Page 3 of 3
Re: Macroassembler by Michal Kowalski, syntacs question
Posted: Sun Jul 29, 2018 11:09 pm
by barrym95838
I support the notion that a BRK by itself should assemble to a $00 by itself, and a BRK #$EA should assemble to $00 $EA without complaint ... now I just need to write or modify an assembler to support that behavior, because expecting someone else to do it for me at this late date would be vainly optimistic.
Posted: Mon Jul 30, 2018 2:24 am
It would indeed be logical to assemble "BRK #0" as 00 00, and some assemblers accept that syntax, but that's not what was specified here. This difference from standard assembler behaviour could indeed be considered a bug.
In the case of the Kowalski assembler, it's not a bug. It's a design feature that gives the programmer the option to have any signature byte assembled after a
BRK instruction. The default if this feature is enabled is to assemble
$EA (
NOP) as the signature byte. If this feature is disabled, only
$00 will be assembled for a
BRK instruction.
Except that that's demonstrably *not* what happens here, and it makes it *more* difficult to assemble an arbitrary desired trailing byte.
The code given was
and it assembled to
According to your description, it should have assembled to
According to every other assembler I know about, it would become
I have no problem with
being assembled as
I just tested the Kowalski assembler with a
BRK instruction and the signature byte option enabled. The code assembled was
$00 $EA.
Posted: Mon Jul 30, 2018 7:51 am
by Klaus2m5
You can set the BRK opcode behavior here:
- Kowalski_set_BRK_behavior.png (13.78 KiB) Viewed 2285 times
This is what macros are for:
; BRK instruction to assemble with or without signature
; no matter what the assembler thinks it should do
myBRK .macro ...
.db 0
.if %0>0
.db %1
.endif
.endm
; usage example
*=$200
myBRK ; native BRK
myBRK $12 ; BRK with signature byte
.end
Posted: Mon Jul 30, 2018 10:38 am
by BitWise
Dev65 generates one byte unless an immediate operand is specified.
00:00C4' 00 : BRK
00:00C5' 0011 : BRK #$11
Posted: Mon Jul 30, 2018 11:41 am
Best of both worlds!
