Page 13 of 17
Posted: Sat Sep 24, 2011 9:07 pm
by ElEctric_EyE
Posted: Sun Sep 25, 2011 6:22 am
by Arlet
You don't need the ORs module at all, just get rid of that. Instead, I assume you have different modules for PS2, I2C, SPI, ROM and RAM. Each of those modules has a port with a data out bus. I assume all of those signals are named 'DO'.
What you do is declare a 'di' bus, 16 bits wide and define it as "wired OR"
I've called it 'di' because it's going to be the input for the CPU. Now, simply attach all your modules to this bus, as well as the CPU.
ps2 ps2( .DO(di), ... );
i2c i2c( .DO(di), ... );
rom rom( .DO(di), ... );
ram ram0( .DO(di), ... );
ram ram1( .DO(di), ... );
cpu cpu( .DI(di), ... );
Each of those modules also needs a chip select signal, and it must produce all zeros on its output bus when it's not selected. If it doesn't need the upper 8 bits of the bus, it just ties them to zero permanently. The synthesis tools will automatically insert all the necessary ORs for you.
Posted: Sun Sep 25, 2011 2:24 pm
by ElEctric_EyE
Posted: Sun Sep 25, 2011 2:27 pm
by Arlet
Yes, that would be on the top level. I've never used schematic entry, but perhaps there is also a way to define a 'wor' signal in a schematic.
Posted: Mon Sep 26, 2011 12:20 am
by ElEctric_EyE
Posted: Tue Sep 27, 2011 5:41 am
by Arlet
By the way, I've pushed some fixes to the github archive of the verilog-6502. You'll need to merge those with your own forks.
Posted: Tue Sep 27, 2011 1:48 pm
by ElEctric_EyE
Posted: Tue Sep 27, 2011 2:03 pm
by Arlet
You should use '|' instead of '||' for a bitwise logical OR.
You can also write it using the entire bus at the same time.
assign DO = INA | INB | INC | IND | INE | INF;
Verilog will automatically extend the IND-INF ports will additional zero bits.
Posted: Tue Sep 27, 2011 3:02 pm
by ElEctric_EyE
Posted: Tue Sep 27, 2011 3:16 pm
by Arlet
You can use my UART if you want.
uart.v - the UART core
uartif.v -wrapper to attach UART to CPU
The UART core was one of my very first projects I did for the Spartan-3 board, when I was just starting to learn Verilog. I still use it whenever I need a UART interface. It's very simple and basic. It only supports 8 data bits, 1 stop bit, no parity, and a fixed baud rate. It assumes a 50 MHz clock, but you can easily change the clock frequency in the code.
The UART wrapper I wrote later, when I needed a UART in a 6502 project. It uses two memory mapped registers. One for data, and the other for control/status.
Posted: Tue Sep 27, 2011 3:39 pm
by ElEctric_EyE
Posted: Tue Sep 27, 2011 4:44 pm
by ElEctric_EyE
Posted: Tue Sep 27, 2011 5:00 pm
by Arlet
Ok, That UART looks like it should work great just using the TX and RX, thanks again! Looking at your code, I see you have it set to go 115200baud. You had it sending data reliably without any use of CTS and RTS?
Yes, 115200 worked fine, but I had a form of flow control in my higher level protocol so the buffers wouldn't overflow.
Posted: Wed Sep 28, 2011 12:22 am
by ElEctric_EyE
Posted: Wed Sep 28, 2011 12:26 pm
by ElEctric_EyE
