Easiest BASIC to port?
Chromatix
Re: Easiest BASIC to port?
Post by Chromatix »
May it be that the terminal client software get's confused about the missing $0D characters causing that garbage to appear?
In that case, you'd see the text coming down a line and continuing right, instead of going back to the left margin - not hash.
/RESET
Post by /RESET »
Isn't that what happens right after "Enhanced BASIC 2.22" ?
Could also be that the $00 isn't catched and output continues fetching characters beyond the text.
Switching terminal output mode to HEX could leverage the mystery what these characters are ore come from.
Just a thought.
LAB_MSZM
!raw $0D,$0A,"Memory size ",$00
LAB_SMSG
!raw " Bytes free",$0D,$0A,$0A
!raw "Enhanced BASIC 2.22",$0A,$00
; numeric constants and series
; constants and series for LOG(n)
LAB_25A0
!8 $02 ; counter
!8 $80,$19,$56,$62 ; 0.59898
!8 $80,$76,$22,$F3 ; 0.96147
;## !8 $80,$76,$22,$F1 ; 0.96147
!8 $82,$38,$AA,$40 ; 2.88539
;## !8 $82,$38,$AA,$45 ; 2.88539
Chromatix
Post by Chromatix »
I think some of those strings are meant to be printed as-is, and some after going through a translator. Sort-of like the difference between OSWRCH and OSASCI in Acorn MOS.
Bizarrely, a "print null terminated string" routine appears to redirect to a "print quote terminated string" routine. Yet the hash contains a quote character. This makes no sense whatsoever.
barrym95838
Post by barrym95838 »
I think I can see the numeric constants for LOG(n) being printed as ASCII, especially the $56, $62 and the $76, $22 and the $38 and the $40. Does anyone else see it?
Mike B.
GaBuZoMeu
Post by GaBuZoMeu »
These 4 byte sequences are normalized floating point representations with a "biased exponent" and a "hidden bit" in the matissa.
The first byte holds the "biased" exponent. Bias is simply an add of $80 to the value of the exponent. In the case of "$80,$19,$56,$62" the exponent is $80-$80=0.
The next three bytes are the normalized 24 bit mantissa with a hidden bit. This hidden bit is the topmost bit of that 24 bits that is always 1 due to normalization (which means the mantissa has a value between 0.5 and <1). As the topmost bit is always 1 it is removed to hold the sign bit of the mantissa. In this case the bit is 0 so the matissa is positive and has a value of $995662 / 2^24 = 10,049,122/16,777,216 = 0.59897435
The last number $82,$38,$AA,$40 is $B8AA40 / 2^24 * 2^($82-80) = 12102208/16777216 * 2^2 = 2,8853912
Atlantis
Post by Atlantis »
Problem solved. It turned out to be an effect of using the X register inside I/O TX routine.
Is it possible to hardcode memory amount for cold boot, to not be asked about it every time?
barrym95838
[ excellent and detailed explanation snipped ]
Yeah, but what happens if your print string routine doesn't know when to stop, and just plows through those binaries as if they were ASCII? A unique and repeatable type of "hash", right? :wink:
Mike B.
GaBuZoMeu
Post by GaBuZoMeu »
Well, printing beginning @E338 on the badge (with EhBasic2.22) gives:
>e330.e3ffq
E330 - ...r....Memory s
E340 - ize . Bytes free
E350 - ...Enhanced BASI
E360 - C 2.22.....Vb.v"
E370 - s.8*@.5.s.5.s...
E380 - ..1r..COx.t#w.t$
E390 - ..8*;.tc..w#.+z.
E3A0 - ..|cB.~u~P.1r...
E3B0 - ...I.[...W{..&e.
E3C0 - #4X.%]a.I.[.x:E7
E3D0 - {."\|.]M}.0.}Ym$
E3E0 - ~.r.~L9s.**S....
E3F0 - .............. .
:roll:
barrym95838
So you can see it too?
Mike B.
GaBuZoMeu
Post by GaBuZoMeu »
Sure. It is not identical, but who can estimate what a galloping X register might cause. :lol:
Klaus2m5
Post by Klaus2m5 »
Yes, but you would no longer be able to reserve RAM space for machine code to be called by CALL or USR() statements. After all it takes only a hit to the [ENTER] key entering an empty line to take the default from Ram_top.
Chromatix
Post by Chromatix »
Since he has an area of banked RAM that isn't included in the BASIC memory area, I think he can safely hard-code the latter.
