB . EXPECT does not store a terminating zero byte.
QUERY then stores a zero in both BLK and >IN .
LOAD and LINELOAD .
: LINELOAD  ( LINE# BLK# -- )
   DUP 0=
   ABORT" CAN'T LOAD 0"
   BLK 2@ 2>R
   BLK !  C/L * >IN !
   INTERPRET  2R>
   BRANCH [ BLK.2! , ] -;
: LOAD  ( U -- )
   0 SWAP BRANCH
   [ ' LINELOAD >BODY , ] -;
LINELOAD aborts if the block to load is zero. For any other block number, LINELOAD saves the contents of BLK and >IN to the return stack. It then stores the block number on the data stack in BLK then multiplies the line number by C/L and stores that value in >IN . LINELOAD uses INTERPRET to interpret the contents of the block before restoring the previous contents of BLK and >IN .
LOAD places zero on the stack, swaps this number with the block number and branches to LINELOAD .
EVALUATE is a word in ANSI Forth which will interpret the contents of a string. It takes an address and the length of a string. I have found it to be a useful addition to the Fleet Forth system.
: EVALUATE  ( ADR CNT -- )
   TIB #TIB @ 2>R
   LIT [ >MARK ] ENTER
   0 0 LIT
   [ ' LINELOAD >BODY DUP TRUE
     " LOAD 0" COUNT MATCH ?HUH
   ENTER
   2R>
   [ >RESOLVE ]
   #TIB ! (IS) TIB ;
This source is for a very compact version of EVALUATE ; however, it is relatively straight forward. Save the contents of TIB and #TIB to the return stack. Point TIB at the string to be evaluated and save the string length in #TIB . Place two zeroes on the data stack and use ENTER to perform the equivalent of a GOSUB into the body of LINELOAD just past LINELOAD's inline error string "CAN'T LOAD 0." LINELOAD will save and restore the contents of BLK and >IN . Since EVALUATE supplies a block number of zero, INTERPRET will actually interpret the contents of the string pointed to by TIB and #TIB .
Finally, restore the original contents of TIB and #TIB .
INTERPRET interprets (and/or compiles) the text from the text stream. It exits when the text stream is exhausted. INTERPRET uses NAME which uses WORD to process strings from the text stream one blank delimited string at a time.
WORD uses 'STREAM to get the address and length of the remaining text stream.
: 'STREAM  ( -- ADR N )
   BLK @ ?DUP
   IF
      BLOCK B/BUF
   ELSE
      TIB #TIB @
   THEN
   >IN @
   OVER UMIN /STRING ;
'STREAM places the address of a block buffer and $400 on the data stack if a non zero block number is stored in BLK or it will place the address of the text input buffer and its length on the data stack.
'STREAM then duplicates the length of the text stream. The unsigned minimum of the length and the value of >IN is used with /STRING to return the address and length of the portion of the text stream which has not yet been processed. If the value of >IN is equal to or greater than the length of the text stream, the text stream has been exhausted and 'STREAM will return an address just past the text stream and a length of zero.
WORD uses 'STREAM so it has access to the address of the unprocessed portion of the text stream as well as the remaining length. WORD stores a string at HERE as a count byte followed by the text of the string and a trailing blank. The trailing blank is needed by NUMBER? .
Fleet Forth has no word called ENCLOSE . Fleet Forth's WORD uses two primitives named SKIP and SCAN . Both words take the address of a string, its length and a character (the delimiter). SKIP returns the address of the first character which is not the delimiter and the remaining length of the string. SCAN returns the address of the first delimiter encountered and the remaining length of the string. If SKIP only encounters delimiter characters or SCAN can not find a delimiter, the address just past the string and a length of zero is returned. Neither word alters the string. Both SKIP and SCAN can handle strings of arbitrary size.
The source for INTERPRET .
: INTERPRET
   BEGIN
      PAUSE NAME C@ 0EXIT
      HERE I/C
   AGAIN -;
PAUSE is the task switcher, which is set to NOOP when not multitasking. PAUSE is included in INTERPRET's loop to allow multitasking while the text stream is being interpreted.
There is no special word with a blank name to stop interpretation. If the text stream is exhausted, WORD returns a string with a length of zero. INTERPRET checks the length of the string and exits if it is zero.
If the length of the string is not zero, INTERPRET places the address of HERE on the stack for I/C , the word which interprets or compiles one word.
This is why Fleet Forth's text input buffer, block buffers and evaluated strings do not need a trailing zero.
JimBoyd
Post by JimBoyd »
In my post describing how Fleet Forth handles the text stream I did not show the source for Fleet Forth's WORD . I thought it might be a distraction. Here is the source for Fleet Forth's WORD .
2VARIABLE HISTORY
: WORD  ( C -- HERE )
   'STREAM                  \ Return address and count of remaining text stream.
   BLK 2@ HISTORY 2!        \ Save the contents of BLK and >IN to HISTORY.
   DUP >IN +!               \ Use count from 'STREAM to push >IN past text stream.
   2PICK SKIP               ( delimiter address count )
   ROT 2PICK -ROT SCAN      ( address address2 count2 )
   1- 0 MAX NEGATE >IN +!   \ Use count from SCAN to pull >IN to correct offset.
   OVER - >HERE ;
'STREAM returns the address and length of the remaining text stream.
After the history is saved for use by WHERE and THRU , >IN is set to point just past the text stream.
SKIP returns the address in the text stream of the sought after text and the length of the remaining text stream.
A copy of this address is saved under the address length and delimiter needed by SCAN .
SCAN returns the address of the delimiter after the sought after text and the length of the remaining text stream. One is subtracted from the length. The maximum of this value and zero is subtracted from >IN to put the offset past the delimiter but no further than the end of the text stream.
All that remains are the addresses of the start of the sought text and the address of the delimiter after the sought text. These are converted to the address and count.
Before >HERE is executed, the address of the string and count are on the stack. The address in the text stream, just like Ansi Forth's PARSE-WORD .
>HERE stores this string at HERE as a counted string with a trailing blank. >HERE is a code word for speed.
I could have defined WORD like this:
2VARIABLE HISTORY
: PARSE-WORD  ( C -- ADR CNT )
   OVER - ;
   PARSE-WORD >HERE ;
However, I saw no need for PARSE-WORD . Fleet Forth's find primitives require the address of a counted string rather than the address of a string and a count and CREATE needs a counted string at HERE .
Fleet Forth's 'TEXT returns the address of the string in the text stream and the length. It is like Ansi Forth's PARSE with one difference. If the delimiter is not found in the text stream 'TEXT aborts with an error message.
: 'TEXT  ( C -- ADR CNT )
   DUP>R LIT [ HERE >A 0 , ] C!  \ Store delimiter in ABORT" string.
   'STREAM 2DUP R>               ( ADR LEN ADR LEN C )
   SCAN 0=                       ( ADR LEN ADR2 FLAG )
   [ HERE 3 + A> ! ]             \ If text stream exhausted after SCAN
   ABORT"   MISSING"             \ then the delimiter was not found
   NIP OVER -                    ( ADR CNT )
   DUP 1+ >IN +! ;
'STREAM returns the address and length of the remaining text stream. A copy of the delimiter is stored in the inline string used by ABORT" . After SCAN executes, the address and length 'STREAM placed on the data stack is still there as well as the address of the first occurrence of the delimiter and the length of the text stream after this point. If this length is zero, the delimiter was not found so abort with an error message.
The length returned by 'STREAM is no longer needed so it is NIPped off the data stack and the two addresses are used to calculate the length of the string returned by 'TEXT . A copy of this length plus one is added to >IN .
[Edit: Corrected an error.]
JimBoyd
Post by JimBoyd »
An error in one of the machine states in a demo for A Finite State Machine Engine in Forth revealed a shortcoming in Fleet Forth's error handling.
My initial assumption was that words run as background tasks would be fully debugged before set as background tasks. That assumption was in error. When a background task is a word to run through a list of finite state machines, every machine state for every machine installed must be error free. Ideally, a finite state machine should be fully tested before it is installed as one of the machines running in the background, but mistakes do happen.
I've improved Fleet Forth's error handling. Since error reporting uses WHERE to report the location of the error, WHERE was modified to include SINGLE and UNLINK .
: WHERE
   ['] EXIT (IS) RECURSE
   SINGLE UNLINK            \ <- This line was added to switch
                            \ off multitasking and reset
                            \ the user pointer and user area's
                            \ first six user variables.
   HISTORY 2@ TUCK  BLK 2!
SINGLE switches off multitasking and UNLINK points UP (the user pointer) back at the main user area and resets the first six user variables to their boot-up values from the boot area. This causes the main user area's ENTRY to point back to itself, make sure the main task is awake and reset the default stack bases for the return, data, and auxiliary stacks.
With these changes, an ABORT" in one of the machine states for a finite state machine running in the background no longer causes problems in Fleet Forth.
JimBoyd
Post by JimBoyd »
One version of the Finite State Machine Engine runs the chain of state machines in the background as a background task. It had the word FSM to initialize the background machine chain and link it into the loop of round robin tasks.
: FSM  ( -- )
   [ ' <FSM> >BODY ] LITERAL
   BACKGROUND-MACHINE-CHAIN ACTIVATE
   BACKGROUND-MACHINE-CHAIN LINK-TASK
   MULTI ;
This word could not be executed more than once or the task for the background machine chain would be linked more than once, breaking the loop. I saw this as a design flaw in Fleet Forth's multitasker so I fixed it.
I added the word LINKED? to test if a task is already linked. Rather than burden the user with testing if a task is linked, I added this word to LINK-TASK , the word which links tasks. If a task is already linked, LINK-TASK does not try to link it again. It is idempotent.
: LINKED?  ( TADR -- FLAG )
   ENTRY
   BEGIN
      @ DUP 2PICK <>
   WHILE
      DUP ENTRY =
   UNTIL
      0=
   THEN
   0<>  NIP ;
: LINK-TASK  ( TADR -- )
   DUP LINKED?
   IF  DROP EXIT  THEN
   ENTRY 2DUP @ SWAP! ! ;
JimBoyd
Post by JimBoyd »
JimBoyd wrote:
Here is DOWN-COUNTER for Fleet Forth.
: DOWN-COUNTER
   2VARIABLE  ( -- )
   DOES>  ( -- ADR )
      JIFFY@ DROP
      OVER 2+ @
      OVER -  0 MIN
      2PICK +!
      OVER 2+ ! ;
That '0 MIN' is to handle the case when the jiffy timer resets to zero when it reaches twenty four hours.
A down-counter, a child word of DOWN-COUNTER , has two cells of storage. The first cell holds a value. The second cell holds the low cell of the Commodore 64 jiffy clock from the last time the down-counter was executed. Each time a down-counter is executed the amount of time, in jiffies, which passed from the last time is subtracted from the value in the first cell.
DOWN-COUNTER DELAY1 OK
300 DELAY1 ! OK
DELAY1 ? 209  OK
DELAY1 ? 118  OK
DELAY1 ? 5  OK
DELAY1 ? -445  OK
Of course, the values returned each time I type "DELAY1 ?" depends on how long I wait.
Here is a slightly improved version of DOWN-COUNTER .
: DOWN-COUNTER
   2VARIABLE  ( ++ )
   DOES>  ( -- ADR )
      JIFFY@ DROP           \ Only need low cell of jiffy clock
      OVER 2@ SWAP 2PICK -  \ new.time value -delta.time
      0 MIN                 \ Compensate for reset at midnight.
      +  2PICK 2! ;         \ add negative time difference to
                            \ old value and store new time
                            \ and new value to down-counter
                            \ variable and leave address.
JIFFY@ leaves the value of the Commodore 64 jiffy clock on the stack as a double number. Yes the jiffy clock resets to zero after twenty four hours.
2PICK is syntactically equivalent to 2 PICK .
CODE 2PICK  ( N1 N2 N3 -- N1 N2 N3 N1 )
   4 ,X LDA  5 ,X LDY
   AYPUSH JMP  END-CODE
A DOWN-COUNTER is used when some code is run periodically, but there is a portion which must be run less often.
DOWN-COUNTER DELAY
   DOWN-COUNTER @ 0<          \
   IF                         \ If this code fragment is run often enough
      #3600 DOWN-COUNTER !    \ <DO.SOMETHING> only runs
      <DO.SOMETHING>          \ once a minute.
   THEN                       \
JimBoyd
Post by JimBoyd »
Fleet Forth is not a multi user Forth system. It was designed for one person to use at a time on a Commodore 64. Fleet Forth supports multitasking with background tasks. With this in mind the Fleet Forth system has only ten user variables. More user variables can be added.
The user area for the foreground task is not part of the loadable image, it is in a section of unused memory on the Commodore 64; therefore, the first eight user variables need initialized at bootup. Fleet Forth's boot area holds the bootup values for the first seven user variables.
ENTRY  -- Points to next task's user area or itself if no other tasks.
READY  -- Flag. TRUE - task is awake. FALSE - task is asleep.
TOS    -- Holds the return stack pointer when a task is switched out.
RP0    -- Base of return stack.
SP0    -- Base of data stack.
AP0    -- Base of auxiliary stack.
DP     -- Dictionary Pointer.
The first six user variables are initialized by the word UNLINK , which also sets the user pointer UP to the address of the foreground task's user area. This unlinks all background tasks and restores control to the main task. UNLINK is included in a routine included in the coldstart and warmstart routines.
The word EMPTY initializes DP from this bootup area and branches into the body of FORGET to handle any necessary pruning. EMPTY is included in the coldstart routine.
These are the next three user variables:
BASE   -- Base for numeric conversion to or from text.
DPL    -- Decimal place.
HLD    -- Holds the address for the next character during conversion
          from text to a double number.
DECIMAL , which sets BASE to decimal, is included in the routine which is included in the coldstart and warmstart routines.
DPL and HLD are not initialized during coldstart or warmstart. It is not required. NUMBER? initializes DPL and <# initializes HLD .
The Fleet Forth system has only ten user variables. The other variables in the system are not user variables as they should not be needed in background tasks.
As I mentioned, Fleet Forth allows the defining of new user variables. The word for this is USER . It takes a number and is followed by a name.
<USER.AREA.OFFSET> USER <NAME.OF.USER.VARIABLE>
For example:
#20 USER STOOGES
To make defining new user variables easier (some may be defined in different sources), Fleet Forth has a 'system value' or 'soft constant' #USER .
The source for Fleet Forth's USER .
: USER  ( N -- )
   DUP 2+ #USER UMAX (IS) #USER
   CREATE C,
   ;CODE  ( -- N )
      2 # LDY  CLC
      W )Y LDA  UP ADC
      UP 1+ LDY  CS IF  INY  THEN
      AYPUSH JMP  END-CODE
If #USER has the value #20, the following:
#USER USER LARRY
#USER USER CURLY
#USER USER MOE
will create the user variable LARRY with the user area offset #20, the user variable CURLY with the user area offset #22, and the user variable MOE with the user area offset #24.
To set aside more of the user area for a particular user variable, the following can be done.
#USER USER LAUREL
#USER 8 + USER HARDY
This will 'allot' eight more bytes in the user area for the user variable LAUREL .
JimBoyd
Post by JimBoyd »
JimBoyd wrote:
I've just streamlined DJIFFIES , the word that takes a positive double number and waits that many jiffies ( 1/60th of a second on the Commodore 64 ) . It is also used by JIFFIES , the word that takes an unsigned single number and waits that many jiffies.
DJIFFIES works by keeping the number of jiffies to delay on the stack as well as the latest jiffy clock value. Each time through the loop, it subtracts the difference from the amount of time to wait. The idea came from DOWN-COUNTER on page 130 ( 140 of the PDF ) in the book Real Time Forth by Tim Hendtlass.
When I was testing my multitasker, I noticed that the loop in DJIFFIES runs several times per jiffy. With three background tasks, two using DJIFFIES ( actually JIFFIES ) for a delay and one counting how many times it runs, the entire round robin runs several times a jiffy. I realized that when the difference between the current jiffy clock value and the previous one is subtracted from the amount of time to delay, either 0 or -1 is added to the remaining time. I only needed to use the lower cell of the jiffy clock value. Here is the code:
SCR# 41
// DJIFFIES
HEX
// TAKES POSITIVE DOUBLE NUMBER
// AND DELAYS THAT MANY JIFFIES
: DJIFFIES  ( D+ -- )
   JIFFY@ DROP
   BEGIN
      PAUSE
      JIFFY@ DROP  DUP>R -
// COMPENSATE FOR RESET AT 24 HOURS
      0 MIN
      S>D D+  R> OVER 0<
   UNTIL
   DROP 2DROP ;
SCR# 42
// JIFFIES
HEX
: JIFFIES  ( U -- )
   0 DJIFFIES ;
JIFFIES takes an unsigned number and has a maximum delay of:
18 minutes 12 seconds and 15 jiffies.
DJIFFIES takes a positive double number and has a maximum delay of:
414 days 6 hours 3 minutes 14 seconds and 7 jiffies or
2,147,483,647 jiffies.
Because DJIFFIES waits until the count goes negative, DJIFFIES and JIFFIES wait one jiffy more than what is requested. Not a big problem. There is an easy solution. Just subtract one from the initial value returned by JIFFY@ DROP .
// DJIFFIES JIFFIES
   JIFFY@ DROP 1-
   BEGIN
      PAUSE
      JIFFY@ DROP  DUP>R -
      // COMPENSATE FOR DAILY RESET
      0 MIN
      S>D D+  R> OVER 0<
   UNTIL
   DROP 2DROP ;
: JIFFIES  ( U -- )
   0 DJIFFIES ;
Now DJIFFIES and JIFFIES will wait the requested number of jiffies.
Note: // (double forward slash) is a Commodore 64 Forth alias for \ (backslash) .
JimBoyd
Post by JimBoyd »
In a previous post I showed the source for Fleet Forth's word USER , the word to create new user variables. I also mentioned #USER. The only user variables I've ever defined other than the ones defined in the kernel are the three user variables used for multitasking. They have the offsets 0, 2, and 4.
0 USER ENTRY   2 USER READY
4 USER TOS
Other than these three, I have never defined new user variables; therefore, I simplified the source for USER and removed #USER from Fleet Forth's kernel.
: USER  ( N ++ )
   CREATE
      C,
   ;CODE  ( -- ADR )
      2 # LDY  CLC
      W )Y LDA  UP ADC
      AYPUSH JMP  END-CODE
I also had to change the source for the multitasker's task creation word TASK .
// TASK CREATION AND ACTIVATION
: TASK  ( U AP0 SP0 RP0 -- )
   CREATE
        ( -- TADR )
      HERE RP0 LOCAL !
      HERE SP0 LOCAL !
      HERE AP0 LOCAL !
      [ ' STOP >BODY ] LITERAL
      HERE ACTIVATE
      // OPTIONAL
      #10 HERE BASE LOCAL !
      [ 0 HLD LOCAL 2+ ] LITERAL
      HERE +  HERE DP LOCAL !
      #12 UMAX ALLOT ;
Note that HLD is the last user variable defined in the kernel. It has an offset of eighteen. The line
compiles a literal decimal twenty. Since there are a total of ten user variables, this points the task's DP just past the area used by the last user variable. Setting a task's DP to point twenty bytes into a task's user area is done so data stored at a background task's HERE will not overwrite any of the task's user variables.
JimBoyd
Post by JimBoyd »
JimBoyd wrote:
Here is my find and replace function.
: FR
   BEGIN F R AGAIN ; -2 ALLOT
There was one flaw in the editor word FR . As I mentioned, FR can be used to find all occurrences of a given string in a screen and replace them.
FR HEX^DECIMAL
and used in another screen without specifying the strings to perform the same search and replace.
FR
When the editor word F searches for a string, it first parses the text stream for a search string delimited by the caret character to place in the find buffer. If the text stream is exhausted, the old search string remains in the find buffer. Whatever string is in the find buffer is used for the search. Likewise, the editor word I , which is used by R , parses the text stream for a string to insert and places this string in the insert buffer.
If the search string was not found when FR was used with the search and replacement strings specified, the replacement string was never placed in the insert buffer. When FR was then used without specifying the search and replace strings, the string to be found would be replaced with garbage (whatever was in the insert buffer).
The following improvement to FR places the search string in the find buffer and the replacement string in the insert buffer before the first search attempt.
: FR
   >FBUF  >IBUF
   BEGIN  F R  AGAIN -;
>FBUF and >IBUF are the words which parse the text stream and place a string in the find buffer and insert buffer respectively.
With this modification, I no longer have a problem with FR .
Unlike S , F ( find) and R ( replace) are limited to one screen at a time. If F can't find the string it aborts. I'm changing that to QUIT so it will not clear the data and auxiliary stacks.
I made that change.
JimBoyd
Post by JimBoyd »
Fleet Forth is an ITC Forth for the Commodore 64 and has to compensate for the indirect jump bug; therefore, when I mentioned defining multi code field words with Fleet Forth, I mentioned a word named CFA-ALIGN to make sure the other CFA's of a multi code field word don't straddle a page boundary by forcing an even address alignment for these CFA's by adding a pad byte before the header is created. The need to define CFA-ALIGN whenever I wished to experiment with adding an extra Code field or two contributed to my reluctance to add extra code fields.
This will no longer be a problem. Fleet Forth's CREATE would compute the address of the yet to be created word's code field. If the code field would start on an address ending in $FF, it would allot a byte before creating the header. This test in CREATE has been modified so that if the CFA would start on an address ending in $FF, $FD, $FB, $F9 or $F7 CREATE will allot a byte before the header is created.
Removing the out of memory check from the code below for clarity, the old test was something like this:
Compute the address of the code field.
   HERE COUNT + 2+  VIEW @ TUCK
   IF  2+  THEN
and allot one byte if it ends with $FF.
   1+ SPLIT DROP
   0= ABS ALLOT
The code to compute the address of the code field is unchanged.
   IF  2+  THEN
but the test is now this.
   DUP 9 + SPLIT DROP
   9 U< AND  2 MOD ALLOT
This change only added twelve bytes to CREATE . Fleet Forth can now support words with up to five code fields without the need to perform any address check other than what CREATE now does.
I think three code fields are typical with multi code field words. Supporting five gives a little extra just in case.
There is one other case where the improved CREATE is helpful. When modifying Blazin' Forth's utilities for Fleet Forth, it was necessary to test the body of the variable SYSIRQ for page crossing.
HEX
// BUG FIX
" SYSIRQ" C@ HERE + 1+
2+ 2+         // SIZE OF LINK
              // & CODE FIELDS
SPLIT DROP 0FF = // WILL PFA BE ON
              // PAGE BOUNDARY?
ABS ALLOT     // IF SO BUMP IT PAST
VARIABLE SYSIRQ
The variable SYSIRQ is used to hold the address of the last part of the Commodore 64's interrupt service routine which is vectored through address $314. Blazin' Forth's interrupt service routine jumps to the Commodore 64's routine by indirectly jumping through the parameter field of the variable SYSIRQ . If this address straddles a page boundary, the indirect jump bug strikes.
With Fleet Forth's new CREATE , the test before defining SYSIRQ is no longer needed.
I lay the name field down first, and then do ALIGN which makes sure the LFA, CFA, and PFA are aligned.  It probably makes L>NAME a little more complex, but I allow characters above $7F anyway for the special characters in the DOS/ANSI (code page 437) characters, and it makes CREATE a little simpler.
JimBoyd
Post by JimBoyd »
If roughly half the words would have a code field on an odd address then those half would need an extra byte. On a system with lots of words, that's a lot of bytes.
The fields of a word in Fleet Forth are in the following order: Link field, Name field, Code field and Parameter Field. A word's link field points to the previous word's link field.
Since the last-compiled word tends to be an unnest (compiled by ;) and word-aligned, the beginning of my name fields is almost always aligned; so in that case, there are many cases when I know I can add another letter to the name if I want to, if it would make it more descriptive, without any memory penalty.
JimBoyd
Post by JimBoyd »
In Fleet Forth nothing is word aligned. The only address adjustment is to make sure a page boundary is not straddled by the code field, and now the next four cells, of a word. I've not had any problems in Fleet Forth due to this lack of alignment.
JimBoyd
Post by JimBoyd »
JimBoyd wrote:
I've removed the words <LIST <L LIST> L> and their editor words 0[ through F[ and 0] through F] because they were unsatisfactory.
I also mentioned a solution which seems satisfactory.
A new LIST word which use an editing window VALUE for a displacement to the right, EW , and a corresponding set of editing words 0[ through F[ which also use EW.
I must admit I have not been using this new Fleet Forth screen editor.
When I was trying to figure out how to implement the IsoPod's finite state machine engine, I was writing ideas in a regular text file on my computer. When I had something which seemed to be going in the right direction, I copied and pasted it into VICE, the Commodore 64 simulator rather than copy it to screens on blocks. I have since then gotten into the habit of just pasting code I want to test into the simulator and using plain text files for source. The simulator treats pasted text as if it is being typed in at the keyboard, which is why I wrote PURGE .
It seems for big things, like the source for Fleet Forth or the system loader and utilities, I still use screens in blocks (the simulator can not handle having the entire source for Fleet Forth's kernel pasted in at one time). For small projects I have been using text files.
The backslashes in the source for the Finite State Machine Engine in Forth were not added just for posting the source. A backslash pasted into VICE appears as the pound character so I defined a word with the backslash character as the name. This word is an alias for Fleet Forth's double forward slash ( // ).
