Page 2 of 2
Re: Optimization competition: An efficient calling conventio
Posted: Tue Jun 23, 2020 2:58 am
by johnwbyrd
johnwbyrd wrote:
For that reason, a 65816-only solution, that may or may not use the Z accumulator, is also of interest.
There is no "Z accumulator" in the 65C816. The 65C816's registers are .A, .B, .X, .Y, DB, DP, PB, PC and SP.
D'oh! I was confusing the 65816 and the obscure 65CE02, which apparently had a Z register.
Posted: Tue Jun 23, 2020 3:13 am
by johnwbyrd
barrym95838 wrote:
I certainly don't know if I'm misunderstanding or oversimplifying, but my attempt which does what you seem to describe would be:
; add two 16-bit numbers in zp:
; x and y point to the addends, a points to the sum
; a and x are modified, y is preserved
If I count correctly (big if), 57 cycles between jmp main and brk, one cycle faster than BillG's fastest NMOS attempt.
At first glance, this code seems to me to behave as per the specifications -- let's see if any more cycles can be shaved off by others...
Posted: Tue Jun 23, 2020 3:48 am
by johnwbyrd
BillG wrote:
        org     0
P3      db      0       ; Pointer to third operand
SumLow  db      0
Num1    dw      1234    ; First number
Num2    dw      5678    ; Second number
Num3    dw      0       ; Sum
; (P1) + (P2) -> (P3)
Add
        sta     P3
        clc
        lda     0,Y
        adc     0,X
        sta     SumLow
        lda     1,Y
        adc     1,X
        ldx     P3      ; Point to sum
        sta     1,X
        lda     SumLow
        sta     0,X
        rts
Start
        ldy     #Num1   ; Store pointer to first number
        ldx     #Num2   ; Store pointer to second number
        lda     #Num3   ; Store pointer to sum
        jsr     Add     ; Add them
        end     Start
It's fascinating that juggling SumLow into a temporary zero page location, and handling the low byte last, seems to produce a faster result.
Posted: Tue Jun 23, 2020 4:06 am
The Z register in the 65CE02 has no analog in the 65C816.
Posted: Thu Jul 16, 2020 10:24 am
by johnwbyrd
Any more suggestions? The existing entries seem optimal superficially, but I still hold out hope.
Lest that any of you think that this is purely an academic competition, let me quietly tease some screenshots of my current work.
Note the line number 7773, which is my attempt at a l33t spelling of LLVM.
Posted: Thu Jul 16, 2020 2:38 pm
by BillG
Are you working on a virtual machine or compiler backend infrastructure?
Posted: Thu Jul 16, 2020 8:09 pm
by johnwbyrd
Yes to both. The first is a by-product of the second. Code optimized for speed would be emitted in ordinary 6502 assembly. But code optimized for size would be emitted in an LLVM IR-like bytecode, to be parsed by a runtime language interpreter, and hence this calling convention would apply.
Posted: Mon Aug 10, 2020 7:27 pm
by johnwbyrd
Going once...
Posted: Fri Aug 14, 2020 7:57 pm
by johnwbyrd
Going twice...
Posted: Sun Sep 13, 2020 8:33 pm
by johnwbyrd
The optimization competition is now over!
:idea: :idea: :idea:
I award Top Honors to BillG for embracing the problem so completely, and for eventually finding the fastest solution. :D
However, an important Inspirational Award goes to barrym95838, for finding the creative breakthrough that enabled the fastest solution to exist. 8)
Congratulations everyone, and thank you so much for playing!
Posted: Tue Sep 15, 2020 1:41 pm
by BillG
I would like to thank the Academy...
Actually, I thank barrym95838 as well for the competitive spirit and out-of-the-box thinking which made the final result possible.
