What was your largest self-written 65xx program?
Re: What was your largest self-written 65xx program?
I never wrote an assembler or a monitor, but I think it's a great way to get your teeth into the machine level, and those who have done it seem to be well set up.
I like the look of dflat!
I learnt 6502 by writing my first assembler. I learnt how to write the assembler by comparing listings in "Compute!" They would sometimes show a program in both assembly and hexadecimal machine language (or decimal in the form of BASIC "DATA" statements!). That's why for the longest time, I didn't know how to use a few uncommon instructions. I remember figuring out the hard way how BRK takes a parameter.
I wouldn't say I'm particularly well set up. But I wouldn't rather have done it any other way.
I did have prior experience with assembly, though. I would hand-assemble TMS-1000 on paper.
Tor wrote:
I've become so used to modern source code practices that I don't think I could ever do the editing on the target platform anymore.
The system cost a few thousand UK pounds. A broke kid, I remember being quiet envious. It was all very slick. Being able to absorb a crash or reset and just keep coding/testing without skipping a beat made assembly programming too easy. Nothing broke my stride on the Atari 800XL like having to reset and reload my source code. I also used the slowest assembler in the world... so that didn't help. My friend pressed an 'F' key and, it seemed, that before his finger had completely lifted off the key, the code was assembled, transferred over and the program was running. It wasn't that fast, of course, but that's how it felt.
From what I've read it seems that programming on the target, with all its constraints and limitations, was for kids in their bedrooms. Professional developers used systems ranging from personal IBM PC clones to PDP-11s, and more. Event the Atari ST, which came out in '85, was a popular low-cost system for the 8-bit machines, with the Atari MADMAC assembler supporting 6502 code generation.
I don't remember source code control being part of my friend's development system. Maybe it was... I wasn't aware of the notion back then. Of course nowadays, like you, everything is under source code control. It's essentially zero-effort.
EDIT: I think this is what my friend used: http://www.cpcwiki.eu/index.php/PDS_development_system
- GARTHWILSON
- Forum Moderator
sark02 wrote:
He used a PC clone for development (editor/assembler) with some kind of hardware interface (attached to the '64 cartridge port) to squirt the entire assembled program over to the '64 in a couple of seconds.
If I crash the workbench computer, I can press the reset button, and the boot-up routine puts "New/Old/Init-Ap?" in the 16-character LCD, three options which correspond to three particular keys on the keypad. Pressing the key for "Old" keeps everything I already had compiled in its RAM, rather than starting over. This almost always works because crashes don't usually go writing trash all over RAM, but instead are just from loops whose exit condition never gets met. Init-Ap goes further, and executes the initialization routine whose address is in the init-ap variable. This allows resetting, setting up I/O again, re-initializing things, etc., and being totally back to operational in a couple of seconds, with nothing lost. The crash and reset on the workbench computer does not affect the PC. There's no special software on the PC, not TSR's, etc., let alone anything expensive.
As I develop code using the text editor on the PC, I put block markers around a small, new portion I want to try, and "print" it to the RS-232 port (the PC thinks it's sending it to a serial printer), then the workbench computer takes that text, and compiles, assembles, or interprets on the fly, as appropriate.
I think the key is having a second computer for development - even if it's as cheap as the first computer, the target, it's still doubled the cost of setting up! We only get safety during development later on, when our CPUs get memory protection. Back in the day, using a timesharing service would be one way to keep costs down - that's good for the entrepreneur, not so much for the schoolkid. Perhaps using nearby University computers for free would do it!
My home-made calculator software has approximately 6,500 lines of code. I wrote some 3,700 lines, 750 of them being an extension to C.R. Bond's math library which accounts for the remaining 2,800 lines.
I didn't use sophisticated methods for debugging, it was mostly done with head-and-pencil, and the Kowalski simulator was used for some math routines. I used the oscilloscope to check the correct behaviour of the keyboard scanning ISR and the associated hardware.
The whole development was done on an old laptop (pentium-II), mainly with DOS tools (as65, ...). I didn't use macros ; I suppose I'd use them if I were to start a new project. The code is made of 13 modules included into the main one at assembly time.
All of that was quite a satisfaction : it's been 20 years since my last software development in assembly... it was at work : I didn't write as large assembly code, but I often passed the 10,000-line limit with parts of projects written in C or PL//M -but that was not for the 6502 of course.
My largest 6502 coded source is a hair under 20.000 lines, producing around 9 KB of (very efficiently coded) binary. It's for a contraption called GoSDC (see http://www.zeridajh.org/hardware/gosdc/index.htm). One of the funky things is that it runs almost entirely on stack space.
20,000 lines to 9216 bytes of code?
Don't get me wrong, I'm not trying to pick on you, I'm trying to understand. For me, I'd expect to get 9216 bytes of code in about 6000 lines. I guess I'll have to look at some of my code and see how big it really is,
OK thanks. I was starting to think you had paragraphs of comments in your code.
- GARTHWILSON
- Forum Moderator
Always think of the next person who will work on the code - it might well be yourself!
- BigDumbDinosaur
Windfall wrote:
;lbopbo: CONVERT LOGICAL BLOCK OFFSET TO PHYSICAL BLOCK OFFSET
; Calling syntax: LONGX ;16 bit index
; LDX LBOLSW ;LBO LSW
; LDY LBOMSW ;LBO MSW
; JSR LBOPBO ;convert LBO to PBO
; Exit registers: .A: entry value
; .B: entry value
; .X: PBO LSW (1,2)
; .Y: PBO MSW (1,2)
; DB: entry value
; DP: entry value
; PB: entry value
; SR: NVmxDIZC
; |||||||+———> 0: okay
; ||||||| 1: PBO wrapped — error
; +++++++————> entry value
; Notes: 1) The returned PBO is zero-based.
; 2) Content is undefined if an error occurs.
; —————————————————————————————————————————————————————————Code: Select all
;mktime: CONVERT BROKEN-DOWN TIME TO CALENDAR TIME
; Calling syntax: per altzone ;pointer to daylight saving time zone data
; per timezone ;pointer to standard time zone data
; per time ;pointer to calendar time field (2)
; per tm ;pointer to broken-down time structure (1)
; jsr mktime
; .B: entry value
; .X: entry value
; .Y: entry value
; DB: entry value
; DP: entry value
; PB: entry value
; SR: NVmxDIZC
; ||||||| 1: conversion error
; Notes: 1) tm must point to a broken-down date & time structure of type
; tm, in which fields are as follows:
; Offset Field Description
; $00 tm_sec seconds
; $02 tm_min minutes
; $04 tm_hour hour
; $06 tm_mday day-of-month
; $08 tm_mon month
; $0A tm_year year
; $0C tm_wday day-of-week¹
; $0E tm_yday day-of-year¹
; $10 tm_isdst DST flag
; ¹Input values are ignored & will be replaced
; by data computed from the input date.
; All fields are of size s_int. Refer to the tm structure def-
; inition in include/calendrics/tm.asm.
; 2) The value returned in time is the number of seconds that have
; elapsed since the "epoch" (discussed below). time must be of
; size s_time_t, which is defined in include/calendrics/tm.asm.
; 3) time is assumed to be UTC, not local time. See below informa-
; tion for more details.
; 4) This function does not verify that the data in tm are valid.
; An error exit will occur if an intermediate computation causes
; an over- or underflow, or attempts division by zero. Nonsens-
; ical dates, such as Feb 30, or times, such as 61 minutes, may
; produce unexpected results.
; mktime converts the broken-down time in the structure tm into the number
; of seconds that have elapsed since the "epoch," which is defined as Sun-
; day, October 1, 00:00:00 UTC, 1752. The conversion is accurate for all
; dates from the epoch to December 31, 23:59:59 UTC, 9999.
; This conversion is different than that used in most UNIX-like operating
; systems, in which the epoch is Thursday, January 1, 1970 & time_t is a
; signed integer. UNIX generates a negative result for dates prior to the
; epoch, with a maximum regression to December 13, 1901 in the case of 32
; bit time_t definitions. This implementation of mktime generates an un-
; signed integer of size s_time_t for any date & time within the accept-
; able range.
; maktime makes reference to several external variables for time zone &
; daylight saving time (DST) conversion data:
; § timezone
; This variable of s_int size defines the local time zone as a signed
; offset to UTC when standard time is in effect. mktime interprets it
; as follows:
; x00000xxxxxxxxxx
; | ++++++++++———> minutes offset from UTC (0-1023)
; +——————————————————> 0: locale is west of UTC
; 1: locale is east of UTC
; For example, if timezone is $81E0 the locale is 8 hours east of UTC &
; 28,800 seconds will be subtracted from the computed time value before
; it is returned. If timezone is $0168 then the locale is 6 hours west
; of UTC & 21,600 seconds will be added to the computed time value be-
; it is returned. This scheme accommodates time zones that are not ex-
; act hour multiples east or west of UTC.
; § altzone
; offset to UTC when daylight saving time is in effect. mktime inter-
; prets it as follows:
; x00000xxxxxxxxxx
; | ++++++++++———> minutes east/west of UTC (0-1023)
; If altzone is $0000 then it is ignored by & time zone compensation is
; based upon timezone. If timezone & altzone are both $0000 then it is
; assumed that the locale is in the UTC time zone.
; Daylight saving time will only apply when tm_isdst in the tm structure
; is $0001. Otherwise, standard time will be assumed, regardless of the
; value of altzone.
; Upon a successful conversion, mktime will rewrite all fields in the tm
; structure, as an internal call will be made to localtim to reverse the
; conversion to compute the day-of-week (tm_wday) & day-of-year (tm_yday)
; fields. A side-effect of this reverse conversion is other fields in tm
; may also change, usually because a value prior to conversion was nonsen-
; sical, e.g., a date such as Feb 30.
; ————————————————————————————————————————————————————————————————————————To those just starting out with assembly language, the above sort of thing may seem to be unnecessarily elaborate and a big time-waster. After all, we all have good memories and never forget anything, right? However, a year or two later when you revisit the function, such as to add features, you'll be glad you committed your thoughts at the time to "paper."
The sames applies regardless of the language being used. In years past, I did a lot of development in Thoroughbred Dictionary-IV, which is a complex timesharing form of BASIC. Like almost all BASIC implementations, Thoroughbred has the REM (remark) statement for commenting programs. I tended to use it quite liberally, and when the occasion arose in which I would have to maintain a program I had written long ago I didn't have to rely on memory to figure out why I wrote things the way I did.
