Re: Claude and I Vibe Coded a Forth Interpreter
Posted: Sun Mar 15, 2026 3:37 am
Slight change of approach. There's a lot of cut and pasted code throughout the file primitives.s for working with the UART. For example, in the same function if it needs to print two characters, it will cut and paste the UART code. One function had it five times! I need to fix this duplication
So, I created a hal.inc and hal_mench.s which copied my serial I/O functions to it. I also created stubs for several other useful functions. I then removed all UART code from primitives.s and replaced it with HAL calls. The good news is the module shrunk by several hundred lines. The bad news is it still doesn't assemble.
My next move is to move the code that doesn't compile out of primitives.s to a temporary file and leave stubs in primitives.s to maintain the dictionary links. That way I will have a skeleton of a Forth system. I will also be able to create a binary and see how far it will execute before falling over. I will then target that function for a fix.
