Page 3 of 3
Re: Old Guy with Special Case Need to Divide by Three
Posted: Tue Feb 27, 2024 8:37 pm
by teamtempest
teamtempest wrote:
I only worked out one random example by hand. Kind of a distributed division:
<snip>
; adjust by hi byte
ldx dividend+1
clc
adc factor,x
factor:
.byte 0*85, 1*85, 2*85
$1FF aka 511 is a special case you will need to handle...
I thought you must be right, because you tested far more extensively than I did. Without that I thought it was possible something might be off.
But if I work it out by hand I get the correct result:
511 = %01 1111 1111
511/3 = 170
x(lo) = 255 = %1111 1111
x(lo)/3 = 85 = %0101 0101
x(hi) = 1 = %01 (so add 85)
85 + 85 = 170
Is there a mistake? A carry bit threw the calculation off somewhere?
Posted: Tue Feb 27, 2024 9:42 pm
by BruceRMcF
Is the following significantly smaller than a 756 byte look-up table?
Just look at the final assembly address (+1 since the origins are all $xx00) of each snippet to see vs $2F4.
2100: $21
2200: $2A
2300: $3A
2400: $2D
2500: $37
2600: $49
2700: $17
2800: $34
Seems like all of them would be.
2000 00532 org FreeRAM
2000 00534 DIVIDE_BY_THREE:
2025 60 [6] 00572 rts
2100 00574 org FreeRAM+$100
2100 00585 div3_ay:
2120 60 [6] 00616 rts
2200 00618 org FreeRAM+$200
2200 00651 Mine:
220D 4C 2213 [3] 00663 jmp EnterLoop
2229 60 [6] 00692 rts
2300 00694 org FreeRAM+$300
2300 00696 BB8:
2335 60 [6] 00735 rts
2400 00737 org FreeRAM+$400
2400 00739 OptimizedBB8:
242C 60 [6] 00773 rts
2500 00775 org FreeRAM+$500
2500 00780 ModifiedBB8:
2536 60 [6] 00825 rts
2600 00827 org FreeRAM+$600
2600 00829 MineTabled:
262D 60 [6] 00870 rts
2634 60 [6] 00879 rts
00880
2635 00 00 00 01 01 01 00881 MyTable ...
2647 06 06
2700 00883 org FreeRAM+$700
2700 00889 div3:
2716 60 [6] 00906 rts
2800 00908 org FreeRAM+$800
2800 00917 ModifiedBB8_plus_teamtempest:
2834 60 [6] 00968 rts
Posted: Tue Feb 27, 2024 10:06 pm
by BillG
511 = %01 1111 1111
511/3 = 170
85 + 85 = 170
You are right about 511. Faulty analysis on my part.
Now try 513 and 514 with your method...
Posted: Tue Feb 27, 2024 10:09 pm
by BillG
That last one is the test driver and not a candidate division subroutine.
Posted: Tue Feb 27, 2024 11:06 pm
by BB8
Further optimized... I'm using your suggested one byte DivBy3. And no loops anymore, only code going forward.
Now it should be at 49-67 +rts cycles when adopting zeropage variables.
ldy nl
lda nh ; loads high byte
beq lv ; if zero then goes to low byte value
; otherwise will sub 255 from low byte and add 85 to res
; one or two times
iny ; subtracts 255 from low byte
beq hv1 ; if zero, high byte is not done
cmp #1 ; checks high byte
beq hv2 ; if zero, high byte is done
hv1 lda #170 ; .A = 2 x 85 (partial quotient)
byte $2c ; *** the wonderful bit/$2c trick!! my first time... ***
hv2 lda #85 ; .A = 85 (partial quotient)
sty nl
lv ; here value is <256 (only low byte)
sta res
tya
lsr
adc #21
lsr
adc nl
ror
lsr
adc nl
ror
lsr
adc nl
ror
lsr
clc ; adds the partial quotient from the upper byte
adc res
sta res
rts
res byte 0
nl byte <726
nh byte >726
Posted: Tue Feb 27, 2024 11:12 pm
by BillO
Gotcha.
Posted: Wed Feb 28, 2024 12:15 am
by barrym95838
You added nine or ten bytes to mine, depending on how you look at it.
Posted: Wed Feb 28, 2024 2:49 am
by BruceRMcF
Definitely added some. $20 instead of $17 would be adding 9.
Posted: Wed Feb 28, 2024 7:17 pm
by WynnSmith
Your input here is more than I could ask for. A 'Thank you' seems inadequate. Nevertheless, thank you.
Posted: Thu Feb 29, 2024 12:21 am
by fachat
I haven't closely followed I'm afraid but has this division algorithm been discussed so far?
https://www.bbcelite.com/deep_dives/shi ... ision.html
Robin from YouTube's 8bit show and tell has pointed to it on Twitter/X
https://twitter.com/8BitShowAndTell/sta ... 9530750115
In its division-by-10 variant, but I believe it can be adopted to division-by-3.
André
Posted: Thu Feb 29, 2024 3:13 am
by barrym95838
That's almost exactly what
mine is doing. The smallest and slowest of the bunch.
Posted: Thu Feb 29, 2024 9:33 am
by fachat
Haha, I was almost expecting this, that you guys already know all that
Great stuff!
Posted: Thu Feb 29, 2024 9:34 am
by fachat
What I like about the bbcelite division algorithm is that it is very small - and that it can be adopted to other argument sizes (and divisors) easily. I find that very neat.
Posted: Mon Apr 22, 2024 6:17 am
by Hermes
Hello!
I hope, I am not too late with my answer.
You can multiply the lower 8 bits of your 10 bit number by 171 and take the lower 8 bits of the result.
You don't even have to calculate the upper byte.
You can ignore the upper 2 bits of your 10 bit number. That works, because your numbers are a multiple of 3.
Use the fastest multiplying by 171 algorithm that you can come up with. (a 256 byte lookup table would work)
To divide by 5 you multiply your lower 8 bits by 205 and throw away the upper byte. (your input must be a multiple of 5)
