6551 vs 6850 vs 8250 vs ?
When using Motorola 68xx chips with the 6502, the E line should be connected directly to the 6502's phase 2 output. Although this line is called Enable, it is not a chip select line, it is a timing line with the same function as the 65xx series phase2 line.
It is called Enable because it is used to indicate that data should be enabled onto the data bus by a devices' 3-state drivers when it is active.
Shift to the left,
Shift to the right,
Mask in, Mask Out,
BYTE! BYTE! BYTE!
Shift to the right,
Mask in, Mask Out,
BYTE! BYTE! BYTE!
- BigDumbDinosaur
leeeeee
- In Memoriam
- GARTHWILSON
- Forum Moderator
Yes. Again, RS-232 is asynchronous.
leeeeee
- In Memoriam
- GARTHWILSON
- Forum Moderator
I've never heard of a distinction. The 6551 ACIA does do the whole set AFAIK:
- 5, 6, 7, or 8 data bits
- 1, 1.5, or 2 stop bits
- odd, even, mark, space, or no parity
- full duplex
- programmable echo mode
- transmit data, continuous stop, or continuous break
- 15 programmable baud rates, + external 16x clock source like for MIDI which is 31.25kbps
leeeeee
- In Memoriam
- BigDumbDinosaur
I see now in the data sheet that for the 1MHz 6850, the CS lines need to be valid at least 80ns before E rises; so yes, E would definitely have to be gated by phase 2, whereas the chip selects must not be. For the 1.5MHz part, it's 60ns min, and for the 2MHz part, it's 40ns. You could probably run phase 2 directly to the E input by itself. As long as the CS lines are not all true, it won't do anything.
- GARTHWILSON
- Forum Moderator
You know, I never even looked at the datasheet.
I had the 6850 knocking around and saw a circuit for a UK101 work-like which I discovered in the projects section of this site that used it. While the rest of the circuit is different, I used his connection schema for the 6850 and it's clock. I figured if it worked for him it would work for me. And it did!
Over the years I have put Lee's EhBasic on it as well as OSI basic, Pittman's Tiny Basic and Micro-chess. More recently I had actually wanted to find a romable Forth to put on it as well, but ran out of steam on that. It's been a real trooper.
Just looked at the datasheet for 6850, and according to it, it should not work!
