Page 2 of 2
Re: Good starter kit for 6502
Posted: Fri Apr 19, 2019 12:01 am
by BillO
Thanks Mike, I get a lot of use out of it too.
As for the mHz thing - yeah, I do that unknowingly - I do teh and usually follow a first capital with ANother too. I was told by my daughter (a clinical psychologist) that this is a real 'thing' and could possibly be treated, but I can catch most of these 'flaws' in my typing and correct them and have been since my first keyboard some 42 years ago.
YEah, they go fast, not slow.
(See, that double capital? I'd usually correct that, but I'm leaving it there as an exhibit to my 'condition' - lol).
Posted: Fri Apr 19, 2019 3:42 am
by whartung
Condition or no, dyring a chat session, my typing is absolutaely awful. I sometimes clean it up, but it's infromal chat, so I don't always bothers.
(Above was verbatim...)
Posted: Fri Apr 19, 2019 10:25 am
by drogon
Thanks cbmeeks, that's very generous of you! I'll PM you.
I also have a couple of new projects that might be of interest. One you can have the PCB for the price of shipping. It's a real simple and tiny design with an expansion bus that can be used in a solderless breadboard and other configurations. It has performed well up to 19+ MHz, uses only 5 chips and fits in the palm of you hand. Here are some shots of it in various projects that are underway.
The other is a motherboard type design, but uses a 4-layer board so I'd be a bit hard pressed to give it away. It runs at 16 MHz and through a memory register can address 128K ROM.
PM me if you are interested in either.
Edit: First board corrected to 19+ MHz! Not 291MHz.
Edit-2: mHz corrected to MHz - I'm special....
It's lovely!
May I ask the edge connector type? I'm after some just like that for my next project and being swamped by the somewhat sub-optimal searches on mouser/rs/farnell, etc. It's one thing where the old printed catalogues really were a boon to be able to quickly flick through the pictures, then get down to the details..
Thanks,
Posted: Fri Apr 19, 2019 1:59 pm
by BillO
It's lovely!
Thanks,
They are 805 series 3.96mm pitch 36 pin connectors with the PCB pins. I got these off eBay for about $1.20 a piece. If you don't deal with eBay you can just google "805 series edge connector" and find other sources.
Here's where I got mine:
https://www.ebay.ca/itm/1x-Card-edge-co ... 443a9a43bd
If you are looking for name brand stuff, the EDAC 305 series would fit the bill. They are expensive though :
https://www.digikey.com/product-detail/ ... -ND/107514
Posted: Fri Apr 19, 2019 2:13 pm
by drogon
It's lovely!
Thanks,
Hm. Ebay is fine for me, I just never thought about it. That's not quite what I'm after - didn't realise it was 4mm pitch as I was after 0.1"/2.54mm - however now knowing the ebay search, ebay was far-faster to search through where I very quickly found "345 Series" which is what I'm really after than Farnell which is a bit bonkers, but there you go! I think the online versions of classic paper catalogues still have a way to go...
Posted: Fri Apr 19, 2019 4:10 pm
by thedrip
Here are the 0.100 spacing card edge connectors I used. 50 pin, but many other options out there
https://www.ebay.com/itm/5pc-Industrial ... xyuPtQ~70q
Posted: Sun May 12, 2019 4:47 am
by thedrip
Came across these on clearance at JameCo
80 pin card edge, through hole 0.100" .. Perfect for a very wide bus 6502 project
https://www.jameco.com/z/50-80C-20-Cinc ... 03039.html
