6502 with a serial port - a minimal monitor?
Re: 6502 with a serial port - a minimal monitor?
This is the 6502 code version. No CMOS opcodes included. I also removed the upload.asm file so it sits from $FC00-$FFFF.
That's it - 1k small and simple. You can easily add commands too. Just check out the readme file. I can help if it is not clear.
- Attachments
- SBC2OSLitest.zip
- 1k File for 6502 code - no upload.asm.
- (44.91 KiB) Downloaded 436 times
Daryl, that is great news. I will run the conversion utility on it tomorrow and post the results (and latest python code for the converter)
Enso,
I revised the file in the link above... please re-download. It needed a few corrections. (I was up too late last night fixing it)
Should be good now.
Should be good now.
teamtempest
I see the code uses that useless (zp,x) address mode!
Addresses to the commands reside in a table in ROM. I had used jmp (table, x). Since the 6502 does not have jmp (abs,x), I had to go back to loading each byte and pushing to the stack, then use RTS for the indirect jump. Had to decrement the addresses by 1 to account for RTS too.
end result - the code conversion works.
Kingswood assembler is not great. It does not show error line numbers in included files - just the line number of the include statement, which makes it pretty much useless. I might have to write an assembler. Python has so many nice features for writing assemblers that it should not be hard. And I've done it a couple of times before...
Kingswood is case-sensitive for labels, which makes it hard in this case. Since my conversion does not build a symbol table I don't want to convert case willy-nilly on things that may not be labels. I hand-modified a bunch of labels and references (linecnt, LineCnt,lineCnt, etc). I was hoping for an automated conversion, but no such luck.
- GARTHWILSON
- Forum Moderator
Although I've found bugs with every assembler and compiler I've tried, one assembler I like is Cross-32 (or C32). You buy just one assembler and it's good for for as many processors as you want to assemble for, because it has the tables to form the instructions for so many processors, and tells you how to make your own so for example we can make our own 65-family enhancement and use this assembler for the new processor.
There are lots of free assemblers though if you don't want to pay for one. There's a list of them about 3/4 of the way down the software section of my links page (one of the links going to a page with lots more assemblers). Without my having tried the free ones, one that looks especially good is Bitwise's (Andrew Jacobs') at http://www.obelisk.demon.co.uk/dev65/ which has program structure capabilities built in, and teamtempest's (Anton Treuenfels') HXA at http://home.earthlink.net/~hxa/ which includes macros to do the program structures I have been promoting.
There are lots of free assemblers though if you don't want to pay for one...
Then again, if I am paying for it (and can't change it to fit my needs) it better be really good!
Macros are a whole other topic. I've tried many assemblers with macros (fasm being one I've used a lot), but they are all crazy. I don't even know if there is a good way to do macros as there are many subtleties...
You've provided some good leads and I will try again to find a better assembler. Thank you. At least I have a pretty good conversion utility in the making...
OK, the monitor is up and running!
Is this the way it should behave? A <CR> by itself, in particular continues dumping up to the next 16-byte boundary. Q by itself does nothing.
I am pretty happy - it only took a couple of hours (mostly to find a verilog issue with IO port selection logic).
The conversion utility was pretty useful (although lots of case changes were done manually). The conversion code:
65C02 Monitor v5.1.1 (7-4-13) Ready
>FF7D
FF7D - 78
D8 A2
FF80 - FF 9A 20 00 FC 58 4C 68 - FD AD 00 C0 20 01 FC 20
>FF57Q
FF57 - 6
>Q
>FF57.FF7CQ
FF57 - 65C02 Mon
FF60 - itor v5.1.1 (7-4
FF70 - -13) Ready...
# make adjustments
opcode=opcode.lower()
if(opcode==".byte\""): #move " into operand
opcode="db"
operand='"'+operand
if(opcode==".byte"):
opcode="db"
if(opcode==".word"):
opcode="dw"
if(opcode=="asl") and (operand==''):
operand="a"
if(opcode=="rol") and (operand==''):
operand="a"
if(opcode=="lsr") and (operand==''):
operand="a"
if(opcode=="ror") and (operand==''):
operand="a"
if opcode=="*=":
opcode = "org"
if operand.startswith("#>"):
operand = "hi "+operand[2:]
if operand.startswith("#<"):
operand = "lo "+operand[2:]
if operand.endswith(",X"):
operand = operand[:-2]+",x"
if operand.endswith(",Y"):
operand = operand[:-2]+",y"
- GARTHWILSON
- Forum Moderator
It's not that paying that I have an issue with (I have no problem paying to support an infrastructure I need). Open source is pretty important to me as at this point in my life I have little desire to hope that a third party will fix my bugs, provide support or just not go bankrupt.
I agree that open-source is the better way to go when possible. I did find another bug last year in C32 (with INCLude files in a macro not getting included until the macro is finished) but found a way around it. The only other bug I can think of is that if there's a comma in a quoted string that is a macro parameter, it mistakes it for a parameter delimiter. This is in my version from about 20 years ago for DOS. They may have fixed those by now, and Data Sync Engineering is still selling C32 for DOS and Windows.
...one that looks especially good is Bitwise's (Andrew Jacobs') at http://www.obelisk.demon.co.uk/dev65/ which has program structure capabilities built in.
... and teamtempest's (Anton Treuenfels') HXA at http://home.earthlink.net/~hxa/ which includes macros to do the program structures I have been promoting.
I wrote my own mostly because I couldn't find anything that ran well on the Mac, and did what I want. I can't seem to find any that produce an assembled listing of all things.
So, mine does -- listings and Intel HEX output.
No macros though.
It seems that every one of us is using a different assembler! You'd think that we would unite, given our numbers... I remember some threads about assemblers and macro features in the past. Don't want to go too far off-topic, but it is a sore subject.
It would seem more appropriate for the macro facility to be separate from the assembler, like the C preprocessor (but more general purpose). Too bad M4 is a nightmare.
>FF7D
FF7D - 78
D8 A2
>FF57Q
FF57 - 6
>Q
>FF57.FF7CQ
FF57 - 65C02 Mon
Glad to see it is living!
- GARTHWILSON
- Forum Moderator
