Poll - Which Assembler Do You Use?
Ruud
Re: Poll - Which Assembler Do You Use?
Post by Ruud »
Mike Naberezny wrote:
Which assembler are you using, and why?
My own own, capable of handling the 65(C)02, 65816, Gideons 65GZ032 and the Z80. The last one because the Commodore 128 has both a 8502 and Z80 onboard.
What I especially like about it: it is free!
Interested? See: http://www.baltissen.org/mp_assem.htm
    ___
   / __|__
  / /  |_/     Groetjes, Ruud
  \ \__|_\
   \___|       URL: www.baltissen.org
andyd
Post by andyd »
Memblers wrote:
I use cc65 (http://www.cc65.org/). But, I've never used the C compiler (I don't know how to, honestly heheh), only the assembler and linker. I like being able to use the segments and linker config, being able to reserve bytes of RAM/ROM right next to the code that uses it, stuff like that.
Like Memblers, I also use the CC65 Assembler. I really like the relocatable code support and memory segment support of it so I can write modules and not have to worry about addressing until "Link - Time"
It is nice that cc65 supports so many targets (15 or 16), including Apple II, Comadore, Atari, Amiga, NES, and others. I am in the process of modifying one of the existing traget defineitions to meet my specific needs.
It is open source and runs under Linux, Windows, other uincies and Mac OS X.
I had some difficulites getting cc65 up under Mac OS X, but it was mostly my misunderstandings and inexperience with Unix applicaitons.
CC65 supports 6502, 65C02 and 65816 and I am Looking forward to being able to do projects in both assembler and C.
Later,
Andy
djmips
Post by djmips »
asmlang_6
Post by asmlang_6 »
I prefer to assemble by hand. I like to do it the way Woz did for the
Apple ][ ROMs.
Sam
"OK, let's see, A0 on the 6502 goes to the ROM. Now where was that reset vector?"
I started out that way and gained a great benefit from it. Don't stop there though-- you'll sell yourself short. You don't lose any control with an assembler, including with conditional assembly, macros, and other things that make assembly a lot more powerful. Even in Forth (unlike other high-level languages with their black-box compilers), you can predict exactly what bytes will be compiled if you want to go through the motions by hand. No control is lost.
