Page 2 of 2
Re: Animated 6502 Block Diagram
Posted: Wed Mar 05, 2025 1:33 am
by Jefffrey
Mr SQL wrote:
Thank you for the explanation. I'm curious how do illegal opcodes manage to add extra functions without extra hardware.
The short answer is that illegal instructions can only add functionality that already has the hardware it needs. There are certainly more instructions that could be added to the 6502 just by changing the instruction decode logic---you could add the type of instructions you're talking about (zero page,x and inx in one instruction), but I don't think you could do it and save any cycles (I guess you would still save one cycle for only reading one instruction instead of two though).
If you're curious about how any particular illegal instruction works, punch it into the RAM and step through it!
My understanding of illegal instructions is that they have the bit pattern xxxxxx11 and perform both the instructions xxxxxx01 and xxxxxx10 at the same time if they're "compatible enough". The reason they do something instead of nothing (like on the 65c02 where they are all nop) is because it takes fewer transistors to make it a "don't care" operation. This optimization is inside the decode rom, which unfortunately my tool doesn't show you right now.
Posted: Fri Apr 11, 2025 7:53 am
by piorkov
Hello @Jefffrey
I think your project has stopped working on the website: https://lambduh.neocities.org/blocks/
In my case, the website does not respond to the step/run/reset buttons. :(
Posted: Thu Dec 11, 2025 1:59 am
by Jefffrey
Sorry to the community for leaving this dead for so long. It's up again in a new place: https://jeffayle.github.io/6502blocks/
I'm not really sure what happened on the original site. I think neocities may have changed something on the server that made wasm not work. I couldn't figure out what that might be, but creating any environment where wasm could run was a challenge for me. The original page is still up at https://lambduh.neocities.org/blocks/ if anyone around here knows about wasm and knows what might be up, i'm still curious about it.
Posted: Thu Dec 11, 2025 5:02 pm
by Yuri
Looks like the new site doesn't load correctly; at least not on Firefox, I haven't tried other browsers.
Posted: Thu Dec 11, 2025 5:24 pm
Same for me... chrome and safari both showing just empty yellow boxes.
Uncaught TypeError: Cannot read properties of null (reading 'getElementsByClassName')
at set_bit (6502blocks/:111:29)
at update_diagram (6502blocks/:135:9)
at Worker.simulator_onmessage (6502blocks/:53:9)
at
function update_diagram(state) {
function set_bit(cls, value) {
let matches = svg_doc.getElementsByClassName(cls);
Posted: Thu Dec 11, 2025 11:50 pm
by Jefffrey
okay, this time it was broken because I forgot to put the svg diagram in the directory that got published. that makes sense. what I really can't make heads or tails of is why it was working for me yesterday just before i posted the link.
is it working for everyone now?
Posted: Fri Dec 12, 2025 1:29 am
by Dr Jefyll
This works for me...
... but this one doesn't.
Cool project!
(running Firefox 136.0 on Ubuntu).
Posted: Fri Dec 12, 2025 8:46 am
works for me now on all 3 browsers - thanks for the fix!
