Re: VGA 320x480x256 with discrete logic
Posted: Tue Feb 01, 2022 7:19 pm
CountChocula wrote:
I have actually thought about this… I was thinking of adding a separate counter for the memory, which I think might also be used to prevent any memory from being used during the blanking interval (as I could just disable the counters when /BLANK is low). This opens up some interesting opportunities, because it would allow 320x200 to fit in a single 64kB chip. Have you tried anything similar? I worry about keeping the two counters properly synchronized.
Chad pointed out though that this doesn't work as well when double-scanning - I'd forgotten about that, oops! 256x240 wouldn't suffer though as the horizontal width is a power of two - you wouldn't need separate visible-pixel counters for that one. It is very appealing.
Also—I hear you on the 640x400 woes. My monitor handles it, but it thinks it's a much weirder resolution (like, 720x480, which isn't even a real VGA resolution).
I was actually thinking about this last night after I wrote my post… I did verify that the reset bit is being flipped on the last pixel, but it's occurred to me that the sync ROM operates at 1/8th the clock speed, which means that, as far as the monitor is concerned, the count restarts seven pixels too early, so I wonder whether that might be the problem. I will try to reset at the beginning of the lines instead and see if being one pixel too late a similar effect in the other direction.
I have had a bit of trouble sourcing 74AC163s, btw… very hard to find unless you want to buy 1,200 of them
Yes, I figure that's something like that… I'm going to hook it up the 'scope and trigger it on the transition of the /OE lines between the counter buffers and the PIC latches to see what happens on the bus… it might be that I'm underestimating the time it takes for the signals to stabilize.
I'd expect that if you start WE too early you might write to the wrong address first; if you end it too late you'd also write to the wrong address, and may also cause temporary corruption of the visual display ("snow" while writing is occurring, that goes away after the writing finishes). If the duration of WE is too short, it may fail to write at all, or write to the right address but with the wrong value. It's possible that you can tweak the timing and see which of these effects happen. It's tricky though to accurately adjust the timing at this frequency using discrete logic. I recently switched to a simple PLD (ATF16V8) and of course it makes things much easier.
I remember watching that video! I think I may have to do the same thing (crazy to think that there isn't any kind of readily-available software that will do these kind of simulations automatically… you'd think that by now this kind of functionality would be fairly routine.)
