Page 3 of 5
Re: 6502 emulation on Gigatron
Posted: Thu Jul 11, 2019 9:55 am
by mvk
Testing has progressed. We can run Microchess now. Video: https://youtu.be/KBdDg5JfVs8
Changes are:
  • It runs in full
  • On true TTL :-)
  • Without VGA timing errors
It runs in "Super Blitz" mode to make it bearable. In the video you can see me change the VGA mode twice to speed up the program more.
[Edit: Updated the video url to show captions]
Posted: Sat Jul 13, 2019 2:14 pm
by monsonite
Well Done Marcel,
Microchess in under 1000 bytes of code - executed by under 1000 TTL logic gates.
regards
Ken
Posted: Sun Jul 14, 2019 5:16 pm
by mvk
Thanks, and under 1000 Elo?
A month ago this was little more than just a nagging idea. Testing will continue the next weeks by hopping from application to application. VTL02, Apple1 BASIC and MS BASIC are still in the queue. I figure that even the larger programs can fit in the small 32K system by toying with the video memory a bit.
The impressive thing about the 476-byte Baum-Wozniak disassembler isn't just its size: it's that it seems to be secretly designed for 26 character wide displays. Now that's quite a foresight by these gentlemen!
Posted: Sat Jul 27, 2019 4:26 pm
by monsonite
Hi All,
Marcel has shared his draft v4 ROM with me, so I can now run WozMon and the 6502 Disassembler on the Gigatron which is emulating a 6502 at about 1/8th of 1MHz speed.
It's 35 years since I did any 6502 assembly language - at that time on a Rockwell AIM-65 at Bangor University.
I guess I'll just have to forget all those Z80 mnemonics I learnt as a teenager and learn a whole new alien language ;)
With the Gigatron executing 6502 code - that opens up a whole new opportunity to run code - including VTL02, ehBASIC, FIG Forth, Sweet-16 and all those other 6502 goodies.
The Gigatron has come a very long way in these last 2 years - from a BMOW and TTL chips on multiple breadboards - to a fully fledged system with over 500 kits sold.
The recent expansion board allows SPI communications, and forum member xopr (Martijn) has an Arduino working as an SPI slave makes a useful peripheral processor.
https://forum.gigatron.io/viewtopic.php?f=4&p=821#p821
If you are in the UK I will be presenting Gigatron to the OSHcamp in Hebden Bridge over the weekend of 31st August, 1st September - and the following weekend with Marcel, in Cambridge at the RetroComputing Festival at the Cambridge Centre for Computing History on 7/8 September.
regards
Ken
Posted: Mon Oct 07, 2019 7:54 am
by mvk
Next stage of testing v6502: Micro-Soft BASIC!
Not quite there yet as it goes awry after the memory check. But at least we squeezed in all of the 8.3KB binary without compromising too much on screen space. We should have 3584 BASIC bytes free on the stock 32K system.
Posted: Thu Oct 10, 2019 5:59 pm
by mvk
Progress
Posted: Thu Oct 10, 2019 6:09 pm
Very good! 1/81 is a nice number too.
Posted: Fri Oct 11, 2019 9:47 am
by monsonite
Well Done Marcel,
Speaking of nice numbers - there is always 355/113
Have a great weekend at VCF Berlin
Ken
Posted: Wed Oct 16, 2019 8:05 pm
by mvk
Thanks! Apart from Ctrl-C not yet working, it's otherwise stable. With 3583 bytes free it has the same free memory as the VIC-20. This is really a coincidence. The version we have running is an early one for the Commodore PET.
Although the system can interpret 6502 code, there still was work to do: code, buffers, zero page variables and stack needed relocation. But that wasn't the biggest hurdle as Michael Steil's excellent set of reconstructed assembly sources made that relatively painless. The main problem was to create a sufficiently large continuous memory space. Although the Gigatron has 32K of RAM, 19KB of that is used for screen memory and the remainder is heavily fragmented. For example, by default the largest continuous block we have is just 512 bytes. BASIC itself needs 8KB, plus we need some K's for user program and variables. Ouch...
The first win is to disable the sound channels 2 through 4. That creates a continuous block from $200 to $800. For this trick you need ROM v4.
The next step is to compress the video memory. Our resolution is already nothing, but we can always lower it even more! Of the 120 visible pixel lines, every 8th is always empty. At least, as long as we only use capitals, and for a mid-1970s BASIC that's perfectly acceptable. The empty pixel lines can then be shared for all rows of text. That saves 14*256 = 3585 bytes already.
The last trick is to increase the spacing between text lines from 1 to 4. This reduces the text lines from 15 to 11, but yields 4 * 7 * 256 =7,168 bytes.
Of course we then went overboard and added a flashing cursor, we made sure that the WAIT 6502 Easter Egg works, and that there is a π-symbol. The Gigatron doesn't have that in its font, but it does have T and U.... And... the font is stored without horizontal spacing, so there's our glyph:
  R         S         T   pi    U
  v         v         v   v     v
  x x x x . . x x x . x x # # # # . . . x
  x . . . x x . . . . . . # . . # . . . x
  x x x x . . x x x . . . # . . # . . . x
  x . x . . . . . . x . . # . . # . . . x
  x . . x . . . . . x . . # . . # . . . x
  x . . . x x x x x . . . # . . . # x x .
  0 1 2 3 4 5 6 7 8 9 a b c d e f 1 1 1 1
  ^                               0 1 2 3
  font82up
Good enough for me:
Posted: Wed Oct 16, 2019 8:48 pm
That has to be the best derivation of Pi ever!
Posted: Sat Oct 19, 2019 2:22 pm
by mvk
TIME$ is now also working:
Posted: Sat Oct 19, 2019 7:51 pm
Aha! Now you can run benchmarks! (Calculating digits of pi, for example)
Posted: Sun Oct 20, 2019 9:35 am
by mvk
Be my guest, it runs ok in the online emulator :-). Binary MSBASIC.gt1 is attached to this post. For benchmarking you should change the screen mode to the dimmest/fasted with the [Select] button.
Posted: Sun Oct 20, 2019 1:31 pm
Posted: Tue Oct 22, 2019 12:57 pm
by mvk
Any result yet? I hope it's not that slow :-)
