Single step (ram) with BRK
barnacle
Re: Single step (ram) with BRK
Post by barnacle »
Hmm, that's something I had not considered. Time for a rethink :D
rudla.kudla
Post by rudla.kudla »
You will probably also need to print a list of all currently defined breakpoints and allow clearing some of them.
The best option probably is to have a list of breakpoint addresses and search a breakpoint based on it's address. The same table will contain the code of the instruction you replaced with BRK.
Dietrich
Post by Dietrich »
You might want to have a look on my DEBUG.COM, which offers most of the discussed features with the notable exception of stepping through ROM code. The program uses the BRK method and enables to set up tp 8 breakpoints [0..7]. The source can be found here: https://github.com/Dietrich-L/CPM-65/bl ... /DEBUG.ASM
Command syntax :
        DEBUG V1.7                     (c) 14.6.1990
Command Summary:
 Dnnnn,mmmm dump memory          Fnnnn,mmmm,cc fill memory
 Gnnnn      go from nnnn         Znn        wait for nn/10 s
 Lnnnn,mmmm list mnemonics       Ennnn,bb,bb.. enter bytes
 Rfilename.ext read file         Wfilename.ext write file
 Nfilename.ext FCB1=filename
 Cnnnn,<string>     enter string Snnnn,mmmm,bb,..   search bytes
 Tdd        trace dd steps       Xr,bb      set register
 Jdd        jump dd opcodes      Mn,m,j     move to n from m,j
 Bd,nnnn    set breakpoint       Kd         kill breakpoint
 ?          prints this screen   ;          command separator
 /dd        repeat dd times      Q          quit to CP/M
The progam installs itself in high memory at $C000, the code to be analyzed can be anywhere in the available RAM.
Enjoy
Dietrich
My system: Elektor Junior Computer, GitHub https://github.com/Dietrich-L
