Garth/Ed:
Thanks very much for the replies. I can assume then that an unsigned mixed precision instruction/subroutine/primitive might be helpful to implement.
I typically work with fixed point signal processing algorithms. As such, I hardly ever use the lower half of a signed/unsigned multiplication product. The results that I'm after are almost always contained in the upper half of the product.
Since I tend to build these functions in custom hardware, I tend to forget about the fact that all HLL languages have no support for multiplication in the sense that I require. Even on the MIPS architecture, most languages return the lower half of the product even though a dedicated register is provided that holds the upper half of the product.
Perhaps I've never properly used casting to get the proper product. Invariably to make the code work properly in an HLL, I've always had to cast the multiplier and multiplicand into next larger integer size. This tends to generate a bigger product which is not directly supported which generates library calls, etc. etc.
(-0.5)*(-0.5) = 0.25 <=> (-128/256)*(-128/256) = (16384/65536)
UM* (multiplication) bug in common 6502 Forths
Re: UM* (multiplication) bug in common 6502 Forths
Ed:
Thanks for the pointer to that article; pulled it down for later reading.
Somewhere in my stash of stuff I have some 6809 databooks and other what nots from th 80's. I may look for them this week. There may be some ideas to glean in the referenced article for a new project.
Michael A.
I knew of a U/ bug in 6502 fig-forth (it was well publicized) but never heard of issues with U*. This prompted some digging. There's a discrepancy in the U* code published in the Fig Installation Manual (Nov 1980) and what's contained in Fig 6502 Rel 1.1 asm listing (Sep 1980) from http://www.forth.org/fig-forth/contents.html
Below is a chart comparing the code for U* U/ found in several '6502 fig-forth'.
; U* U/ code comparison for 6502 Fig-Forth
; FIG INST MANUAL 6502 Rel 1.1 ASM HES 64FORTH AIM-65 FORTH
CODE U*
SEC LDA, LDA 2,X LDA 2,X LDA 2,X
N STA, STA N STA N STA N
SEC STY, STY 2,X STY 2,X STY 2,X
SEC 1+ LDA, LDA 3,X LDA 3,X LDA 3,X
N 1+ STA, STA N+1 STA N+1 STA N+1
SEC 1+ STY, STY 3,X STY 3,X STY 3,X
16 # LDY, LDY #16 LDY #16 LDY #16
BEGIN, L396 L84DC LB464
BOT 2+ ASL, ASL 2,X ASL 2,X ASL 2,X
BOT 3 + ROL, ROL 3,X ROL 3,X ROL 3,X
BOT ROL, ROL 0,X ROL 0,X ROL 0,X
BOT 1+ ROL, ROL 1,X ROL 1,X ROL 1,X
CS IF, BCC L411 BCC L84FB BCC LB483
CLC, CLC CLC CLC
N LDA, LDA N LDA N LDA N
BOT 2 + ADC, ADC 2,X ADC 2,X ADC 2,X
BOT 2 + STA, STA 2,X STA 2,X STA 2,X
N 1+ LDA, LDA N+1 LDA N+1 LDA N+1
BOT 3 + ADC, ADC 3,X ADC 3,X ADC 3,X
BOT 3 + STA, STA 3,X STA 3,X STA 3,X
CS IF, BCC L84FB BCC LB483
BOT INC, LDA #0 INC 0,X INC 0,X
0= IF, ADC 0,X BNE L84FB BNE LB483
BOT 1+ INC, STA 0,X INC 1,X INC 1,X
ENDIF, ENDIF, ENDIF, L411 L84FB LB483
DEY, DEY DEY DEY
0= UNTIL, BNE L396 BNE L84DC BNE LB464
NEXT JMP, JMP NEXT JMP NEXT JMP NEXT
CODE U/
STY N+1
SEC 2 + LDA, LDA 4,X LDA 4,X LDA 4,X
SEC LDY, LDY 2,X LDY 2,X LDY 2,X
SEC 2 + STY, STY 4,X STY 4,X STY 4,X
.A ASL, ASL A ASL A ASL A
SEC STA, STA 2,X STA 2,X STA 2,X
SEC 3 + LDA, LDA 5,X LDA 5,X LDA 5,X
SEC 1+ LDY, LDY 3,X LDY 3,X LDY 3,X
SEC 3 + STY, STY 5,X STY 5,X STY 5,X
.A ROL, ROL A ROL A ROL A
SEC 1+ STA, STA 3,X STA 3,X STA 3,X
16 # LDA, LDA #16 LDA #16 LDA #16
BEGIN, L433 L8520 LB4A6
SEC 2 + ROL, ROL 4,X ROL 4,X ROL 4,X
SEC 3 + ROL, ROL 5,X ROL 5,X ROL 5,X
ROL N+1 PHP
SEC, SEC SEC SEC
BOT SBC, SBC 0,X SBC 0,X SBC 0,X
TAY, TAY TAY TAY
BOT 1+ SBC, SBC 1,X SBC 1,X SBC 1,X
PHA BCC LB4BF
LDA N+1 STY 4,X
SBC #0 STA 5,X
LDA #0 PLP
STA N+1 SEC
PLA BCS LB4C6
LB4BF PLP
CS IF, BCC L444 BCC L8540 BCC LB4C6
SEC 2+ STY, STY 4,X STY 4,X STY 4,X
SEC 3 + STA, STA 5,X STA 5,X STA 5,X
THEN, L444 L8540 LB4C6
SEC ROL, ROL 2,X ROL 2,X ROL 2,X
SEC 1+ ROL, ROL 3,X ROL 3,X ROL 3,X
N DEC, DEC N DEC N DEC N
0= END, BNE L433 BNE L8520 BNE LB4A6
POP JMP, JMP POP JMP POP JMP POP
Bill Ragsdale wrote:
Most vendors who follow the FIG Model have corrected this and several other problems (carry problems in U* and U/, expanding buffer size to 1024 bytes and Y register range in ENCLOSE). These updates point out the advantage of software products with vendor support, additional testing and review. The self installed FIG system has had remarkable acceptance, but it cannot supplant the broader resources of commercial offerings.
- GARTHWILSON
- Forum Moderator
Forum member TobyLobster has done extensive work comparing over 60 6502 integer multiply methods, and done a great compilation at https://github.com/TobyLobster/multiply_test . The original post is at viewtopic.php?f=2&t=7451 .
