For anyone interested, here's the Quick Basic version of table-based 2D rotations.
There's the BASIC source file and the compiled version which rotated a test pattern around 360 degrees in 10 degree increments. It has a 1 second delay between rotations. You can press the <Space Bar> to speed it up.
I didn't have enough time to do it in assembly, but it should be a straight forward process.
Download the Zip'd file from my web site (I'll leave it there for 30 days).
(Right Click and select "save target as"):
http://65c02.tripod.com/2drot.zip
"Undo", I hope this helps. You'll only need 4K for the tables. I don't know how much for the code. 6K may have been a little large.
Fast 2D rotation for 6510
2d rotations
Hi Everyone,
I just had to get my $0.02 in and make this my first post
Steve Judd ( I think ) posted something a long long time ago which is a pretty good trade off between speed & accuracy; a 256 byte table is all you need + some trickery
Fast multiply: don't blink or you'll miss it.
Let f(x) = x^2 / 4. Then
a*b = f(a+b) - f(a-b)
Thus with a table of squares you can do integer multiplies very quickly.
To see an implementation of this algorithm, see C=Hacking.
check it out at www.ffd2.com for more info. I've used it successfully on the GBC and some C64 stuff a long time ago..
Yvo
Yvo
Sounds like this thing.
http://www.cfxweb.net/modules.php?name= ... le&sid=664
Btw, there is a method based on shears,
12
34
12
34 (+x shear)
31
42 (+y shear)
and there is variations that rotate by other odd degrees like 22, read a paper once..
use something like a bresenham to get weird shears..
http://www.cfxweb.net/modules.php?name= ... =0&thold=0
12
34
12
34 (+x shear)
31
42 (+y shear)
Re: 2d rotations
If a and b are 8-bits, then a+b is 9 bits ($FF+$FF = $1FE). Also, the square of an 8-bit number is a 16-bit number. So, 512 entries at 16-bits each yields 1024 bytes devoted to table data.
That being said, however, you can still use 8-bit arithmetic to address it using some of those "tricks" you've been talking about.
For example:
ma = $F0 ; input A
mb = $F1 ; input B
mapb = $F2 ; temporary: ((A+B)^2)/4; also holds results
mamb = $f4 ; temporary: ((A-B)^2)/4
mul8x8:
clc ; Compute ((A+B)^2)/4
lda ma
adc mb
bcs 1$
tax
lda sqtable00,x
sta mapb
lda sqtable01,x
sta mapb+1
jmp 2$
1$:
tax
lda sqtable10,x
sta mapb
lda sqtable11,x
sta mapb+1
2$:
sec ; Compute ((A-B)^2)/4
lda ma
sbc mb
bcc 3$
tax
lda sqtable00,x
sta mamb
lda sqtable01,x
sta mamb+1
jmp 4$
3$:
tax
lda sqtable10,x
sta mamb
lda sqtable11,x
sta mamb+1
4$:
sec ; Subtract them to get AB.
lda mapb
sbc mamb
sta mapb
lda mapb+1
sbc mamb+1
sta mamb+1
rts
sqtable00 is the table of square's for sums 0-255, low byte.
sqtable01 is the table of square's for sums 0-255, high byte.
sqtable10 is the table of square's for sums 256-511, low byte.
sqtable11 is the table of square's for sums 256-511, high byte.
NOTE: For this to all fit in 16-bits or less, you must store the squares pre-divided by four. That is, the second entry for sqtable00 isn't 4, as you'd expect, it's 1.
NOTE: This is an unsigned multiply. You need a wrapper around this multiplication code to handle signed multiplications. But this is true of most 6502 multiplication subroutines anyway.
The 65816 represents a more convenient package to do this type of multiplication with (note: this is my first attempt at coding 65816-version of the above code, so it might have some errors, and could probably stand more optimization):
ma = $F0 ; input A (byte!)
mb = $F2 ; input B (byte!)
mapb = $F4
mamb = $F6
mul8x8_16:
longa on ; Assume accumulator is 16-bits wide,
longi on ; as are the index registers.
sep #MF ; But first, zero the high-bytes of the input parameters
stz ma+1 ; guarantees the subroutine will work without additional
stz mb+1 ; error handling.
rep #MF
sec ; Compute ((A-B)^2)/4 first.
lda ma
sbc mb
and #$01FF ; AND in case the result is negative; confines result into valid index bounds
asl a
tax
lda sqtable,x
sta mamb
clc ; Compute ((A+B)^2)/4 next. We do this here so we avoid having
lda ma ; to refetch its value from memory. It's already in A, so we just...
adc mb
asl a ; Note we don't need to AND for addition. High bits guaranteed to be clear.
tax
lda sqtable,x
sec
sbc mamb ;... subtract the other term, and A now has the product.
rts
Interestingly enough, a 16x16=32 multiplication subroutine for the 65816 would take on the same form as the mul8x8 routine for the 6502, with similar performances. But it would require a 512KB square table.
-- algebraic derivation for those who don't believe --
ab = ((a+b)^2)/4 - ((a-b)^2)/4
ab = ((a+b)^2 - (a-b)^2)/4
ab = ((a^2+2ab+b^2) - (a^2-2ab+b^2))/4
ab = (a^2+2ab+b^2-a^2+2ab-b^2)/4
ab = (a^2-a^2+2ab+2ab+b^2-b^2)/4
ab = (4ab)/4
ab = ab
Anonymous wrote:
I think I can give you a method using look-up tables and no multiplication/division if you can afford about 6k for the tables & code.
The basic idea is pre-calculate the new x,y position from the old one for each pixel. Since you are rotating about the center, you only have to calculate one quarter of the screen. The other three will be the same offsets, they'll just have different signs. Since you will be limiting the angles to 10,20,30, ect, only 8 tables would be needed. Each table will hold 2 bytes for each of the 256 pixels in the first quadrant (the new x and new y). This method will also eliminate the need to check to see if a pixel was rotated "off the screen".
Let me know if this method sounds practical.
A better solution is to use reverse mapping. This only requires calculating four rotations for the corners, then it's linear interpolation for the rest of the pixels.
Also, this gives you scaling for free.
Toshi
