6502 assembler for 6502?
pebmeister
Re: 6502 assembler for 6502?
Post by pebmeister »
https://github.com/pebmeister/Pasm
my opensource Assembler.
supports labels, local labels, -+ labels, macros
example basic graphics wedge I wrote using it
         ; written by Paul Baxter
        .inc "macros.asm"
        .inc "pagezero.asm"
        .inc "basic.asm"
        .inc "kernal.asm"
        BITMAPBASE = 4096 * 2
        COLORBASE = 1024
        ; Some zero page has multiple uses
        XCOORD = LINNUM ; DO NOT CHANGE set by basic parse routine
        LOC = UNUSED2
        DX = BITTS
        DY = BITCI
        XS = RIDATA
        YS = RIPRTY + 1
        K1 = OLDLIN
        K2 = FREKZP
        _D = FREKZP + 2
        _X = LINNUM
        _Y = RESHO
        _CMD = FREKZP
        TMP = UNUSED2 + 2
        CMDTABLE = UNUSED2
        BASICTEXT = RESHO
        CMDJUMP = UNUSED2
        WEDGE_TMP = LINNUM
        CURLOC = BITTS
        CURLOCB = BITCI
        COUNTER = UNUSED2
        MASKB = RESHO
        MASKE = FREKZP
        YCOUNT = FREKZP + 2
        YCOL = PTR1
        XD   = PTR1
        COLORPTR = TMPDATA
        X0 = FORPNT
        X1 = OPPTR
        Y0 = PRTY
        Y1 = MSGFLG
        R = FREKZP
        PK = OLDLIN
        CURX = BITCI
        CURY = FREKZP + 2
        CX = RIDATA
        CY = RIPRTY + 1
        XDIST  = INDEX
        YDIST  = INDEX + 2
        StartX = DSCPNT
        YMAX = OLDLIN
        XMAX = BLNCT
        SRCM = BSOUR
        ; The values below are globals must
        ; not be modified by basic
        ; The values below will work if you do
        ; not use tape
        CIRJUMP = CNTDN
        IGONE_SV = BSOUR
        COLOR = CMP0
        .org $C000
;*  INSTALL                                 *
;*   Installs Basic Wedge                   *
INSTALL
        php
        cli
        ;   install wedge
        MOVE16 IGONE, IGONE_SV
        MOVE16I IGONE, WEDGE
        ; fix basic pointers
        MOVE16I TXTTAB,2049
        MOVE16I STREND,2051
        ; clear first 5 bytes of BASIC
        ; same as doing a NEW
        lda #0
        ldy #5
        sta (TXTTAB),y
        dey
        bne -
        sta SRCM
        lda #3
        sta COLOR
        plp
        jmp WARM
;*  WEDGE                                   *
;* TXTPTR - pointer to BASIC text           *
;* IGONE  - jump vector back to BASIC       *
WEDGE
        ; move the address of the table to pagezero
        MOVE16I CMDTABLE, _Commands
        MOVE16 TXTPTR, BASICTEXT
        ; init _cmd INDEX TO 0
        ; also init y to 1
        ldy #0
        sty _CMD
        iny
@SkipSpace
        lda (BASICTEXT),y
        cmp #' '
        bne @MatchCmd
        INC16 BASICTEXT
        jmp @SkipSpace
@MatchCmd
        lda (BASICTEXT),y
        ; if it's a null then its the end of a command
        beq @NextCmd
        ; if its a colon let basic handle it
        cmp #':'
        beq @NextCmd
        ; compare to the table entry
        cmp (CMDTABLE),y
        bne @NextCmd
        ; get the next char
        iny
        jmp @MatchCmd
@NextCmd
        lda (CMDTABLE),y
        beq @ExecuteCmd
        inc _CMD
        ldy #0
@CmdTableInc
        INC16 CMDTABLE
        lda (CMDTABLE),y
        bne @CmdTableInc
        iny
        lda (CMDTABLE),y
        beq @ExitToBasic
        INC16 CMDTABLE
        iny
        jmp @MatchCmd
@ExecuteCmd
        dey
        sty WEDGE_TMP
        lda #0
        sta WEDGE_TMP + 1
        ADD16 BASICTEXT, WEDGE_TMP, BASICTEXT
        MOVE16 BASICTEXT, TXTPTR
        ; multiply _CMD by two to get jump offset
        lda _CMD
        asl
        ; move offset to x
        ; move jump entry to
        ; pagezero jump
        tax
        lda _Jump,x
        sta CMDJUMP
        lda _jump + 1,x
        sta CMDJUMP + 1
        jsr @Jump
@Cleanup
        jsr CHRGOT
        beq @Exit2
        jsr CHRGET
        jmp @Cleanup
@Exit2
        DEC16 TXTPTR
@ExitToBasic
        jmp (IGONE_SV)
@Jump
        ; execute the command
        jmp (CMDJUMP)
; each command
; 1st byte space or 0 for end of table
; 0 terminates the string entry
_Commands
        .byte " H", FRE_TOK, "CT", 0
        .byte " HLINE", 0
        .byte " HPLOT", 0
        .byte " HRECT", 0
        .byte " HGROFF", 0
        .byte " HFCOL", 0
        .byte " HBCOL", 0
        .byte " HCLS", 0
        .byte " HGR", 0
        .byte " HCIR", 0
        .byte " HFCIR", 0
        .byte " HSRCMODE", 0
        .byte 0
 ; offsets to commands
_Jump
        .word HGRFillRect
        .word HGRLine
        .word HGRPlot
        .word HGRRect
        .word HGROff
        .word HGRFColor
        .word HGRBColor
        .word HGRCls
        .word HGROn
        .word HGRCircle
        .word HGRFillCircle
        .word HSourceMode
;*  HGROn                                   *
;*  Enter HGR Mode                          *
HGROn
        ; hires on
        lda $D018
        ora #%00001000
        sta $D018
        lda $D011
        ora #%00100000
        sta $D011
        rts
;*  HGRCls                                  *
;*  Clear graphics bitmap and colors        *
HGRCls
        ldx #0
        lda #0
@_ClrLoop
        sta BITMAPBASE + ($0100 * 0),x
        sta BITMAPBASE + ($0100 * 1),x
        sta BITMAPBASE + ($0100 * 2),x
        sta BITMAPBASE + ($0100 * 3),x
        sta BITMAPBASE + ($0100 * 4),x
        sta BITMAPBASE + ($0100 * 5),x
        sta BITMAPBASE + ($0100 * 6),x
        sta BITMAPBASE + ($0100 * 7),x
        sta BITMAPBASE + ($0100 * 8),x
        sta BITMAPBASE + ($0100 * 9),x
        sta BITMAPBASE + ($0100 * 10),x
        sta BITMAPBASE + ($0100 * 11),x
        sta BITMAPBASE + ($0100 * 12),x
        sta BITMAPBASE + ($0100 * 13),x
        sta BITMAPBASE + ($0100 * 14),x
        sta BITMAPBASE + ($0100 * 15),x
        sta BITMAPBASE + ($0100 * 16),x
        sta BITMAPBASE + ($0100 * 17),x
        sta BITMAPBASE + ($0100 * 18),x
        sta BITMAPBASE + ($0100 * 19),x
        sta BITMAPBASE + ($0100 * 20),x
        sta BITMAPBASE + ($0100 * 21),x
        sta BITMAPBASE + ($0100 * 22),x
        sta BITMAPBASE + ($0100 * 23),x
        sta BITMAPBASE + ($0100 * 24),x
        sta BITMAPBASE + ($0100 * 25),x
        sta BITMAPBASE + ($0100 * 26),x
        sta BITMAPBASE + ($0100 * 27),x
        sta BITMAPBASE + ($0100 * 28),x
        sta BITMAPBASE + ($0100 * 29),x
        sta BITMAPBASE + ($0100 * 30),x
        inx
        bne @_ClrLoop
@_ClrLoop2
        sta BITMAPBASE + ($0100 * 31),x
        inx
        cpx #8000-31*255
        bne @_ClrLoop2
        jmp ClearColor
;  HGRBColor
;     Set HGR Background COLOR
HGRBColor
        jsr GETBYTC
        txa
        and #$0F
        sta TMP
        lda COLOR
        and #$F0
        ora TMP
        sta COLOR
        rts
;  HGRFColor
;     Set HGR Forground COLOR
HGRFColor
        jsr GETBYTC
        txa
        and #$0F
        asl
        asl
        asl
        asl
        sta TMP
        lda COLOR
        and #$0F
        ora TMP
        sta COLOR
        rts
;  ClearColor
;     clear Color memory
ClearColor
        lda COLOR
        ldx #0
@Clear3
        sta COLORBASE + ($0100 * 0),x
        sta COLORBASE + ($0100 * 1),x
        sta COLORBASE + ($0100 * 2),x
        inx
        bne @Clear3
@Clear4
        sta COLORBASE + ($0100 * 3),x
        inx
        cpx #1000-3*255
        bne @Clear4
        rts
;  HGROff
HGROff
        ; hires off
        lda $D018
        and #~ %00001000
        sta $D018
        lda $D011
        and #~ %00100000
        sta $D011
        rts
;  HGRPlot
; Parses Basic Text and plot a point
; Calls
;   GETNUM $B7EB
;   _Plot
; HGRPlot x,y
HGRPlot
        INC16 TXTPTR
        jsr GETNUM ; get address in $14/$15 y next integer at X
        jsr RangeCheckXY
;  _Plot
;       XCOORD     IN  2 byte x coordinate
;       X register IN  y coordinate
; Plot a single point
; Must not be called Plot because it collides with Kernal
; PLOT    = $E50A
; Calls
;   CalcPlot
_Plot
        stx YCOL
        MOVE16 XCOORD, COLORPTR
        ; Calc Bitmap location
        jsr CalcPlot
        ldy #0
        lda (LOC),y
        ora MaskStart,x
        sta (LOC),y
        ; Calc color map location
        jsr CalcColorByte
        lda COLOR
        ldy #0
        sta (COLORPTR),y
        rts
; CalcColorByte
; COLORPTR = x location
; YCOL = y location
; Warning:
;     Destroys both COLORPTR and YCOL
CalcColorByte
        lda #0
        sta YCOL + 1
        RSHIFT16 COLORPTR, 3  ; COLORPTR = x / 8
        RSHIFT16 YCOL, 3      ; ycol int(y/8)*40
        MULT40 YCOL
        ADD16 COLORPTR, YCOL, COLORPTR  ; COLORPTR = COLORPTR + ycol
        ADD16I COLORPTR, COLORBASE, COLORPTR ; COLORPTR = COLORPTR + COLORBASE
        rts
;  CalcPlot
;       X reg  IN  y coordinate
;       LOC    OUT  byte of bitemap
;       X reg  OUT  bit of bitmap
CalcPlot
; 320*int(y/8)=32*[8*int(y/8)] + 8*[8*int(y/8)]
        lda #0
        sta LOC
        txa             ;X register has Y coordinate
        lsr
        lsr
        lsr
        sta LOC + 1     ; high-byte of 32*8*int(y/8)
        lsr
        ror LOC
        lsr
        ror LOC         ; low byte of 8*[8*int(y/8)]
        adc LOC + 1
        adc #>BITMAPBASE
        sta LOC+1       ; high byte of memory=BITMAPBASE + 320*int(y/8)
        lda XCOORD
        and #%11111000  ; 8*int(x/8)
        adc LOC
        sta LOC         ; set address memory block of bytes
        lda XCOORD + 1
        adc LOC + 1
        sta LOC + 1
        txa
        and #%00000111 ; int(y/7), byte offset inside bLOCk
        tay
        lda XCOORD
        and #%00000111 ; int(x/7), bit inside byte
        tax
        ; add y to LOC
        sty TMP
        lda #0
        sta TMP + 1
        ADD16 TMP, LOC, LOC
        ; given: x (0 - 7)
        ; x = 7 - x
        MOVE8I TMP, 7
        stx TMP + 1
        SUB8 TMP, TMP + 1, TMP
        ldx TMP
        rts
;  HGRLine
; This routine draws a line
; Calls:
;  GETNUM
;  _Line
HGRLine
        INC16 TXTPTR
        jsr GETNUM ; get address in LINNUM $14/$15 y next integer at X
        jsr RangeCheckXY
        stx Y0
        MOVE16 XCOORD, X0
        jsr CHKCOM
        jsr RangeCheckXY
        stx Y1
        MOVE16 XCOORD, X1
; _Line
;    XO - start X
;    Y0 - start Y
;    X1 - end X
;    Y1 - end Y
; optimized for horizontal lines
_Line
        ldx Y0
        cpx Y1
        bne NotHorizontal
        lda X0 + 1
        cmp X1 + 1
        bcc _Line2
        lda X0
        cmp X1
        bcc _Line2
        MOVE16 X1, XCOORD
        SUB16 X0, X1, XDIST
        jmp CalcPlotHLine
;*  _Line2                                  *
;*    Draw Horizontal line                  *
;*    X0 must be less than X1               *
;*    XO - start X                          *
;*    Y0 - start Y                          *
;*    X1 - end X                            *
;*    Y1 - end Y                            *
_Line2
        MOVE16 X0,XCOORD
        SUB16 X1, X0, XDIST
CalcPlotHLine
        MOVE8 Y0, YCOL
        ldx Y0
        ; Calculate 1st byte and bit of BitMap
        jsr CalcPlot
        MOVE16 LOC, CURLOC
        ; Draw the horizontal Line
        jsr HGRHorizontalLine
        ; Set the Lines color memory
        jmp HCPlotLine
NotHorizontal
        MOVE8I DY+1, 0
        ; DX% = abs(x0%-x1%)
        ; set XS to add or substract
        lda X0 + 1
        cmp X1 + 1
        bcc @X1_larger
        lda X0
        cmp X1
        bcc @X1_larger
        SUB16 X0, X1, DX
        lda #1
        bne @Calc_DY
@X1_larger
        SUB16 X1, X0, DX
        lda #0
@Calc_DY
        sta XS
        ; DY = abs(y0% - y1%)
        ; set YS to add or subtract
        lda Y0
        cmp Y1
        bcc @Y1_larger
        SUB8 Y0, Y1, DY
        lda #1
        bne @Done_calc
@Y1_larger
        SUB8 Y1, Y0, DY
        lda #0
@Done_calc
        sta YS
        ; y is 8 bit so if this is not 0 its larger
        lda DX + 1
        ; using reverse logic because branch is > 128
        beq @DX_DY_compare
        jmp @DX_larger
@DX_DY_compare
        lda DX
        cmp DY
        bcc @DY_larger
        jmp @DX_larger
@DY_larger
        ; K1 = 2 * DX
        MOVE16 DX, K1
        LSHIFT16 K1, 1
        ; K2%=2*(DX%-DY%)
        SUB16 DX, DY, K2
        LSHIFT16 K2, 1
        ; d%=K1%-DY
        SUB16 K1, DY, _D
        ; y=y0%
        lda Y0
        sta _Y
        ; x = x0
        MOVE16 X0, _X
; for y=y0% to y1% step YS%
@Y_loop_start
        lda _Y
        cmp Y1
        bne @Y_loop_continue
        jmp @Exitline
@Y_loop_continue
        ; plot
        ldx _Y
        jsr _Plot
        ; if d%<0 then y_loop_d0_minus
        lda _D + 1
        bmi @Y_loop_d0_minus
        ; x = x + XS
        lda XS
        beq @Y_loop_X_inc
        DEC16 _X
        jmp  @Y_loop_add_d
@Y_loop_X_inc
        INC16 _X
@Y_loop_add_d
        ; d% = d% + K2%
        ADD16 _D, K2, _D
        jmp @Y_loop_next
@y_loop_d0_minus
        ; d%=d%+K1%
        ADD16 _D, K1, _D
@y_loop_next
        ; y = y + YS
        lda YS
        beq @Y_loop_next_inc
        DEC8 _Y
        jmp @Y_loop_start
@Y_loop_next_inc
        inc _Y
        jmp @Y_loop_start
@DX_larger
        ; K1 = 2 * DY
        MOVE16 DY, K1
        LSHIFT16 K1, 1
        ; K2%=2*(DY%-DX%)
        SUB16 DY, DX, K2
        LSHIFT16 K2, 1
        ; d%=K1%-DX
        SUB16 K1, DX, _D
        ; y=y0%
        lda Y0
        sta _Y
        ; x = x0
        MOVE16 X0, _X
; for x=x0% to x1% step XS%
@X_loop_start
        lda _X + 1
        cmp X1 + 1
        bne @X_loop_continue
        lda _X
        cmp X1
        jmp @Exitline
@X_loop_continue
        ; plot
        ldx _Y
        jsr _Plot
        ; if d%<0 then x_loop_d0_minus
        lda _D + 1
        bmi @X_loop_d0_minus
        ; y = y + YS
        lda YS
        beq @X_loop_Y_inc
        DEC8 _Y
        jmp  @X_loop_add_d
@X_loop_Y_inc
        inc _Y
@X_loop_add_d
        ; d% = d% + K2%
        ADD16 _D, K2, _D
        jmp @X_loop_next
@X_loop_d0_minus
        ; d%=d%+K1%
        ADD16 _D, K1, _D
@X_loop_next
        ; x = x + XS
        lda XS
        beq @x_loop_next_inc
        DEC16 _X
        jmp @X_loop_start
@X_loop_next_inc
        INC16 _X
        jmp @X_loop_start
@Exitline
        ldx _Y
        jmp _Plot
;  HCPlotLine
; COLORPTR - X start
; XDIST   - X Distance
; YCOL     - Y Location
; Plot color memory line
HCPlotLine
        ; Save start, distance and end
        MOVE16 COLORPTR, StartX
        ; get the start byte
        jsr CalcColorByte
        MOVE16 XDIST, XD
        INC16 XD
        lda StartX
        and #%00000111
        beq @InitLoop
        ; subtract 8 - N from XD
        sta TMP
        sec
        lda #8
        sbc TMP
        sta TMP
        SUB168 XD, TMP, XD
        ; set color Memory
        ldy #0
        lda COLOR
        sta (COLORPTR),y
        INC16 COLORPTR
        ; set y to 0
@InitLoop
        ldy #0
@Loop
        lda XD + 1  ; check that there is more to process
                    ; check high byte first
        bne @LoopContinue
        lda XD      ; check low byte is at least 8 pixels
        cmp #08
        bcc @LoopExit
@LoopContinue
        ; set color Memory
        lda COLOR
        sta (COLORPTR),y
        INC16 COLORPTR
        ; subtract 8 from distance
        SUB16I XD, 8, XD
        jmp @Loop
@LoopExit
        ; check for last byte
        lda XD
        beq @Exit
        ; set color Memory
        lda COLOR
        sta (COLORPTR),y
@Exit
        rts
;  HGRHorizontalLine
; CURLOC IN POINTER to bitmap byte
; XDIST IN x distance
; X register IN bit in first byte of bitmap
HGRHorizontalLine
        ; If there are 8 bits to set then we can use bytes
        ; instead of using bits
        ; set the first potentially partial byte
        ; set x to number of bits in first byte
        lda XDIST + 1   ; load HI byte
        bne @HFirstByte ; if its not 0 then it > 8 bits
        cpx XDIST       ; see if bit is within distance
        bcc @HFirstByte ; yes so we leave x unmodified
        ldx XDIST       ; set x to XDIST
        jmp @HLastByte
@HFirstByte
        stx  COUNTER    ; save in counter
        lda #0          ; zero out high byte
        sta COUNTER + 1
        ; substract COUNTER from distance of first byte
        ; and save in COUNTER
        SUB16 XDIST, COUNTER, COUNTER
        ; Plot the first byte
        ldy #0
        lda (CURLOC),y
        ora MaskData,x
        sta (CURLOC),y
; Horizontal Line - Loop
; here we plot bytes instead of bits
@HLoop1
        ; test that there are at least 8 bits to plot
        lda COUNTER + 1 ; get the high byte
        bne @HLoop_Cont ; if its set there are more than 8 bits left
        lda COUNTER     ; load lo byte
        cmp #8          ; compare it to 8
        beq @HLoop1End  ; if it is equal then go to the last byte
        bcs @HLoop_Cont ; continue if > 8
        jmp @HLoop1End  ; less than 8 go to last byte
@HLoop_Cont             ; add 8 to current pointer
        ADD16I CURLOC, 8, CURLOC
        lda #$FF        ; load a with FF
        sta (CURLOC),y  ; store the byte
                        ; Increrment COUNTER by 8
        SUB16I COUNTER, 8, COUNTER
        jmp @HLoop1     ; goto to byte loop
@HLoop1End
        ldx COUNTER     ; see if there are bits left
        beq @HLoop1EXIT ; if no then exit
; Horizontal Lines Last Byte
@HLastByte
        lda (CURLOC),y
        ora MaskDataEnd,x
        sta (CURLOC),y
@HLoop1EXIT
        rts
;  HGRFillRect
HGRFillRect
        INC16 TXTPTR    ; advance basic textptr
        ; get the start position, xdistance and ydistance
        jsr RangeCheckXY
        stx Y0
        MOVE16 XCOORD, X0
        jsr CHKCOM
        jsr RangeCheckXY
        stx YDIST
        MOVE16 XCOORD, XDIST
;  HFillRect
; X0        -  xstart
; Y0        -  ystart
; XDIST     -  xdistance
; YDIST     -  ydistance
HFillRect
        ADD8 Y0, YDIST, YMAX
        ADD16 X0, XDIST, X1
        lda Y0
@YLOOP
        sta Y1
        jsr _Line2
        ldy Y0
        cpy YMAX
        beq @Exit
        iny
        sty Y0
        jmp @YLOOP
@Exit
        rts
;  HGRRect
;  Parse Basic text for
;  x, y, xdist, ydist
;  Call HRect for to draw rectangle
HGRRect
        jsr RangeCheckXY
        stx Y0
        MOVE16 XCOORD, X0
        jsr CHKCOM
        jsr RangeCheckXY
        stx YDIST
;  HRect
;  X0       - x start
;  Y0       - y start
;  XDIST    - x distance
;  YDIST    - y distance
HRect
        ADD16 X0, XDIST, XMAX
        ; Top Horizontal Line
        MOVE16 XMAX, X1
        MOVE8 Y0, Y1
        pha
        jsr _Line2
        ; Bottom Horizontal Line
        lda YMAX
        sta Y0
        sta Y1
        jsr _Line2
        ; Left Vertical Line
        MOVE16 X0, X1
        pla
        sta Y0
        jsr _Line
        ; Right Vertical Line
        MOVE16 XMAX, X0
        MOVE16 X0, X1
        jsr _Line
        rts
;  SetCircleJump
;  set routine for circle to plot or fill
SetCircleJump
        asl
        tax
        lda JumpTable, x
        sta CIRJUMP
        inx
        lda JumpTable, x
        sta CIRJUMP + 1
        rts
;  JumpCircle
;  SetCircleJump MUST be called first
;  This will fill or plot for circles
JumpCircle
         jmp (CIRJUMP)
JumpTable
        .word PlotCirclePixels
        .word PlotFillCircle
;  HGRFillCircle
;  Fill a circle from BASIC
;  x, y, radius
; Bresenham's algorithm
HGRFillCircle
        lda #1
        jsr SetCircleJump
        jmp HGRCircle2
;  HGRFillCircle
;  Fill a circle from asm
HGRFillCircle2
        lda #1
        jsr SetCircleJump
        jmp HGRCircle3
;  HGRCircle
;  x, y, radius
HGRCircle
        lda #0
        jsr SetCircleJump
HGRCircle2
        stx CY
        MOVE16 XCOORD, CX
        jsr GETBYTC
        stx R
        jsr RangeCheckCircle
HGRCircle3
        ; pk = 3 - 2 * r;
        lda #0
        sta PK + 1
        MOVE8 R, PK         ; pk = r
        LSHIFT16 PK,1       ; pk = r * 2
        MOVE16I TMP, 3;     ; tmp = 3
        SUB16 TMP, PK, PK   ; pk = tmp - pk
        MOVE16I CURX, 0     ; x = 0
        MOVE8 R, CURY       ; y = r
        ; PlotPixels(x, y, xc, yc);
        jsr JumpCircle
@StartWhile
        ; while (x < y)
        lda CURX + 1
        bne @ContinueWhile
        lda CURX
        cmp CURY
        bcs @Exit
@ContinueWhile
        ; if (pk <= 0)
        lda PK+1
        bmi @PKLessEqualZero
        bne @PKGreaterZero
        lda PK
        bne @PKGreaterZero
@PKLessEqualZero
        ; pk = pk + (4 * x) + 6;
        MOVE16 CURX, TMP
        LSHIFT16 TMP, 2
        ADD16 PK, TMP, PK
        ADD16I PK, 6, PK
        ;++x;
        INC16 CURX
        jmp @EndWhile
@PKGreaterZero
        ; pk = pk + (4 * (x - y)) + 10;
        SUB168 CURX, CURY, TMP
        LSHIFT16 TMP, 2
        ADD16I TMP, 10, TMP
        ADD16 PK, TMP, PK
        ; ++x;
        INC16 CURX
        ; --y;
        DEC8 CURY
@EndWhile
        jsr JumpCircle
        jmp @StartWhile
@Exit
        rts
;  PlotCirclePixels
;  plot circle pixels
PlotCirclePixels
        ; PutPixel(CX - CURX, CY + CURY);
        SUB16 CX, CURX, XCOORD
        ADD8 CY, CURY, Y1
        tax
        jsr _Plot
        ; PutPixel(CX + CURX, CY + CURY);
        ADD16 CX, CURX, XCOORD
        ldx Y1
        jsr _Plot
        ; PutPixel(CX - CURX,  CY - CURY);
        SUB8 CY, CURY, Y1
        tax
        jsr _Plot
        ; PutPixel(CX + CURX, CY - CURY);
        ldx Y1
        jsr _Plot
        ; PutPixel(CX - CURY, CY + CURX);
        SUB168 CX, CURY, XCOORD
        ADD8 CY, CURX, Y1
        tax
        jsr _Plot
        ; PutPixel(CX + CURY, CY + CURX);
        ADD168 CX, CURY, XCOORD
        ldx Y1
        jsr _Plot
        ; PutPixel(CX - CURY, CY - CURX);
        SUB8 CY, CURX, Y1
        tax
        jsr _Plot
        ; PutPixel(CX + CURY, CY - CURX);
        ldx Y1
        jmp _Plot
;  PlotFillCircle
;  fill circle pixels
PlotFillCircle
        ; Line(CX - CURY, CY + CURX) to (CX + CURY, CY + CURX)
        SUB168 CX, CURY, X0
        ADD8 CY, CURX, Y0
        ADD168 CX, CURY, X1
        MOVE8 Y0, Y1
        jsr _Line2
        ; Line (CX - CURY, CY - CURX) to (CX + CURY, CY - CURX)
        SUB168 CX, CURY, X0
        SUB8 CY, CURX, Y0
        ADD168 CX, CURY, X1
        MOVE8 Y0, Y1
        jsr _Line2
        ; Line(CX - CURX, CY + CURY) to (CX + CURX, CY + CURY)
        SUB16 CX, CURX, X0
        ADD8 CY, CURY, Y0
        ADD16 CX, CURX, X1
        MOVE8 Y0, Y1
        jsr _Line2
        ; Line(CX - CURX, CY - CURY) to (CX + CURX, CY - CURY)
        SUB16 CX, CURX, X0
        SUB8 CY, CURY, Y0
        ADD16 CX, CURX, X1
        MOVE8 Y0, Y1
        jmp _Line2
;  RangeCheckXY
;  Check XCOORD and x range
RangeCheckXY
        cpx # 200
        bcs RangeError
        lda XCOORD + 1
        beq @Exit
        lda XCOORD
        cmp # 320 - 256
        bcs RangeError
@Exit
        rts
RangeError
        ldx # ILLEGALQUANITY
        jmp ERROR
;  RangeCheckCircle
;  Range check Circle parameters
RangeCheckCircle
        lda CY
        cmp R
        bcc RangeError
        adc R
        tax
        lda CX + 1
        bne @CheckMax
        lda CX
        cmp R
        bcc RangeError
@CheckMax
        ADD168 CX,R,XCOORD
        jmp RangeCheckXY
;  HSourceMode
;  Set source plotmode
HSourceMode
        jsr GETBYTC
        stx SRCM
        rts
MaskStart
        .byte %00000001 ; 0
        .byte %00000010 ; 1
        .byte %00000100 ; 2
        .byte %00001000 ; 3
        .byte %00010000 ; 4
        .byte %00100000 ; 5
        .byte %01000000 ; 6
        .byte %10000000 ; 7
MaskData
        .byte %00000001 ; 0
        .byte %00000011 ; 1
        .byte %00000111 ; 2
        .byte %00001111 ; 3
        .byte %00011111 ; 4
        .byte %00111111 ; 5
        .byte %01111111 ; 6
        .byte %11111111 ; 7
MaskDataEnd
        .byte %00000000 ; 0
        .byte %10000000 ; 1
        .byte %11000000 ; 2
        .byte %11100000 ; 3
        .byte %11110000 ; 4
        .byte %11111000 ; 5
        .byte %11111100 ; 6
        .byte %11111110 ; 7
        .byte %11111111 ; 8
Proxy
Post by Proxy »
you say PASM is platform independent, but it's written in C++ and requires Flex and Bison to be build, so how would you build that to run on it a 6502?
hjalfi
Post by hjalfi »
I have one for CP/M-65 written in C, compiling with llvm-mos. It reads in a text file and writes out a binary. It ends up being about 20kB of code. https://github.com/davidgiven/cpm65/blo ... apps/asm.c
