New to SBC projects
Topics related to the SBC- series of printed circuit boards, designed by Daryl Rictor and popular with many 6502.org visitors.
Also available in some glue logic is 74ABT, which is about as fast as you are going to get. I tend to stick with 74ABT and 74AC. Many are also available in SOIC packages...a bit more a challenge to solder, but more economical with board real estate.
From Mouser, I just ordered some 74ABT573's in DIPs, and some 74ABT00's and 04's in SOIC since they didn't have them in DIP. I will probably get the SOIC-to-DIP adapters for the SOICs. I would still like to find the '521 and '138 in ABT, if anyone knows a source.
Mouser now has the 74ABT00 and '04 in DIP, so I ordered those. They still don't have the 74ABT30 in any package, nor the '521, '688, or '138. Is there any other 5V 74xx logic family that's significantly faster than 74AC/74ACT?
74F is in the same range, speed-wise. For example, prop delay on a 74F00 is 2.4 to 6.0 ns, taken from the Fairchild data sheet. Mouser lists a lot of 74F parts, although it seems more of them are small-outline packages than DIP.
In my next SBC I will probably use more 50-mil type packages, since the oldest grandson has no trouble hand soldering those. :) Can't say the same for gramps (me) though. Somewhere along the way, I hope to work out an SMT soldering procedure that doesn't involve having to use an iron on every terminal. Our toaster-oven is starting to look attractive, although, for some unfathomable reason, my wife is not enthralled with the idea.
[Mouser]...still [doesn't] have the 74ABT30 in any package
Take a look at the 74F30.
