Page 2 of 2
Re: Using x and y registers as an address
Posted: Fri Nov 10, 2023 10:10 pm
by pistolhamster
This was a good read, thank you to those who gave such well explained advice.
Allow me to ask a question: Like the OP, I dabble a bit with a simple project where I need to dynamically change memory addresses.
I want to print a series of characters on the screen starting with $0400 and ending with $07e7. To do that I have written four loops Right, down, left, up.
something like this
*=$1000
right:
lda #$d7 // petscii circle
sta $0400,x
inx
cpx #40 // max length of row.
bne right
That is not too hard, the X index stops at 40, but I struggle with the "down" bit
ldy #0
stx $1100
down:
sta $0400,x // X must increase 40 per cycle to print downwards in a line
lda $1100 //get the stored X value (should be 40 first pass)
adc #40
sta $1101 //
ldx $1100
iny
cpy #25 // with 25 rows this is the max
bne down
It works until x ($1100) reaches 255, then the x index flips because it has 8 bits only, and my whole little thing comes crashung down.
Could I change the routine so that I don't address $0400,x but increment the address itself that the petscii circle is stored to?
Posted: Fri Nov 10, 2023 11:46 pm
by richardc64
Is that a typo or have you coined a neologism, a new word for flawed code, combining "crash" & "hung", much like hangry?
Posted: Sat Nov 11, 2023 12:51 am
by gfoot
Typically you would store the address in two consecutive bytes of page zero, and adjust them there by doing 16-bit adds or subtracts. Then to read or write the target memory location you set X or Y to zero and use indexed indirect addressing, i.e. (zpaddr,x) or (zpaddr),y.
However you can certainly use self-modifying code instead, if your code is in RAM. Garth linked to some examples of that upthread.
The case where self-modifying code doesn't work so well is where there are two or more instructions that all need to use the same address. There are some more complex techniques to cater for that a bit but it's simpler to just use indirect indexed addressing.
Posted: Sat Nov 11, 2023 1:33 am
On the 65c02, you can also do it without indexing, with:  ADC (ZP),  AND (ZP),  CMP (ZP),  EOR (ZP),  LDA (ZP),  ORA (ZP),  SBC (ZP),  and  STA (ZP).
Posted: Sat Nov 11, 2023 8:35 am
by pistolhamster
It would be an excellent example of serendipity. Alas, it was a typo. But yes, why not? "It crashung"
Posted: Sun Nov 12, 2023 2:43 pm
by pistolhamster
Thanks, you put me on the track again. This is what I managed to write and test, I now have a nice column of petscii circles.
ldx #$27
ldy #$04
stx $60 // low byte address
sty $61 // high byte address
ldy #0 // counter
down:
    clc
    lda #81 //petscii circle
    sta ($60),y
    lda $60 // get low byte
    adc #40 // add 40 for next line
    sta $60 // store new value
    lda $61 // get high byte
    adc #0
    sta $61
    inx
    cpx #25 // max rows
    bne down
Posted: Sun Nov 12, 2023 3:07 pm
by gfoot
Yes that's the idea. Note Garth's point that with a modern 65C02 you can also do it without using an index register.
Even on older CPUs you can also speed things up a little by swapping the roles of the Y register and the low byte of the address, i.e. $60. So you'd store zero at $60 and put the low byte of your target address into Y instead. This doesn't affect the function of the STA line, but it allows you to save a few cycles in the addition as now you can use TYA instead of LDA $60, and TAY instead of STA $60.
Posted: Mon Nov 13, 2023 1:19 am
ldx #$27
ldy #$04
ldx #25 ;rows
ldy #0 // counter
down:
    sta ($60),y
    clc
    adc #0
    sta $61
    dex
    bne down ;more rows
Posted: Wed Nov 15, 2023 9:09 am
by barrym95838
Solid advice, every word. Shaved two bytes and ten cycles from the inner loop.
    ldy #$27
    ldx #$04
    stx $61     // high byte address
    ldx #0
    ldx #25     // counter
down:
    clc
down2:
    lda #81     // petscii circle
    sta ($60),y
    dex
    beq done
    tya         // get low byte
    tay         // store new value
    bcc down2
    inc $61     // update high byte
    bcs down
done:
Posted: Wed Nov 15, 2023 8:49 pm
by pistolhamster
Oh, that was a clever thing. Thank you.
IS the 65C02 the same as the WDC 65C02 that is still manufactured? I've seen that it will be the heart of the new Commander X16.
Posted: Thu Nov 16, 2023 4:02 am
by Dr Jefyll
Yeah, pretty much... especially software-wise. Compared with C02's from Rockwell and CMD, for example, the current WDC product has a couple of new instructions, but they're ones you're unlikely to use -- STP and WAI. (And are you concerned about the hardware side of things? Briefly, the WDC chips can be run faster and they have some slight but important changes to the pinout; also the inputs no longer accept TTL voltage levels.)
