Wolin - a minimal Kotlin-like language compiler for 65xx
qus
Re: Wolin - a minimal Kotlin-like language compiler for 65xx
Post by qus »
Yep:
__wolin_lab_loop_start_1:
; 12: add 53280[ubyte] = 53280[ubyte] , #1[ubyte]
    inc 53280
; 13: evalless CPU.NC[bool] = 53280[ubyte] , #255[ubyte]
    lda 53280
    cmp #255
; 14: bift CPU.NC[bool] , __wolin_lab_loop_start_1<while_start>[uword]
	bcc __wolin_lab_loop_start_1
BillG
Post by BillG »
    lda 53280
    cmp #255
If X or Y is available, you can compare a byte with 255 (or 1) with something like:
    ldx    53280
    inx            ; (or dex)
    beq
qus
Post by qus »
Heh, thanks. It will probably be good for 6502 asm optimization phase, though.
dmsc
Post by dmsc »
Hi!
qus wrote:
Some compiler fun. I've compiled the same code with Wolin, cc65 and vbcc:
Wolin:
C (generated by Wolin C frontend :D)
  do {
      (*(unsigned char *)(53280))++;
   } while ( (*(unsigned char *)(53280)) < 255);
cc65:
L0015:	ldx     #$00
	lda     $D020
	inc     $D020
	ldx     #$00
	lda     $D020
	cmp     #$FF
	jsr     boolult
	jne     L0015
I wonder if I can make my bool operations any smarter and use V/C/N flags somehow (and obviously win brevity competition)... But I do like the way it works now - by storing the final bool result of an operation in SP reg. MAYBE instead of storing it at SP,x I just pretend I "stored" it at 6502 V/C/N?
You compiled the CC65 example without optimizations, here I get (using "cc65 -Osir test.c":
L000B:  inc     $D020
        lda     $D020
        cmp     #$FF
        bcc     L000B
Have Fun!
qus
Post by qus »
With such optimizations one has to wonder why are they turned off by default...
Chromatix
Post by Chromatix »
Most C compilers have no optimisation by default, so cc65 is not unusual in that respect. Unoptimised compilation results in code that does fewer unexpected things when single-stepping in a debugger.
