Page 2 of 2
Re: Advice Reqd For Tools.
Posted: Tue Aug 12, 2025 7:46 am
by drogon
(USB-C allows negotiation of higher voltages, for power delivery (PD) up to 65W)
And for hobby projects, there are many little modules that have a USB-C socket and can provide various output voltages - assuming the input USB-C is capable - they are typically called "decoy modules" and some can have their output voltage changes by setting links or soldering pads.
e.g. modules like this
https://www.ebay.co.uk/itm/295636499200
but once you have the keywords to search for there are many options out there and this can make powering hobby projects a breeze.
You do need a good USB-C mains unit though - the cheaper ones just supply 5v but the full PD compliant ones can supply up to 48v at 5 amps.
As an aside, it's often reported that the mains units have more computing power inside them than the Apollo guidance computer...
Posted: Tue Aug 12, 2025 12:04 pm
by barnacle
Yes, but imagine the length of the mains cable...
Posted: Tue Aug 12, 2025 5:54 pm
Wondering how one gets 65 watts out of a USB port. At 5 volts, you’d need 13 amps flowing through those skinny little wires.
The USB spec. allows the master and a device that has the needed intelligence to negotiate a higher voltage and current limit.
Shows you what I know about the not-so-universal universal serial bus.
How many masters could do it though? Why not just have the iron plug into the mains, or at least use a wall wart.
That would be my question as well. Presumably everyone who is a member here has at least one receptacle by their electronics bench. Lotsa watts to be had there for heating soldering irons, arc welding, making tea, etc..
Posted: Tue Aug 12, 2025 5:58 pm
...not to mention the problems with the cable getting tangled up with airplanes, helicopters and nut cases hang-gliding off precipitous slopes.
