Page 17 of 25
Re: Fleet Forth design considerations
Posted: Tue Oct 25, 2022 1:59 am
by JimBoyd
I will discuss Fleet Forth's control flow words built around the branch primitives BRANCH and ?BRANCH which use the following words to mark and resolve an address.
<MARK ... <RESOLVE
>MARK ... >RESOLVE
BRANCH is followed by an inline address. It always branches to this address. ?BRANCH is also followed by an inline address. If the top element of the data stack is zero, It will branch to this address. If not, it will increment IP , Forth's instruction pointer, past this inline address.
Fleet Forth's control flow words are like building blocks. Other than the DO LOOPs, there are six fundamental control flow words.
BEGIN marks the target of a backward branch which is resolved by AGAIN or UNTIL . AGAIN compiles BRANCH and UNTIL compiles ?BRANCH . AGAIN and UNTIL resolve the address placed on the stack by BEGIN or any other word which uses <MARK .
IF and AHEAD are for forward branches and leave an address to be patched by THEN. IF compiles ?BRANCH and AHEAD compiles BRANCH. THEN resolves the address from a single IF , a single AHEAD or any word which uses >MARK .
Here are the control flow structures possible with these six words.
BEGIN ... AGAIN
BEGIN ... UNTIL
IF ... THEN
AHEAD ... THEN
If a branch word which branches on true is added, there would be two more fundamental control flow words.
or something similar. The prospective names are irrelevant for this post. There would be two more control flow structures.
Fairly simple and seemingly limited; however, these six words plus immediate versions of DUP DROP SWAP and ROT for the control flow stack can be used to build all the other control flow words. These control flow stack manipulators are CS-DUP CS-DROP CS-SWAP and CS-ROT . Since there is compiler security (a single number on top of the address), each element of the control flow stack is a double number. Fleet Forth's control flow stack is the data stack, which means the control flow stack manipulators are aliases. They have no bodies of their own, each one's code field points to the body of the word it is aliasing.
CS-DUP is an alias for 2DUP
CS-DROP is an alias for 2DROP
CS-SWAP is an alias for 2SWAP
CS-ROT is an alias for 2ROT
The other control flow words can be built from these fundamental control flow words.
WHILE is just IF CS-SWAP
: WHILE ( CS1 -- CS2 CS1 )
[COMPILE] IF [COMPILE] CS-SWAP ; IMMEDIATE
In Fleet Forth it's defined like this.
[COMPILE] IF 2SWAP ; IMMEDIATE
REPEAT is AGAIN THEN
: REPEAT ( CS2 CS1 -- )
[COMPILE] AGAIN [COMPILE] THEN ; IMMEDIATE
BEGIN ( begin.cs )
WHILE ( if.cs begin.cs )
AGAIN ( if.cs ) \ BEGIN was resolved
THEN ( -- ) \ IF (within WHILE) was resolved
REPEAT combines AGAIN and THEN in a single word. Multiple WHILEs can be in a BEGIN loop, but each one needs resolved by a THEN . It wasn't until after Fleet Forth's WHILE and REPEAT were implemented that I found I had inadvertently achieved Ansi compliance with their implementation. Sometimes conforming to multiple standards just happens.
ELSE is just AHEAD CS-SWAP THEN
: ELSE ( CS1 -- CS2 )
[COMPILE] AHEAD [COMPILE] CS-SWAP [COMPILE] THEN ; IMMEDIATE
Or as it's defined in Fleet Forth.
[COMPILE] AHEAD 2SWAP [COMPILE] THEN ; IMMEDIATE
ELIF is IF CS-SWAP THEN
: ELIF ( CS1 -- CS2 )
[COMPILE] IF 2SWAP [COMPILE] THEN ; IMMEDIATE
In Fleet Forth two bytes are saved by defining ELIF as this.
[COMPILE] WHILE [COMPILE] THEN ; IMMEDIATE
IF ( if.cs )
ELSE ( ahead.cs ) \ IF was resolved
THEN ( -- ) \ AHEAD (within ELSE) was resolved
When the auxiliary stack is loaded, there are two more control flow stack manipulation words.
CS>A moves control flow data to the auxiliary stack.
A>CS moves control flow data from the auxiliary stack.
I recently read an article about Forth control structures in the July 1986 issue of Dr Dobbs Journal. The article was "A Forth Standards Proposal: Extended Control Structures" by George W Shaw II. The author sites what he believes are five shortcomings in Forth's control structures. I find his proposed solution overly complex.
The first three shortcomings concern LEAVE . To paraphrase the author: The standard control structures can't handle multiple LEAVEs without retesting the exit condition, nor the loop termination separately from LEAVE , nor can LEAVE exit through multiple levels of DO LOOPs.
One of the author's proposed extensions.
Apparently, LEAVES has a built in THEN and the THEN after LOOP resolves the branch from LEAVES .
The Forth-83 Standard LEAVE can't do this; however, the Standard IF along with UNLOOP AHEAD and an auxiliary stack can.
DO IF UNLOOP AHEAD CS>A THEN ... LOOP A>CS THEN
or without AHEAD
DO IF UNLOOP ELSE CS>A THEN ... LOOP A>CS THEN
Fleet Forth's BLOCK branches out of a ?DO LOOP .
CODE BLOCK ( BLK -- ADR )
DEY
BLK/BUF STY
' MRU >BODY LDA W STA
' MRU >BODY 1+ LDA W 1+ STA
6 # LDY
W )Y LDA 0 ,X CMP
0= IF
INY W )Y LDA 1 ,X CMP
0= IF
INY (W)PUT JMP
THEN
THEN
>FORTH
#BUF 1+ 2
?DO
DUP I >BT @ =
IF
DROP I UNLOOP
AHEAD CS>A
THEN
LOOP
LRU 2+ 2+ @
IF
LRU 2@ 0 B/BUF R/W
LRU 2+ 2+ OFF
THEN
BLK/BUF C@
IF
LRU ON
LRU 2+ @ OVER 1 B/BUF R/W
THEN
LRU ! #BUF
A>CS THEN
DUP >BT MRU 6 CMOVE
MRU 1 >BT ROT 6 * CMOVE>
MRU 2+ @ ;
Here is an explanation for what it is doing.
DEY \ store $FF in zero page location BLK/BUF.
\ BUFFER's cfa points to the following.
BLK/BUF STY \ BUFFER will store a zero at BLK/BUF.
if the requested block is the most recently used,
replace the block number with the buffer address for that block
ends with a jump to an address which jumps to NEXT.
if the requested block is not the most recently used
>FORTH \ transition to high level Forth.
#BUF 1+ 2
?DO
search buffer table for matching block number.
if it's found, drop the block number
and branch out of the loop with the index.
IF
DROP I UNLOOP
AHEAD CS>A \ save control flow data to the auxiliary stack.
THEN
LOOP
it's not in the buffer table.
save the least recently used block to mass storage.
BLK/BUF C@ \ is this BLOCK or BUFFER?
if this is block, read in the requested block.
LRU ! #BUF \ store block number in the table
\ at the entry for the least recently used block.
\ and place the address for this entry on the stack.
A>CS THEN \ resolve the branch from the loop.
the stack now has the number for the table entry
with the desired block.
move that entry to the top of the buffer table
and slide the others down.
place the buffer address of that block on the data stack.
As for simply exiting a word from within a DO LOOP nested within another DO LOOP
DO
<DO-SOMETHING>
DO
<DO-SOMETHING> <TEST>
IF
UNLOOP UNLOOP EXIT
THEN
<DO-SOMETHING>
LOOP
<DO-SOMETHING>
LOOP
As for branching out of a nested BEGIN loop
BEGIN
<DO-SOMETHING>
BEGIN
<DO-SOMETHING> <TEST0>
IF CS>A
<DO-SOMETHING> <TEST1>
UNTIL
<DO-SOMETHING> <TEST2>
UNTIL
<DO-SOMETHING>
A>CS THEN
<IF-BRANCHES-HERE>
The last two shortcomings sited are that the standard control structures can't handle multiple WHILE exits separately from each other or from UNTIL without retesting the exit condition.
This is not an issue with the WHILE from Fleet Forth and the Ansi Standard.
BEGIN
WHILE
WHILE
WHILE
<DO-SOMETHING>
UNTIL
<UNTIL-EXIT-FROM-LOOP> EXIT
THEN
<LAST-WHILE> EXIT
THEN
<SECOND-WHILE> EXIT
THEN
<FIRST-WHILE> ;
Although Fleet Forth's assembler uses reverse polish notation and control flow similar to Ragsdale's assembler, it is not based on his assembler.
The control flow words for Fleet Forth's assembler are modeled on the high level Forth control flow words presented here. The control flow data is also two items, an address and a security code. The security codes used for the assembler control flow words are different.
Fleet Forth's control flow words, like the Ansi Standard control flow words, are the blocks upon which other control flow words can be built. This is, in my opinion, a more elegant solution than the one presented by George W. Shaw II.
Posted: Wed Nov 02, 2022 10:50 pm
by JimBoyd
Want to see something scary? With Fleet Forth I can do this.
0 >R CR .S CR .AS R> CR . CR
EMPTY
EMPTY
0
OK
With the new interpreter, this no longer works in Fleet Forth. I did mention it was not portable.
Posted: Sun Nov 13, 2022 9:15 pm
by JimBoyd
I just noticed that Tali Forth doesn't transfer the stack pointer to the X-register to update the loop index in place. It pulls the index off the return stack. I tried that method with Fleet Forth's (LOOP) and (+LOOP) . The resulting code was smaller and somewhat faster, especially for (+LOOP) .
Fleet Forth's DO LOOPs store three parameters on the return stack based on a suggestion from GARTHWILSON. Fleet Forth's previous (LOOP) and (+LOOP) with some details and code removed for clarity.
CODE (LOOP)
XSAVE STX TSX $101 ,X INC
0= IF // BRANCHING OUT OF WORD
SEC TYA
LABEL I.HI+A
$102 ,X ADC $102 ,X STA
VS IF // BRANCHING OUT OF WORD
XSAVE LDX
LABEL LEAVE.BODY
PLA PLA PLA PLA
LABEL EXIT.BODY
PLA IP STA PLA IP 1+ STA
CS>A CS>A
LABEL NEXT
\ fall through to NEXT
CODE (+LOOP) ( N -- )
INX INX XSAVE STX
$0FF ,X LDY $0FE ,X LDA
TSX CLC
$101 ,X ADC $101 ,X STA
TYA 0 # LDY
I.HI+A JMP
END-CODE
\ Section of code between ?BRANCH and BRANCH
A>CS THEN A>CS THEN \ Branch from (LOOP) to here
XSAVE LDX
LABEL BRANCH.BODY
\ fall through to BRANCH
I did not indent after either occurrence of IF because I am using them to conditionally branch out of (LOOP) and into another primitive.
Here are the new versions of (LOOP) and (+LOOP)
CODE (LOOP)
PLA TAY INY
0= IF // BRANCHING OUT OF WORD \ BRANCH1
SEC PLA 0 # ADC
VS IF // BRANCHING OUT OF WORD \ BRANCH2 -- compiles BVC
VS NOT IF \ -- compiles BVS
LABEL LEAVE.BODY
PLA PLA
THEN
PLA PLA
LABEL EXIT.BODY
CS-SWAP CS>A CS>A
LABEL NEXT
INX INX CLC
PLA $FE ,X ADC TAY
PLA $FF ,X ADC
VS IF CS>A \ BRANCH3 -- compiles BVC
LEAVE.BODY 2+ VS BRAN \ -- compiles BVS
END-CODE
\ The section of code between ?BRANCH and BRANCH
A>CS THEN A>CS THEN \ BRANCH2 and BRANCH3 branch to here
PHA
A>CS THEN \ BRANCH1 branches to here
TYA PHA 0 # LDY
LABEL BRANCH.BODY
The two PLA instructions which are skipped over are to support LEAVE . This adds four bytes to (LOOP) but eliminates the need to add five bytes to LEAVE .
All comments beginning with a backslash '\' were added to hopefully aid in understanding.
Posted: Thu Nov 24, 2022 3:05 am
by JimBoyd
As I mentioned previously, Fleet Forth uses >FORTH to transition from the cold-start routine to high level Forth. Here is the tail end of Fleet Forth's cold start routine.
WARM SPLIT SWAP
# LDA $300 STA \ store address of warm-start routine
# LDA $301 STA \ at $300
(WARM) JSR
>FORTH
EMPTY 0 DRIVE CONFIGURE
12 SPACES
[ HERE 18 + >A ]
." C64 FLEET FORTH COPYRIGHT (C) 1995-2022 BY JAMES BOYD "
[ HERE 1- >A ]
INITIAL QUIT -; \ don't compile EXIT
$D A> C! $D0D A> ! \ replace some blanks in startup message string with CR.
-; (dash semicolon) works like ; (semicolon) but without compiling EXIT .
This is what is assembled and compiled by the source fragment above.
10947 134 # LDA N 1+
10949 768 STA
10952 42 # LDA
10954 769 STA
10957 10829 JSR ' BOOTCOLORS >BODY 19 +
10960 3382 JSR ' (>FORTH) >BODY
10963 10773 EMPTY
10965 3293 0
10967 9935 DRIVE
10969 9311 CONFIGURE
10971 3308 CLIT 12
10974 6662 SPACES
10976 7787 (.") C64 FLEET FORTHMMCOPYRIGHT (C) 1995-2022 BY JAMES BOYDM
11034 2955 INITIAL
11036 8621 QUIT
I know how Blazin' Forth handles the transition. How do other ITC Forths handle it?
Posted: Fri Nov 25, 2022 11:01 pm
by JimBoyd
Surely I'm not the only one to write an indirect threaded code (ITC) implementation of Forth on this forum, or am I?
Posted: Fri Nov 25, 2022 11:03 pm
by JimBoyd
Blazin' Forth handles the transition from cold start to high level Forth by storing the address of the Forth thread in IP and jumping to the body of a primitive which would have been in the Forth thread.
If I didn't have >FORTH in Fleet Forth, I would push the address of the Forth thread onto the return stack and jump to the body of EXIT .
Here are three examples showing these techniques.
Using >FORTH to transition to high level Forth thread.
WARM SPLIT SWAP
(WARM) JSR
>FORTH
12 SPACES
[ HERE 18 + >A ]
[ HERE 1- >A ]
Pushing the address of the Forth thread onto the return stack and jumping to the body of EXIT .
LABEL COLD.THREAD
] EMPTY 0 DRIVE CONFIGURE
12 SPACES
[ HERE 18 + >A ]
[ HERE 1- >A ]
INITIAL QUIT [
WARM SPLIT SWAP
(WARM) JSR
COLD.THREAD SPLIT \ push address of Forth thread
# LDA PHA \ onto return stack
# LDA PHA
' EXIT @ JMP
END-CODE
Storing the address of the Forth thread in IP and jumping to the body of 0
LABEL COLD.THREAD
] EMPTY DRIVE CONFIGURE \ zero will already be on data stack
12 SPACES
[ HERE 18 + >A ]
[ HERE 1- >A ]
INITIAL QUIT [
WARM SPLIT SWAP
(WARM) JSR
COLD.THREAD SPLIT
# LDA IP 1+ STA
# LDA IP STA
' 0 @ JMP \ 0 is not a constant in Fleet Forth.
END-CODE \ CFA of 0 points to code which
\ places a zero on the data stack.
In the first example the compiler security provided by colon and semicolon (or dash semicolon) is available. In the other two examples, it is not.
Posted: Fri Nov 25, 2022 11:59 pm
I got into Forth on the HP-71 hand-held computer in about 1990, then on the 6502 the next year, starting with a metacompiler my employer bought which compiled basically Forth-83. The metacompiler had lots of deficiencies and bugs, so I modified and extended it heavily. I would like to publish my work on that one as an assembly-language source code, but I would still need to remove some material the metacompiler supplier might be able to claim a copyright on, meaning there would definitely be some work to do on it. It's not a high priority.
Some years after I was heavily into that, I started writing my 65816 Forth from scratch. It has been operational for 25 years, but only one person has used it much, and that was a technician in the Pratt & Whitney turbine-engine plant in Canada. He used it on the Mensch computer of the 1990's with a 65265 microcontroller. I've hardly used this Forth myself, for a couple of reasons. I let it collect dust for a couple of years at a time, then spend a little time further developing it until another big work project comes along, and then it goes back into mothballs for a couple more years or more. It runs two to three times the speed of my '02 Forth at a given clock rate. My only operation of it has been on my workbench computer than has a 65802 on it, meaning it only has access to bank 0, the first 64KB. I've written words for long accesses, but have not had any hardware to prove them on. At the moment, I am very slowly working on a PCB for a new workbench computer with far more of everything—a real 65816, 768 times as much RAM, hopefully 20MHz (or more if I can get it) (which would mean 40-60 times the Forth execution speed of a C64), more I/O of every kind, etc.—and then I can finish up the '816 Forth and publish it. It is intended for all code to run in bank 0 (which I find is plenty), and the rest of memory is for data, all contiguous, so for example you could have a multi-megabyte array with no interruptions for I/O or anything else.
Both my '02 and '816 Forths are ITC. The '816 Forth has hundreds of primitives (ie, words defined in assembly language), far more than the '02 Forth has. Since the '02 doesn't handle 16-bit quantities nearly as efficiently as the '816 does, many of words were just too impractical to have as primitives (ie, defined in assembly language) on the '02. They just take too many instructions, too much memory. The '816 OTOH makes it practical to have far more as primitives. Besides the obvious advantages of more compact code and faster execution, there were many cases on the '816 where it was actually easier to write words as primitives than as secondaries.
Posted: Sat Nov 26, 2022 1:00 am
by JimBoyd
I'm not asking you to show any code. I am curious, when your computer goes from the reset/cold start routine to Forth's QUIT loop (or high level Forth which leads to the QUIT loop), is it by one of the three methods I presented or something else?
Would any other implementer of an ITC Forth like to mention which method is used to transition from the reset/cold start routine to high level Forth?
Posted: Sat Nov 26, 2022 2:37 am
The reset routine includes loading NEXT into ZP so I can use self-modifying code to eliminate some indirection and make NEXT faster, and putting the PFA of COLD into IP and then jumping to NEXT. COLD sets up some things in Forth, then ends with ABORT, and ABORT ends with QUIT.
I don't have anything called WARM, but I have COLD ask in the LCD, "New/Old/Init Ap?" corresponding to three keys. "New" does the usual thing, re-initializing everything including the dictionary pointer. "Old" leaves the dictionary pointer alone but does all the same stuff about initializing interrupt vectors, alarms, key-repeat speed, the delay before key-repeat starts, and other such things. "Init-Ap" does like "Old" but then also calls the word whose CFA is stored in the INIT-AP variable. These allow a very fast recovery from a crash, since most crashes don't go writing garbage all over memory but are instead the result of some loop exit condition never being met, and I usually realize right away what I did and can fix it immediately.
Posted: Sat Nov 26, 2022 3:50 am
by JimBoyd
I hadn't thought of jumping to NEXT . Scott Ballantyne's Blazin' Forth puts the PFA of the high level part of its cold start routine in IP then jumps to RP!
My Fleet Forth clears the return stack in the low level portion of COLD before calling a few Commodore 64 kernal routines before using >FORTH to transition to high level. The high level portion ends with QUIT . The data stack and auxiliary stack are cleared by a subroutine called by the low level portion of COLD .
Fleet Forth does not have a word called WARM . It is a label used by the metacompiler.
Since Fleet Forth is for the C64, it is loaded from disk. It has one line of BASIC, a BASIC fuse to launch the cold start routine.
XXXX is the address of the cold start routine. The address of the warm start routine is stored at address $300 so it will run whenever the RUN/STOP and RESTORE keys are pressed at the same time. This is handy if I accidentally start an infinite loop, for example. The warm start routine leaves the dictionary and block buffers (and their tables) alone. It acts like an ABORT after initializing a few things such as setting base to DECIMAL , turning off multitasking, and storing the indirect jump opcode $6C at W-1.
Posted: Sat Dec 10, 2022 1:58 am
by JimBoyd
Here is a breakdown of Fleet Forth's FORGET . For the sake of clarity, every double slash (used by Fleet Forth for an end of line comment) was converted to a backslash.
: FORGET ( -- )
NAME CURRENT @ DUP CONTEXT !
VFIND ?HUH >LINK
NAME parses the text stream for a blank delimited string and manages the case since Fleet Forth is case insensitive. The string is stored as a counted string at HERE .
The CONTEXT VOCABULARY is set equal to the CURRENT VOCABULARY and VFIND is used to perform the search. VFIND is a primitive without a body with a code field which points one byte into the body of (FIND) . Unlike (FIND) , VFIND will NOT search parent vocabularies. ?HUH aborts with the message "WHAT?" if the name was not found. >LINK takes the CFA of the word and returns the LFA , the link field address, which is the word's first field.
LABEL (FORGET)
SINGLE
DUP>R FENCE @
LIT
LABEL KERNEL-FENCE
[ 0 , ] \ WILL BE PATCHED
UMAX U<
ABORT" PROTECTED"
The word EMPTY branches to the address at the LABEL (FORGET) . SINGLE switches off multitasking by setting the deferred word PAUSE to the no-op NOOP . A copy of the address is saved to the return stack and tested against FENCE and FORGET's internal fence. If it is less than either, FORGET aborts with the message "PROTECTED".
VOC-LINK R@ TRIM
VOC-LINK @
BEGIN
DUP 2- 2- R@ TRIM
@ ?DUP 0=
UNTIL
A Fleet Forth VOCABULARY has three cells in its parameter field. The first cell points to the link field of the latest word defined in this VOCABULARY, the second cell points to the parent of this VOCABULARY , and the third cell is part of the VOC-LINK chain of all vocabularies.
The VOC-LINK chain is trimmed to remove all vocabularies which are defined after the forget point, then each of the remaining vocabularies are trimmed to remove all words which are defined after the forget point.
R> DUP DP ! [ 'THERE ] LITERAL @
UMIN [ 'THERE ] LITERAL !
The dictionary pointer DP is set to the forget point and the empty point is set to the lesser of the previous empty point and the forget point.
\ RESET ANY SYSTEM DEFERRED WORD
\ WITH CFA ABOVE HERE
HERE [ END.FORGET ] LITERAL
\ BRANCH INTO IORESET
BRANCH [ (IORESET) , ] -;
Each deferred word in the kernel has its PFA and default vector stored in a table of deferred words. This last section of FORGET pushes HERE and the ending address of the table onto the data stack and branches to IORESET . Any deferred word with a vector defined after the new HERE will be reset to its default vector.
This is the last line of source for Fleet Forth's kernel. It patches FORGET's internal fence, protecting all kernel words.
To be clear, the last thing the metacompiler does is execute FINISH-FORTH , but that's in block #1.
Fleet Forth's FORGET does exactly what I want and it works great; however, if I've forgotten anything or if anyone has a suggestion for an improvement, please let me know.
SEE FORGET
FORGET
10666 7700 NAME
10668 2603 CURRENT
10670 3549 @
10672 5002 DUP
10674 2589 CONTEXT
10676 3587 !
10678 7718 VFIND
10680 8033 ?HUH
10682 6627 >LINK
10684 8616 SINGLE
10686 4753 DUP>R
10688 2530 FENCE
10690 3549 @
10692 2497 LIT 12017
10696 5926 UMAX
10698 4390 U<
10700 7825 (ABORT") PROTECTED
10712 2674 VOC-LINK
10714 4726 R@
10716 8824 TRIM
10718 2674 VOC-LINK
10720 3549 @
10722 5002 DUP
10724 4789 2-
10726 4789 2-
10728 4726 R@
10730 8824 TRIM
10732 3549 @
10734 4981 ?DUP
10736 4597 0=
10738 2259 ?BRANCH 10722
10742 4658 R>
10744 5002 DUP
10746 2846 DP
10748 3587 !
10750 2497 LIT 2077
10754 3549 @
10756 5905 UMIN
10758 2497 LIT 2077
10762 3587 !
10764 7357 HERE
10766 2497 LIT 3054
10770 2489 BRANCH 9703 ' IORESET >BODY 6 +
108
OK
SEE uses the current BASE , which was DECIMAL , to display numbers.
Posted: Sun Dec 11, 2022 9:20 pm
by JimBoyd
There is an interesting property of Fleet Forth's DO LOOP's. Detailed information is provided on Fleet Forth's DO LOOP's here.
Consider the word used to remove trailing blanks from the count of a string's address count pair, -TRAILING
: -TRAILING ( ADR CNT1 -- ADR CNT2 )
DUP 0
?DO
2DUP + 1- C@ BL <> ?LEAVE
1-
LOOP ;
Here is what gets compiled:
SEE -TRAILING
-TRAILING
6748 5002 DUP
6750 3293 0
6752 2358 (?DO) 6776
6756 5284 2DUP
6758 4884 +
6760 4815 1-
6762 3576 C@
6764 2709 BL
6766 4474 <>
6768 2128 ?LEAVE
6770 4815 1-
6772 2149 (LOOP) 6756
6776 2469 EXIT
30
OK
If the count is zero (?DO) will branch to the address which is stored in the cell which follows. This address (address 6776) is also present when (DO) is compiled. It is the address which is pushed on the return stack for any LEAVE or ?LEAVE . It is also the address used by (LOOP) if the DO LOOP runs to completion. If a different address is stored in the cell after (?DO) , the EXIT at address 6776 will not be reached.
Here is the word SPACE
Simple and to the point, it emits one space character.
SEE SPACE
SPACE
6661 2709 BL
6663 2931 EMIT
6665 2469 EXIT
6
OK
Notice that address 6665 in SPACE also has the word EXIT . If the address after the (?DO) in -TRAILING is replaced with this address, -TRAILING will work exactly as before. The only difference is the EXIT at the end of -TRAILING will not be reached. Not by (?DO) if the count of the string is zero, not by ?LEAVE if there are no more blanks in the string, and not by (LOOP) if the loop runs to completion. They will all branch to address 6665.
The following modification to the source will result in that change.
DUP 0
?DO
1-
LOOP -;
' SPACE >BODY 4 + HERE 2- @ 2- !
Dash semicolon -; finishes the definition without compiling EXIT . The phrase
' SPACE >BODY 4 +
returns the address where there is an EXIT , address 6665 in this case.
HERE 2- @ 2-
backs up to the address of the branch used by (LOOP) and follows it then backs up to the address of the branch used by (?DO) .
Finally, store ! changes the address to 6665.
SEE -TRAILING
-TRAILING
6748 5002 DUP
6750 3293 0
6752 2358 (?DO) 6665
6756 5284 2DUP
6758 4884 +
6760 4815 1-
6762 3576 C@
6764 2709 BL
6766 4474 <>
6768 2128 ?LEAVE
6770 4815 1-
28
OK
Okay, a minor savings of two bytes; however, there is no cost in performance. Here is another example. Fleet Forth's ID. TYPE and QTYPE . QTYPE is used by LIST since a BLOCK might not contain a screen of source. It could be virtual memory or some other type of data.
: ID. ( NFA -- )
1+
BEGIN
COUNT $7F 2DUP AND QEMIT >
UNTIL
DROP PAUSE ;
: TYPE ( ADR CNT -- )
0
?DO
COUNT EMIT
LOOP
DROP PAUSE ;
: QTYPE ( ADR CNT -- )
0
?DO
COUNT QEMIT
LOOP
DROP PAUSE ;
The following modification shaves six bytes off of TYPE and six bytes off of QTYPE .
: ID. ( NFA -- )
1+
BEGIN
UNTIL
[ HERE >A ]
DROP PAUSE ;
0
?DO
COUNT EMIT
LOOP -;
A@ HERE 2- @ 2- !
0
?DO
COUNT QEMIT
LOOP -;
A> HERE 2- @ 2- !
Since this technique is the epitome of highly non portable code, I will most likely confine its use to Fleet Forth's kernel and system loader.
To be clear, this type of DO LOOP places three parameters on the return stack: The address in the cell following (?DO) or (DO) , the loop limit, and the loop index (actually modified versions of the limit and index).
The loop words (?DO) LEAVE ?LEAVE (LOOP) and (+LOOP) all leave the loop by way of this address. (?DO) uses that address to avoid the loop entirely if the limit and initial index are identical.
If this type of DO LOOP were the norm, it would be interesting to see what other creative use could be made of it.
Posted: Mon Dec 12, 2022 1:15 am
Nice! Do other Forths use that too, ie, is it somewhat common practice, or just your own?
(I would call that hyphen though, as a dash is longer ( — versus - ). On typewriters, since they were usually monospaced, we used to do a dash with two hyphens in a row.)
...as is always the case with Forth. I continue to be surprised, now after 30+ years, by creative and useful techniques that can be done in Forth, things that definitely don't initially meet the eye and aren't in books except maybe "Thinking Forth" (which I really should re-read every few years but don't).
Posted: Tue Dec 13, 2022 1:00 am
by JimBoyd
I saw it somewhere but I don't remember where. I'm reasonably certain it was -; but it could have been ;- . I'm going with -; because I think it looks better. As for how common it is, I don't know.
Posted: Sun Jan 08, 2023 10:39 pm
by JimBoyd
Fleet Forth now has a slightly smaller version of NUMBER? with the same functionality.
This is the previous version.
: NUMBER? ( ADR -- D FLAG )
RB
DUP 1+ C@ ASCII # - DUP 3 U<
IF
BASE.TABLE + C@ BASE !
1+ DUP
THEN
DROP
DPL ON 0 0 ROT
1+
COUNT ASCII - <> DUP>R +
COUNT DIGIT NIP >R
2-
BEGIN
CONVERT DUP C@ VALID?
WHILE
DPL OFF
DUP 1+ C@ VALID?
UNTIL
THEN
C@ BL = R> AND
R> ?EXIT
>R DNEGATE R> ;
It takes the address of a counted string and returns a double number and a flag. The flag is true if conversion was successful.
DIGIT ( CHAR -- N TRUE )
( CHAR -- CHAR FALSE )
CONVERT ( D1 ADR1 -- D2 ADR2 )
CONVERT returns the address of the first unconvertible character. This is exactly what I want. It takes the address one byte prior to the first character it will attempt to convert, so I replaced CONVERT with the phrase 1- CONVERT and bumped the address up one byte.
Instead of just testing the first character to see if it is a valid digit, also make it the first digit by placing a copy of the flag to the return stack and replacing
0 0 ROT with AND 0 ROT
Since the loop starts with 1- CONVERT , I was able to make the rest of the loop more efficient.
RB
1+ DUP C@ ASCII # - DUP 3 U<
IF
COUNT
THEN
DROP
DPL ON
COUNT DIGIT DUP>R AND 0
ROT
BEGIN
1- CONVERT COUNT VALID?
WHILE
DPL OFF
DUP C@ VALID?
UNTIL
THEN
1- C@ BL = R> AND
R> ?EXIT
>R DNEGATE R> ;
This version of NUMBER? accepts the same numeric strings as valid, but it is 8 bytes smaller.
