It has to do two subtractions in many cases. For example, if the input number is 79999 ($1387f), the loop on the first byte will get down to 80000 ($13880), see that the first byte matches, and conclude that that first digit might be 8. It has do the comparison all the way to the lowest byte to find that it isn't. But even with that it does look like an improvement over the "subtract powers of 10" version.
I'm still fond of double-dabble for its simplicity and versatility. Change the "half" and "double" parts, and it can handle conversions between any two formats, including mixed radix ones like HH:MM:SS for time.
Nope. Still only one subtraction, but 3 comparisons. 80000 will be found at T8E4 and only needs one subtraction from the input value.
The main loop should look like this:
* Step #1) X_BYTES is stored in the X-reg and starts at the highest byte in its category to compare the
* table's hi-byte with the hex value hi-byte (i.e. LDX X_BYTES,Y where Y is the number of hex bytes in the input value)
* If table byte is greater than input byte, the X-reg is subtracted by the number of digits to get the next lower hi-byte from the table
* If the hi-bytes are equal, then a comparison of the next lower hex byte will need to be made until the table byte is less than input byte or the byte counter is zero
* Once the table hex byte is lower than the input byte, the subtraction can be made for all hex digits of the input value
* After the subtraction is made and the new value stored, the new value should have one less hex byte to deal with.
* The number of hex bytes is reduced by one and put into the Y-reg
* if Y-reg <> 0 then loop back to the first step
Here is the table that would be used for an 8-digit hex (max $FF FF FF FF FF FF FF FF)(20-digit decimal #).
INPUTHEXVAL DS 8
HEXDIGSLO DFB 09,00,#ONEHEX,#TWOHEX,#THREHEX,#FOURHEX
DFB #FIVEHEX,#SIXHEX,#SEVENHEX,#EIGHTHEX,#NINEHEX
HEXDIGSHI DFB 09,00,#<ONEHEX,#<TWOHEX,#<THREHEX,#<FOURHEX
DFB #<FIVEHEX,#<SIXHEX,#<SEVENHEX,#<EIGHTHEX,#<NINEHEX
X_BYTES HEX 00
DFB TWOHEX-ONEHEX ; 0A
DFB THREHEX-TWOHEX ; 2B
DFB FOURHEX-THREHEX ; 41
DFB FIVEHEX-FOURHEX ; 53
DFB SIXHEX-FIVEHEX ; 77
DFB SEVENHEX-SIXHEX ; 72
DFB EIGHTHEX-SEVENHEX ; A1
DFB NINEHEX-EIGHTHEX ; A8
DFB ENDTABLE-NINEHEX ; 50
* The "e" stands for the number of zeroes that follow (1e3 = 1000, 2e3 = 2000 .. etc )
ONEHEX EQU *
T1e1 HEX 0A
T2e1 HEX 14
T3e1 HEX 1E
T4e1 HEX 28
T5e1 HEX 32
T6e1 HEX 3C
T7e1 HEX 46
T8e1 HEX 50
T9e1 HEX 5A
T1e2 HEX 64
T2e2 HEX C8
TWOHEX EQU *
T3e2 HEX 2C,01
T4e2 HEX 90,01
T5e2 HEX F4,01
T6e2 HEX 58,02
T7e2 HEX BC,02
T8e2 HEX 20,03
T9e2 HEX 84,03
T1e3 HEX E8,03
T2e3 HEX D0,07
T3e3 HEX B8,0B
T4e3 HEX A0,0F
T5e3 HEX 88,13
T6e3 HEX 70,17
T7e3 HEX 58,1B
T8e3 HEX 40,1F
T9e3 HEX 28,23
T1e4 HEX 10,27
T2e4 HEX 20,4E
T3e4 HEX 30,75
T4e4 HEX 40,9C
T5e4 HEX 50,C3
T6e4 HEX 60,EA
THREHEX EQU *
T7e4 HEX 70,11,01
T8e4 HEX 80,38,01
T9e4 HEX 90,5F,01
T1e5 HEX A0,86,01
T2e5 HEX 40,0D,03
T3e5 HEX E0,93,04
T4e5 HEX 80,1A,06
T5e5 HEX 20,A1,07
T6e5 HEX C0,27,09
T7e5 HEX 60,AE,0A
T8e5 HEX 00,35,0C
T9e5 HEX A0,BB,0D
T1e6 HEX 40,42,0F
T2e6 HEX 80,84,1E
T3e6 HEX C0,C6,2D
T4e6 HEX 00,09,3D
T5e6 HEX 40,4B,4C
T6e6 HEX 80,8D,5B
T7e6 HEX C0,CF,6A
T8e6 HEX 00,12,7A
T9e6 HEX 40,54,89
T1e7 HEX 80,96,98
FOURHEX EQU *
T2e7 HEX 00,2D,31,01
T3e7 HEX 80,C3,C9,01
T4e7 HEX 00,5A,62,02
T5e7 HEX 80,F0,FA,02
T6e7 HEX 00,87,93,03
T7e7 HEX 80,1D,2C,04
T8e7 HEX 00,B4,C4,04
T9e7 HEX 80,4A,5D,05
T1e8 HEX 00,E1,F5,05
T2e8 HEX 00,C2,EB,0B
T3e8 HEX 00,A3,E1,11
T4e8 HEX 00,84,D7,17
T5e8 HEX 00,65,CD,1D
T6e8 HEX 00,46,C3,23
T7e8 HEX 00,27,B9,29
T8e8 HEX 00,08,AF,2F
T9e8 HEX 00,E9,A4,35
T1e9 HEX 00,CA,9A,3B
T2e9 HEX 00,94,35,77
T3e9 HEX 00,5E,D0,B2
T4e9 HEX 00,28,6B,EE
FIVEHEX EQU *
T5e9 HEX 00,F2,05,2A,01
T6e9 HEX 00,BC,A0,65,01
T7e9 HEX 00,86,3B,A1,01
T8e9 HEX 00,50,D6,DC,01
T9e9 HEX 00,1A,71,18,02
T1e10 HEX 00,E4,0B,54,02
T2e10 HEX 00,C8,17,A8,04
T3e10 HEX 00,AC,23,FC,06
T4e10 HEX 00,90,2F,50,09
T5e10 HEX 00,74,3B,A4,0B
T6e10 HEX 00,58,47,F8,0D
T7e10 HEX 00,3C,53,4C,10
T8e10 HEX 00,20,5F,A0,12
T9e10 HEX 00,04,6B,F4,14
T1e11 HEX 00,E8,76,48,17
T2e11 HEX 00,D0,ED,90,2E
T3e11 HEX 00,B8,64,D9,45
T4e11 HEX 00,A0,DB,21,5D
T5e11 HEX 00,88,52,6A,74
T6e11 HEX 00,70,C9,B2,8B
T7e11 HEX 00,58,40,FB,A2
T8e11 HEX 00,40,B7,43,BA
T9e11 HEX 00,28,2E,8C,D1
T1e12 HEX 00,10,A5,D4,E8
SIXHEX EQU *
T2e12 HEX 00,20,4A,A9,D1,01
T3e12 HEX 00,30,EF,7D,BA,02
T4e12 HEX 00,40,94,52,A3,03
T5e12 HEX 00,50,39,27,8C,04
T6e12 HEX 00,60,DE,FB,74,05
T7e12 HEX 00,70,83,D0,5D,06
T8e12 HEX 00,80,28,A5,46,07
T9e12 HEX 00,90,CD,79,2F,08
T1e13 HEX 00,A0,72,4E,18,09
T2e13 HEX 00,40,E5,9C,30,12
T3e13 HEX 00,E0,57,EB,48,1B
T4e13 HEX 00,80,CA,39,61,24
T5e13 HEX 00,20,3D,88,79,2D
T6e13 HEX 00,C0,AF,D6,91,36
T7e13 HEX 00,60,22,25,AA,3F
T8e13 HEX 00,00,95,73,C2,48
T9e13 HEX 00,A0,07,C2,DA,51
T1e14 HEX 00,40,7A,10,F3,5A
T2e14 HEX 00,80,F4,20,E6,B5
SEVENHEX EQU *
T3e14 HEX 00,C0,6E,31,D9,10,01
T4e14 HEX 00,00,E9,41,CC,6B,01
T5e14 HEX 00,40,63,52,BF,C6,01
T6e14 HEX 00,80,DD,62,B2,21,02
T7e14 HEX 00,C0,57,73,A5,7C,02
T8e14 HEX 00,00,D2,83,98,D7,02
T9e14 HEX 00,40,4C,94,8B,32,03
T1e15 HEX 00,80,C6,A4,7E,8D,03
T2e15 HEX 00,00,8D,49,FD,1A,07
T3e15 HEX 00,80,53,EE,7B,A8,0A
T4e15 HEX 00,00,1A,93,FA,35,0E
T5e15 HEX 00,80,E0,37,79,C3,11
T6e15 HEX 00,00,A7,DC,F7,50,15
T7e15 HEX 00,80,6D,81,76,DE,18
T8e15 HEX 00,00,34,26,F5,6B,1C
T9e15 HEX 00,80,FA,CA,73,F9,1F
T1e16 HEX 00,00,C1,6F,F2,86,23
T2e16 HEX 00,00,82,DF,E4,0D,47
T3e16 HEX 00,00,43,4F,D7,94,6A
T4e16 HEX 00,00,04,BF,C9,1B,8E
T5e16 HEX 00,00,C5,2E,BC,A2,B1
T6e16 HEX 00,00,86,9E,AE,29,D5
T7e16 HEX 00,00,47,0E,A1,B0,F8
EIGHTHEX EQU *
T8e16 HEX 00,00,08,7E,93,37,1C,01
T9e16 HEX 00,00,C9,ED,85,BE,3F,01
T1e17 HEX 00,00,8A,5D,78,45,63,01
T2e17 HEX 00,00,14,BB,F0,8A,C6,02
T3e17 HEX 00,00,9E,18,69,D0,29,04
T4e17 HEX 00,00,28,76,E1,15,8D,05
T5e17 HEX 00,00,B2,D3,59,5B,F0,06
T6e17 HEX 00,00,3C,31,D2,A0,53,08
T7e17 HEX 00,00,C6,8E,4A,E6,B6,09
T8e17 HEX 00,00,50,EC,C2,2B,1A,0B
T9e17 HEX 00,00,DA,49,3B,71,7D,0C
T1e18 HEX 00,00,64,A7,B3,B6,E0,0D
T2e18 HEX 00,00,C8,4E,67,6D,C1,1B
T3e18 HEX 00,00,2C,F6,1A,24,A2,29
T4e18 HEX 00,00,90,9D,CE,DA,82,37
T5e18 HEX 00,00,F4,44,82,91,63,45
T6e18 HEX 00,00,58,EC,35,48,44,53
T7e18 HEX 00,00,BC,93,E9,FE,24,61
T8e18 HEX 00,00,20,3B,9D,B5,05,6F
T9e18 HEX 00,00,84,E2,50,6C,E6,7C
T1e19 HEX 00,00,E8,89,04,23,C7,8A
NINEHEX EQU *
T2e19 HEX 00,00,D0,13,09,46,8E,15,01
T3e19 HEX 00,00,B8,9D,0D,69,55,A0,01
T4e19 HEX 00,00,A0,27,12,8C,1C,2B,02
T5e19 HEX 00,00,88,B1,16,AF,E3,B5,02
T6e19 HEX 00,00,70,3B,1B,D2,AA,40,03
T7e19 HEX 00,00,58,C5,1F,F5,71,CB,03
T8e19 HEX 00,00,40,4F,24,18,39,56,04
T9e19 HEX 00,00,28,D9,28,3B,00,E1,04
T1E20 HEX 00,00,10,63,2D,5E,C7,6B,05
ENDTABLE EQU *
The table was smaller than I thought it would be at just under 900 bytes.
I will give everyone a chance to play with the table before posting my own code.
I left a kind of easter egg in this table. Can you spot it?
Happy programming!
