Advice Reqd For Tools.
drogon
Re: Advice Reqd For Tools.
Post by drogon »
(USB-C allows negotiation of higher voltages, for power delivery (PD) up to 65W)
And for hobby projects, there are many little modules that have a USB-C socket and can provide various output voltages - assuming the input USB-C is capable - they are typically called "decoy modules" and some can have their output voltage changes by setting links or soldering pads.
e.g. modules like this https://www.ebay.co.uk/itm/295636499200
but once you have the keywords to search for there are many options out there and this can make powering hobby projects a breeze.
You do need a good USB-C mains unit though - the cheaper ones just supply 5v but the full PD compliant ones can supply up to 48v at 5 amps.
As an aside, it's often reported that the mains units have more computing power inside them than the Apollo guidance computer...
barnacle
Post by barnacle »
Yes, but imagine the length of the mains cable...
Neil :mrgreen:
Wondering how one gets 65 watts out of a USB port.  At 5 volts, you’d need 13 amps flowing through those skinny little wires.
The USB spec. allows the master and a device that has the needed intelligence to negotiate a higher voltage and current limit.
Shows you what I know about the not-so-universal universal serial bus.  :shock:
How many masters could do it though?  Why not just have the iron plug into the mains, or at least use a wall wart.
That would be my question as well.  Presumably everyone who is a member here has at least one receptacle by their electronics bench.  Lotsa watts to be had there for heating soldering irons, arc welding, making tea, etc..  8)
Neil :mrgreen:
...not to mention the problems with the cable getting tangled up with airplanes, helicopters and nut cases hang-gliding off precipitous slopes.  :shock:
