Page 3 of 3
Re: C02 - An 8-bit optimized C syntax compiler for the 6502
Posted: Fri Mar 16, 2018 11:03 pm
by unclouded
Just an idea: How about maintaining a short piece of sample code so we can see the current syntax? I like the way
http://coffeescript.org/ explains the language by example.
Posted: Sat Mar 17, 2018 8:21 pm
by CurtisP
A dense, but fairly exhaustive sample code section has been added to the README file, along with the new logo designed by
Triangular
Posted: Mon Mar 19, 2018 8:03 am
by unclouded
Very nice! Is this one correct?
do (c = getchr(); putchr(c); while (c<>13)
It looks to the untrained eye like there's an unmatched parenthesis following `do`
I see that:
..is a condition for "i is positive". It might be friendlier to just recognise
as a degenerate comparison and emit the `BMI` pattern.
Posted: Mon Mar 19, 2018 7:59 pm
by CurtisP
This should have been
do {c = getchr(); putchr(c);} while (c<>13)
I'll fix it.
I see that:
That won't work, because all variables, expressions, and comparisons are unsigned. So (128 > 1) is true even though (128:+) is not, and (128>0) should work the same way.
Posted: Thu Jul 19, 2018 4:40 am
by CurtisP
After a few months hiatus, I've started working on C02. I fixes a bug with break & continue in do/while loops, add a tag for strings to printf() in library stdiox.
I also added a new library memio, which mimics file i/o functions, but reads and writes directly to memory, for use with machines and emulators that do not have file system support, but do support loading and saving blocks of memory to and from a storage device. I did this to allow development of programs that would normally interact with files on these systems.
Posted: Fri Jul 20, 2018 6:58 pm
by CurtisP
I fixed a bug in the parsing of escape sequences in strings (dumb mistake, but took me a while to find it).
But more importantly I made two changes to expression parsing and compilation: Expressions may be used as indexes in any subscripted array references within expressions, and function calls may appear in any term of an expression
My next step is to allow expressions as the second (and possibly third) arguments of function calls. I figure the less quirks in the language specification the better.
All changes have been pushed up to the github repository at
https://github.com/RevCurtisP/C02
Posted: Thu Jul 23, 2020 5:15 pm
Just to note, I stumbled on this old thread, and am pleased to see active development still going on in the repository. Nice!
