processor detection
chitselb
Re: processor detection
Post by chitselb »
This might not be the best time to ask, but other than processor detection and maybe making calculators, is there any good purpose for the SED/CLD instructions? The PET ROM does CLD during initialization, and nothing I've ever seen turns it on without turning it back off again. But in tons of programs I've seen (admittedly mine too!) , there is this CLD in there somewhere near the beginning, an homage to the D flag
leepivonka
Post by leepivonka »
SED & CLD are a handy way to change D.
The D flag controls whether ADC & SBC work in binary or BCD.
If doing ADC on $99 and $01 with C clear:
If D is set, the result is $00
If D is clear, the result is $9A
White Flame
Post by White Flame »
Yeah, you certainly want decimal mode off by default, and only turn it on when you need it. ADC and SBC are very widely used in assumption of full 8-bit mode to toy with leaving it on. Many IRQ routines also forget to CLD, so interrupting decimal mode code can be dangerous. Note that since the processor flags get effectively PHP/PLP'd in the IRQ/RTI mechanism, the routine doesn't have to worry about restoring the prior state of D manually.
Beyond the financial fixed point & high score calculations, there are also some clever routines that print a register in ASCII decimal digits that use decimal mode for the conversion (and turn it off when they're done ;) ).
Note that the CMOS '02 (65c02) does clear the D flag upon reset or interrupt. The NMOS needs the CLD in the reset routine and ISRs though.
BitWise
In Memoriam
Post by BitWise »
I always set the I flag and clear D flag in my reset routines in case an application has executed JMP ($FFFC) to simulate a hardware reset.
An excellent safeguard!
Elsewhere on this tie, there is a "universal" binary to ASCII conversion routine that uses decimal mode.
