Page 3 of 17
Re: Random-number generation
Posted: Tue Mar 14, 2023 3:09 pm
by Arlet
No, I don't have 6502 version of my code written out, but I have tested it with Dieharder/TestU01. Results are mixed. You can get good results with sufficient number of state bytes and/or multiple iterations, but the smallest/fastest versions aren't so good.
I don't know where the bug is in the optimized code, but I converted it to C, and it produces the same numbers as your test output.
uint64_t LFSR = 0xffffffff;
uint8_t OUT;
while( 1 )
for( i = 0; i < 8; i++ )
LFSR <<= 1;
OUT = OUT >> 1;
if( LFSR & 0x100000000UL )
LFSR ^= 0x1ea000001;
OUT |= 0x80;
putchar( OUT );
Posted: Tue Mar 14, 2023 3:37 pm
by Alex1
Ok Arlet.
Posted: Tue Mar 14, 2023 3:41 pm
by Arlet
I think the
should be
My version does not have the mask, so it doesn't have this bug.
Posted: Tue Mar 14, 2023 3:47 pm
by Alex1
I think the
should be
Well done ! that was the bug !!
Posted: Tue Mar 14, 2023 5:00 pm
by Proxy
I'm really sorry to tell you and I hope you won't get offended but your algorithm is not random at all and is full of short cycles. not at all 2^32.
nah you're good.
I guess you never did any tests on it, did you?
not really. i just thought it would work due to the pointer itself only repeating every 2^32 calls so it would guarantee a new value each time. maybe if the function takes the pointer as well as the data from the table to generate a number. since the whole thing is always 256 bytes large the function could be made larger/more complex.
but why bother when others have made much better functions that are way smaller and faster?
All al lot of short cycles, I stopped the test well before 2^32 :
The first 20-byte sequence repeats non-stop :
Found 'A0C3BEA2C0BE731CBE16371CBEA0C1BEA2BEBE53' at index 0 !
hmm, when i turn the function into a small logic circuit i get:
A1 C3 BE A3 C0 BE 74 1C BE 16 38 1C BE A1 C1 BE A3 BE BE 54
at the start. with the first repeating at index $D00, the next at $7B00, then $D0000, then $D0D00, and so on.
maybe there was some small mistake when converting the assembly to... whatever you use to run the test, did you forget the carry from the first to the second add? if i remove that carry line in the circuit i get exactly what you had:
A0 C3 BE A2 C0 BE 73 1C BE 16 37 1C BE A0 C1 BE A2 BE BE 53
either way it doesn't matter, the RNG function does suck
Posted: Tue Mar 14, 2023 5:23 pm
by Alex1
Yes you are right, there was a carry problem in my code to test your RNG algorithm. But, as you said, the loops are always there with or without carry.
The problem is, in fact, not the 2^32 pointer but the table of 256 bytes too small.
Conversely with LFSR we can prove mathematically that there will be no loops while with a random data table like yours, we cannot mathematically demonstrate that there will be no loops. According to the data of the table, the algorithm can go in loop without warning.
Posted: Wed Mar 15, 2023 12:05 am
by teamtempest
I think the
rol mask
should be
asl mask
Yeah, that occurred to me a bit later. The problem stems from what I called LFSR. Any time a set bit is shifted into the carry flag and the branch to 'noupdate' is not taken, it's still there when 'mask' is rotated. So it adds bits to mask; probably eight of them if the initial seed value starts with $FF. The loop will still stop after eight rotations, but there might be a whole lot of extra set bits in 'mask'. ASL instead of ROL always shifts in a zero bit, so 'mask' never has more than one set bit.
Good catch.
Posted: Wed Mar 15, 2023 3:07 am
by barrym95838
For really compact but dumb PRNGs, a while ago I ported the basic LFSR algorithm and gave it a full 256|65536 period, as opposed to the default of just 255|65535. Of course, the period is only as long as the number itself, but I wanted something where graphical effects would go through all 256 values of a grid once in a "random" order.
https://codebase64.org/doku.php?id=base ... 8-bit_prng
https://codebase64.org/doku.php?id=base ... 6-bit_prng
The 8-bit one is quite tiny, even with the fixup for full range:
lda seed
beq doEor
asl
beq noEor
bcc noEor
doEor: eor #$1d ; 16 possible magic numbers work here, see the link
noEor: sta seed
I have come to the realization that my VTL02 PRNG is not up to snuff. It involves a swap-rotate-add-update "thingy" between the 16-bit seed (tick, tick+1) and the most recent 16-bit numeric assignment value (arg+2, arg+3). VTL02 code consists of nothing but assignment statements and optional comments, so I figured the assignments should be frequent enough to keep the mix fresh. Some informal experiments have shown me that it has a strong tendency to suck, especially in short loops:
lda arg+2 ;
sta (arg) ;
adc tick+1 ; store arg[{1}] in the left-side
rol ; variable
tax ;
ldy #1 ;
lda arg+3 ;
sta (arg),y ;
adc tick ; pseudo-randomize {'}
rol ;
sta tick+1 ;
stx tick ;
execrts:
rts ;
I think I should spend a few bytes replacing it with White Flame's 16-bit code, unless someone smarter than I can come up with a better plan. Updating the seed only when used instead of after every numeric assignment executed should improve overall performance slightly too.
Posted: Wed Mar 15, 2023 2:09 pm
by Alex1
As PRNGs seem to interest some people I also give you my
LFSR 64 which also dates from 1988,
It generates a random sequence of (2^64)-1 bits. It's a 64-bit GALOIS LFSR. Each call to the routine generates an 8-bit byte. We can therefore obtain (2^64)/8 bytes before repeating the sequence. There is no short cycle for all seed values.
First a 8-bytes seed must be put at
seed:
The seed can vary from 1 to $FFFFFFFFFFFFFFFF but never 0 otherwise the LFSR produces only bits to 0.
Each call to the
start: function returns a pseudorandom byte in
rndbyte:
First
init: must be call one time.
After
start: must be call for each generated byte (
rndbyte:) that can be use directly.
The test vector is :
For a seed = $FFFFFFFFFFFFFFFF
the first 50 bytes are :
C4 B0 C2 1F BB C2 A2 D6 EA 28 87 FE 9E EA D6 14 D1 6E 0E 7A 46 84 41 FE 08 8A 49 74 4E 0E 07 7A 24 7F 23 05 6A 71 49 74 E0 05 A9 71 8A 74 23 05 A0 71
// Pukall LFSR 64
// 1988
// Main Program
init:
ldx #0
loop: jsr start
inx
cpx #64
bne loop
rts
start: lda #0
sta rndbyte
sta tmp
jsr begin
lda tmp
cmp #0
beq bit1
sta rndbyte
bit1: lda #0
sta tmp
jsr begin
lda tmp
cmp #0
beq bit2
lda rndbyte
ora #$2
sta rndbyte
bit2: lda #0
sta tmp
jsr begin
lda tmp
cmp #0
beq bit3
lda rndbyte
ora #$4
sta rndbyte
bit3: lda #0
sta tmp
jsr begin
lda tmp
cmp #0
beq bit4
lda rndbyte
ora #$8
sta rndbyte
bit4: lda #0
sta tmp
jsr begin
lda tmp
cmp #0
beq bit5
lda rndbyte
ora #$10
sta rndbyte
bit5: lda #0
sta tmp
jsr begin
lda tmp
cmp #0
beq bit6
lda rndbyte
ora #$20
sta rndbyte
bit6: lda #0
sta tmp
jsr begin
lda tmp
cmp #0
beq bit7
lda rndbyte
ora #$40
sta rndbyte
bit7: lda #0
sta tmp
jsr begin
lda tmp
cmp #0
beq ret
lda rndbyte
ora #$80
sta rndbyte
ret: rts
begin:
asl seed
rol seed+1
rol seed+2
rol seed+3
rol seed+4
rol seed+5
rol seed+6
rol seed+7
bcc not
lda seed
eor #$01
sta seed
lda seed+7
eor #$B0
sta seed+7
lda #1
sta tmp
not:
rts
seed: .byte $FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF
tmp: .byte $00
rndbyte: .byte $00
A FIPS 140-2 test shows that bytes are seen as random:
rngtest: starting FIPS tests...
rngtest: bits received from input: 40000032
rngtest: FIPS 140-2 successes: 2000
rngtest: FIPS 140-2 failures: 0
rngtest: FIPS 140-2(2001-10-10) Monobit: 0
rngtest: FIPS 140-2(2001-10-10) Poker: 0
rngtest: FIPS 140-2(2001-10-10) Runs: 0
rngtest: FIPS 140-2(2001-10-10) Long run: 0
rngtest: FIPS 140-2(2001-10-10) Continuous run: 0
rngtest: input channel speed: (min=130.640; avg=3263.214; max=9536.743)Mibits/s
rngtest: FIPS tests speed: (min=1021.455; avg=16349.437; max=17147.717)Kibits/s
rngtest: Program run time: 2404057 microseconds
The optimized code :
// Pukall LFSR 64
// 1988
// Optimized by Teamtempest 2023
// Main Program
init:
ldx #0
loop: jsr start
inx
cpx #64
bne loop
rts
start: lda #$00
sta rndbyte
lda #$01
sta mask
begin:
asl seed
rol seed+1
rol seed+2
rol seed+3
rol seed+4
rol seed+5
rol seed+6
rol seed+7
bcc not
lda seed
eor #$01
sta seed
lda seed+7
eor #$B0
sta seed+7
lda rndbyte
ora mask
sta rndbyte
not:
asl mask
bcc begin
rts
mask: .byte $00
rndbyte: .byte $00
Posted: Wed Mar 15, 2023 3:43 pm
I'm all in favour of LFSRs!
Thanks for sharing your code. Just a couple of things you're doing are not idiomatic in 6502 land.
You almost never need to compare with zero, because the Z flag is set by a load.
Here, I would probably use PHA and PLA, if tmp isn't needed inside the subroutine. (But in this case it is in fact the return value.)
But I think it will be more natural, faster, and shorter, to use carry as the return value.
bcc not
lda #1
sta tmp
not:
rts
So we just need a SEC instead:
and now C is the return boolean. Which is nice, because we no longer need to initialise tmp.
So
jsr begin
lda tmp
cmp #0
beq bit7
becomes
(probably!)
But also, as I think as noted upthread, your 8 calls to begin, with preamble and postamble, can be compressed into a loop. In which case begin need not be a subroutine, it can be placed inline.
I think it can be useful though, to start by writing code however it occurs to you, and get it debugged, and then to perform some transformations to improve it.
Posted: Wed Mar 15, 2023 4:45 pm
by Alex1
BigEd, it is an unoptimized 1988 code. Thank you for suggesting improvements.
Posted: Sat Mar 18, 2023 10:54 am
by Arlet
Here's my attempt at a random number generator optimized for 6502. An 8 bit random number is returned in A. It needs 7 bytes of RAM (preferably zero page), and has a period guaranteed to be at least 32 bits. It passes Dieharder and PractRand tests (up to at least 4GB of output).
CLC
LDA #$45
ADC seed+0
STA seed+0
ADC seed+1
STA seed+1
ADC seed+2
STA seed+2
ADC seed+3
STA seed+3
EOR seed+6
ADC seed+4
STA seed+4
ADC seed+5
STA seed+5
ADC seed+6
STA seed+6
EOR seed+4
RTS
Posted: Sat Mar 18, 2023 3:28 pm
by barrym95838
Nice! It's going to be tough to beat that for quality of output in the general case, I think, at least when considering code footprint.
Posted: Mon Mar 20, 2023 4:11 pm
by Alex1
Hi Arlet,
Is your algorithm based on math? What is the principle in this case? Or did you create randomly by trial and error?
Posted: Mon Mar 20, 2023 5:09 pm
by Arlet
A lot of trial and error, and then using the errors to refine my intuition. There's also some math involved, but I didn't realize that until it was already somewhat successful. Particularly, a chain of ADC instructions like this results in a maximum length permuted counter that will go through all possible states, but in a randomish order (provided that initial input is odd, and carry flag is cleared). The problem with just a simple chain of ADCs is that the lower order bits are quite regular, so I mixed in some EORs to try to break that pattern, and then used PractRand to see if it was successful.
The "magic" $45 constant input isn't very critical. Other odd values will work too.
