Re: Rockwell 6551 - Clock Questions
Posted: Wed Feb 26, 2025 5:59 pm
I have the case of a dual 6551 ACIA board from the RM 65 family from Rockwell. I don't have the schematic. It only has a 1.8432 Mhz Xtal to drive both ACIAs. I think it is not possible to connect the Xtal directly to both ACIAs, so I assume that the card must incorporate a pierce oscillator with the Xtal, resistors, capacitors and TTL inverters.
In that case, could the oscillator's output inverter be connected to the XTLI pins of both ACIAs, leaving the XTLOs pins floating? And, by the way, would it make sense to assign the binary value 1 to bit 4 in the control register of one of the ACIAs? For example, $0E for 9600bps, 1 stop bit, 8 data bit.
