resman makes a good point I should have mentioned:
Cowgol 2.0 compiler for the 6502
- GARTHWILSON
- Forum Moderator
Re: Cowgol 2.0 compiler for the 6502
hjalfi wrote:
But the downside is that I can't index anything on the stack [...] I also can't dereference pointers, and access to local variables in outer scopes becomes impossible
Then why not just put the parameters directly into their memory locations instead of pushing/popping the values through the stack intermediary?
@resman: Cowgol 1.0 did that! I couldn't make it work. The problem is compiling code like this:
Because function1 and function2 can share the same address for their locals, then we marshal the 1 and 2 into function1's parameters and then immediately overwrite them with the 3 and 4 for function2's parameters before function1 gets called. The same happens with this:
I could marshal the parameters into temporaries and then copy them into the function parameters just before the call, but if I'm doing that I might as well stack them --- pla and pha are really cheap one-byte instructions. It's worth spending less in the caller (which happens frequently) and instead spending more in the callee (which happens once).
A similar problem happens with return parameters where the values have to be copied to local storage rather than used in-situ in case they get overwritten by a subsequent call to a different function.
If, BTW, anyone has a clever solution then I'm all ears...
function1(1, 2, function2(3, 4));
function1(1, 2, function1(3, 4))
- GARTHWILSON
- Forum Moderator
Stacks solve those problems. Functions will not step on calling functions' pending parameters. A subroutine's local variables will reside on the stack(s), indexed the same way every time even though the actual addresses may be different each time, depending on how deeply it's nested in the pile of subroutines calling other subroutines. The same concept automatically accommodates recursion.
Hmm, I get it. The calls to function1 and function2 don't exist in the call stack simultaneously, so their parameters and locals can overlap in storage if they are assigned statically.
But the calling function's locals should be arranged to be disjoint from both called functions. Those locals include all temporaries, including the temporarily-stored return value of function2. You should then be able to organise the parameters of function1 so that they stay out of functions2's space until the latter has returned.
It seems obvious to me that storage assignment should begin with leaf functions and move down from there. Leaf functions have no dependencies, so the choice of local storage is free; you might as well stuff it at one end of the space available. Then calling functions have a free choice of storage except for that used by any of their callees.
hjalfi wrote:
I'm actually doing static variable allocation; by analysing the call graph of the program, I can assign every variable and every expression evaluation temporary an address. If two subroutines are never called at the same time their variables can overlap --- there's never any conflict, and I can prove this at link time. This is the big win of forbidding recursion: many of these old CPUs make stack frames really painful.
I would make a set of simple rules to map a function's parameters, locals, and return values. For instance:
function address + 0: JMP *+sizeof(parameters+return values+locals)
function address + 3: parameters
function address + 3 + sizeof(parameters): return values
function address + 3 + sizeof(parameters + return values) : locals
function address + 3 + sizeof(parameters + return values + locals) : function code
Something to consider.
Then you only need to know the address of the function, the number of parameters and the number of return values. You can easily use function pointers, as all the parameters and return values are offset from the actual function address. It may seem wasteful to start off the function with a JMP over it's variables storage, but this hides the amount of local storage/temporaries used by the routine. If you notice, this is actually hard-coding the frame stack into the function itself.
Is there a particular reason the entry point must come first? If not, you can do away with that jump...
"function address": parameters
"function address" + sizeof(parameters): return values
"function address" + sizeof(parameters + return values) : locals
"function address" + sizeof(parameters + return values + locals) : function entry point
function address" + sizeof(parameters + return values) : function entry point
<code>
"function address" + sizeof(parameters + return values + code) : locals
JSR func1
params:
param1 DW 0
param2 DW 0
retvals:
retval1 DW 0
... continue code
Are you sure you don't want to implement a frame stack? PLASMA limits the per-function framesize to ~250. That way it can easily access the locals with just an 8 bit index register.
@resman: Right. It took me ages to see that the first time round. Once you start accessing the subroutine's parameters outside the scope of the subroutine, you're effectively extending the lifetime of the parameters to when you start evaluating the first parameter, rather than just when the jsr to the subroutine happens. Because calls can overlap, this means we have no choice but to deal with cases when we have two different values destined for the same parameter at the same time. So, they have to be marshalled into local storage somehow. Cowgol 1.0 marshalled them into static storage, but this was really expensive --- two or three bytes per byte. The processor stack is much cheaper --- one byte per byte, and less if I can copy stuff in and out with loops. As @GARTHWILSON says, stacks are ideally suited for this kind of problem.
I'm not averse to using stacks --- I just don't want to use stack frames, as they're expensive on 8-bit systems and make it very hard to access variables from an outer scope, which I need to do to make nested subroutines work.
Regarding the problems indexing things on an auxiliary stack: the compiler makes extensive use of the (zp),y and abs,x addressing modes. As pointer variables are statically assigned to zero page, then dereferencing them is extremely cheap. If the variables were kept on an auxiliary stack I would need to copy them to a static area of zero page first. This is easy for Forth, because Forth's an interpreter! Likewise, most operations with 32-bit values use loops, looping from y=0 to 3. I get to dereference pointers here for free.
Here's an example of the kind of code I'm producing, scrappily annotated by me:
sub Expr2Simple(sop: uint8, uop: uint8, lhs: [Node], rhs: [Node]): (result: [Node])
ResolveUntypedConstantsNeedingNumbers(lhs, rhs);
var op := uop;
if IsSNum(lhs.type) != 0 then
op := sop;
end if;
var ltype := lhs.type;
result := MidC2Op(op, NodeWidth(lhs), lhs, rhs);
result.type := ltype;
end sub;
; Expr2Simple
f563_Expr2Simple:
sta ws1+79 ; unmarshal rhs into a variable (passed in xa)
stx ws1+80
plx ; remove return address from the stack
pla
inx
stx c21_0fce ; poke into return instruction
sta c21_0fce+1
ldy #3 ; unmarshal node, uop and sop together
c21_0fcf:
pla
sta ws1+75,y
dey
bpl c21_0fcf
lda ws1+77 ; marshal lhs onto the stack
ldx ws1+78
pha
phx
lda ws1+79 ; marshal rhs into xa
ldx ws1+80
ajsr f556_ResolveUntypedConstantsNeedingNumbers
lda ws1+76 ; copy uop to sop
sta ws1+83
ldy #8
lda (ws1+77),y ; lhs.type high byte into x
tax
dey
lda (ws1+77),y ; lhs.type low byte into a giving xa
ajsr f238_IsSNum ; returns result in a
tax ; set flag bytes
beq c21_0fd4
c21_0fd3:
lda ws1+75 ; op := sop
sta ws1+83
bra c21_0fd0
c21_0fd4:
c21_0fd0:
ldy #8 ; read lhs.type again. Huh, I should move this up
lda (ws1+77),y
tax
dey
lda (ws1+77),y
sta ws1+84
stx ws1+85
lda ws1+83 ; marshal op for call to MidC2Op
pha
lda ws1+77 ; marshal lhs into xa for call to NodeWidth
ldx ws1+78
ajsr f178_NodeWidth ; returns result in a
pha ; marshal for call to MidC2Op
lda ws1+77 ; marshal LHS
ldx ws1+78
pha
phx
lda ws1+79 ; marshal RHS
ldx ws1+80
ajsr f186_MidC2Op
sta ws1+81
stx ws1+82 ; result in xa
lda ws1+84 ; write ltype to result.type
ldx ws1+85
ldy #7
sta (ws1+81),y
txa
iny
sta (ws1+81),y
lda ws1+81 ; marshal result into xa for return
ldx ws1+82
c21_0fce=*+1
jmp $ffff ; jumps to return address
- GARTHWILSON
- Forum Moderator
On the hardware stack, it's a matter of TSX (done only once, at the beginning of the routine), and then LDA 1xx,X for example, where the xx is how far into the stack to index. So for example, ADC 106,X reaches for the sixth byte in the hardware stack and adds it to the accumulator. You only need the TSX once (at the beginning of the routine), and there's no need for INX and DEX either, as long as LDX #FF, TXS is part of your reset routine. So reaching back in the stack is pretty cheap. ADC abs is four cycles, and so is ADC abs,X, as long as you're not crossing a page boundary, which you won't be doing anyway since the stack area on the 6502 does not cross page boundaries. So essentially the stack frame access is no more expensive than absolute addressing of variables.
So suppose you put four bytes on the stack (or maybe they're left there from previous operations) and then you call your routine that uses them. The 1xx,X addressing can access them without pulling the return address off or copying them anywhere. There's no "marshaling" involved. If you want the routine to return two more bytes of output than it took in as input, the calling routine can do PHA PHA (with so-far irrelevant data) before calling the routine, then the routine doesn't have to juggle the return address either in order to return the right number of bytes. This and lots more is covered in the stacks treatise.
If you use a separate data stack in ZP though, the data will go there instead of on the hardware stack, and again you can use it in place. There's no need to copy it somewhere else. The ZP,X indexing does take one extra cycle than non-indexed ZP access; so if you're doing a loop where something is accessed hundreds of times where the added execution time from the many accesses really adds up, you can do like Forth does with N, a ZP area of eight or so bytes for local data. N is only used inside of primitives, and a primitive is always finished the N's contents when the primitive finishes. N is never used to pass parameters, or to hold them temporarily while calling something else; so there's never any danger of one routine stepping on data that's still needed by a pending routine. If copying things from the stack to N and back takes less time than doing a lot of indexing in a loop that gets executed many times (like multiplication), then it's worth it.
(ZP,X) is great too, particularly when a stack cell contains the address of something to access.
I'm not familiar with the term "dereferencing." What exactly does it mean? Edit: in view of what Chromatix wrote two posts down, it is extremely cheap also to have the address of something on the ZP data stack and access it with a single instruction, with the (ZP,X) addressing mode. Say the cell of interest is at the top of the ZP data stack. To read what's at the address pointed to there, all you need is LDA (0,X). There's no need to move it.
Why? Just use them in place.
Forth does not interpret in the sense of looking things up at run time (except for token-threaded Forth, which is rarely used, because of this overhead). In indirect-threaded or direct-threaded code (ITC or DTC) Forth, what gets compiled is a list of addresses of routines, and sometimes there will be inlined data, like literal numbers or strings. In subroutine-threaded code (STC) Forth, it's a list of JSRs, except that routines can be straight-lined to avoid the JSR-RTS overhead if they're short enough or time-critical enough to justify it. For example, to DROP a stack cell, INX INX is four times as fast as JSR DROP, and even saves a byte.
..snip
..snip
I would really commit to one implementation or the other. Absolutely no recursion (or semi-recursion) or go for broke with a frame stack. I'm trying not to push the decisions I made with PLASMA too hard, but it solved all the problems your dealing with and allowed for a recursive descent compiler to be easily implemented and self hosted.
void strcpy(char* a, const char* b)
while(*a++ = *b++)
- GARTHWILSON
- Forum Moderator
It means to follow the pointer to the data it refers to.
Thanks. I added an edit to the middle of my post above, showing how easy it is to do that with a ZP data stack. (It's just LDA (0,X) for example, a single instruction.)
Hi!
It is great to see more languages for the 6502, specially ones with the compiler (almost) capable of running in the 6502
Also, I agree that by limiting the use of recursion you make the language potentially faster and more portable, as the usable stack sizes in the 6502 are really small.
About the compiler size, in my FastBasic I opted for a novel approach to fit all the compiler (plus runtime and full-screen editor) in only 8kB (or 9.5kB with floating-point support): the compiler is programmed in it's own interpreted bytecode, a simple "parsing machine".
This is slower than a compiler in assembler, but the parsing machine is really small, as it implements a PEG parser (via recursive descent) in which each rule is only one byte, and the emitted code is also stored in the parsing bytecode.
For example, from https://github.com/dmsc/fastbasic/blob/ ... /basic.syn this is an extract on how a "terminal expression" is parsed, in the parser gramar:
For each rule, there is one alternative on each line, and each alternative is composed with all the sub-rules one after the other, so the above means that to parse a "T_EXPR", you generate the VM token "TOK_BYTE" (equivalent to a "LDA #") and them try to parse "E_NUMBER_BYTE" (this will parse a number 0-255 and store it in the code). If this is not possible, the following rule tries to parse a WORD (number from -32768 to 32767), if not it tries to parse a "-" sign followed by recursively trying to again parse an T_EXPR, and then emitting the code for "TOK_NEG" (negation), etc.
Note that the parser machine will rewind the parser when a rule fails, and all the generated code will be discarded. Also, the "E_*" rules are calls to machine code that implement special functionality (so the number parsing is done in machine language).
After the parsing is complete, the generated code can be run as-is (in the interpreter), but the compiler does a peephole pass that replaces a lot of the generated expressions with simpler ones, for example, for an array access the parser generates:
After the peephole, this is optimized to:
As you see, all stack operations (PUSH and ADD) were eliminated, and now the code is much smaller and faster. The good thing is that the peephole does not need to be performed at the same time than the parsing, as the original program is not needed for the optimization.
I'm slowly writing now a new pass to transform the bytecode to 6502 assembler, this simply replaces each bytecode with equivalent 6502 assembler, the above would turn to:
So, generated code is still very bad, but at least is a lot faster than the bytecode interpreter
Have Fun!
hjalfi wrote:
http://cowlark.com/cowgol/
I estimate the 65c02:Z80 generated code size to be about 1.1. As the 65c02 compiler compiled for the Z80 is 60210 bytes, that makes the 65c02 compiler compiled for the 65c02 to be about 66kB. So close... (But of course it also needs some memory to actually run in!)
T_EXPR: integer constant, variable or function
emit { TOK_BYTE } E_NUMBER_BYTE
emit { TOK_NUM } E_NUMBER_WORD
"-" T_EXPR emit { TOK_NEG }
"+" T_EXPR
"NOT" NOT_EXPR emit { TOK_L_NOT }
ARRAY_WORD_ADDR emit { TOK_DPEEK }
ARRAY_BYTE_ADDR emit { TOK_PEEK }
emit { TOK_VAR_LOAD } E_VAR_WORD
PAR_EXPR
# Code for B = A(X+1)
VAR_LOAD A
PUSH
VAR_LOAD X
PUSH
LOAD_BYTE #1
ADD
USHL
ADD
DPEEK
VAR_STORE B
LOAD_1
ADD_VAR X
USHL
ADD_VAR A
DPEEK
VAR_STORE B
LDA #1
LDX #0
CLC
ADC VAR_X
PHA
TXA
ADC VAR_X+1
TAX
PLA
ASL
PHA
TXA
ASL
TAX
PLA
CLC
ADC VAR_A
PHA
TXA
ADC VAR_A+1
TAX
PLA
STA PTR
STX PTR+1
LDY #1
LDA (PTR), Y
TAX
DEY
LDA (PTR), Y
STA VAR_B
STX VAR_B+1
Have Fun!
@GARTHWILSON: Oops, I'd completely forgotten that the (zp,x) addressing mode existed! Yes, indeed, that makes accessing bytes via pointers on a data stack trivial. However, I still believe that (unless there's something else I've missed) accessing index data requires either copying the pointer to a fixed location in zero page, or doing pointer arithmetic: there's no (zp,x,y) or (zp,x),y address mode. So, for example, 32-bit arithmetic becomes very expensive. The same problem applies to accessing values directly on the hardware stack with abs,x.
BTW, I have implemented Forths...
@resman: can you provide an example of some PLASMA stack frame code? (BTW, the Plasma VM should be a really easy Cowgol target.)
It's important to remember, BTW, this Cowgol is not specific to the 6502. It's intended for other architectures as well. The 6502 is good at indexing but the 8080 and Z80 really aren't, and my language abstraction has to work there too. Statically assigning variables is important for that.
@dmsc: 9.5kB is really impressive, especially with floating point! I've only briefly played with PEG and packrat parsers; my impression was that they required memoisation to work effectively, which is hard on a small system. Are you doing anything here or just accepting the cost? How are you handling errors?
I'm using the Lemon parser generator, which is a traditional shift-reduce parser. The automaton is pretty small (465 bytes) and the compiled grammar is in about 4kB of tables. Each rule has a subroutine which does typechecking, code emission etc in code. I'm not at all averse to replacing it. The biggest killer is that I don't have function pointers or jump tables, so the rule dispatch table is enormously wasteful --- about 1.5kB. The code generator has another one. I have just come up with what I think is a workable abstraction over function pointers, so I'll have to try implementing it and seeing if that helps.
