Page 2 of 2
Re: 65816 Test Suite
Posted: Thu Jul 11, 2024 2:42 pm
by AndrewP
Mostly just to post this somewhere for myself so I don't lose it again; there is another suite of 65816 tests (amongst many others) over here:
https://github.com/SingleStepTests/Proc ... main/65816
Very useful for emulators that can arbitrarily set memory values and the program counter because it's just a bunch of JSON for the start state and the expected end state.
Posted: Thu Jul 11, 2024 7:43 pm
(Just writing this as a counter-point - your recommendations and strong recommendations are, of course, only yours. I wouldn't want your opinions to be taken as consensus.)
All recommendations are de facto opinions, Ed, whether offered individually or by a group. It should be obvious to others reading this topic that my recommendation is an opinion, one based upon extensive experience in programming the 65C816. I have never suggested that my recommendations are consensus.
Posted: Sat Jul 13, 2024 5:53 am
Interesting find Andrew, thanks! (Single instructions, full bus activity, randomly generated, verified against hardware)
Posted: Sun Jul 14, 2024 3:47 pm
by 8BIT
Well, I finally got my SBC-4 reconfigured and ran the full test suite and all tests passed, including the BCD math. This confirms the suite's tests are accurate.
If you haven't dug into the code, both binary and BCD math tests all the status bits - Carry, Zero, Negative, and Overflow. All are accurate in both modes, including math on invalid BCD numbers. Don't ask me how many hours I worked on that feature.
I am much more confident now that the 65816 Simulator is mostly working. I still have to work on getting the cycle counting verified, as I was focused on instruction accuracy. I'm sure there will be many exceptions to the basic cycle times listed in the datasheet.
Posted: Sun Jul 14, 2024 6:38 pm
Splendid news, well done! I get the feeling this test suite will lead to a great leap forward in several ways.
Posted: Sat Jul 27, 2024 8:09 pm
by Yuri
Seems that there is no uart.asm in the zip file. I commented out the include and it assembled and ran without issue though.
Posted: Sat Jul 27, 2024 10:24 pm
by 8BIT
Oops - uart.asm was for the sbc-4. The Kowalski version just uses the io.asm for terminal IO.
Good catch! I'll edit the post with the update.
thanks!
Posted: Sat Jul 27, 2024 10:37 pm
by 8BIT
The zip file has been updated in the head post. It also includes a fix for a few 16-bit immediate values that were not declared with the !# operand specifier. This would have resulted in errors for the pending 1.4.0.3 version release coming very soon.
