cjs wrote:
You might consider using Amtel 28C256 or similar EEPROMs, which require no special voltages to program, just the usual +5 V. (You can even program them in-system, though you want to make sure you're not running code from it when you do so).
daniMolina wrote:
I really think you should practice your soldering. It seems all your issues come from this...
daniMolina wrote:
It's a shame to damage hard to find components or equipment, and it gives you that sensation of failed objectives...
The most important lesson I've learnt in this world is, never do any work if you're tired, or not fully concentrated. Errors pile up at at amazing pace if you do.
daniMolina wrote:
Also, triple check everything before powering up. This will save you a lot of problems and frustration along the way.
As hobbyists, we are here to have fun.
