Ideas for a faster TTL CPU //6502 related
Re: Ideas for a faster TTL CPU //6502 related
Is the architecture of the TK20 known? Might be some interesting tactics in there. I suppose two of the nibble-wide '181s would be for the ALU, and two could be for index calculation (although as we know, the 6502 uses the ALU for that too.) I wouldn't really expect to use a '181 for incrementing. Maybe two for stack pointer increment and decrement? Or maybe for BCD adjustment??
AFAIR (I visited Schaetzle & Bsteht twice in 1987 and 1988) the bottleneck was RAM access. I think it was the address decoding and the bank switching which was typical for the Apple II family.
My most important question is the meaning of the softswitches: $C0F8/$C0F9, $C0FA/$C0FB, and $C044 .. $C04F. My board was "compiled" to sit in slot 7, means soft switches in $C0Fx. But the $C04x softswitches are a bit strange.
Regards
Ralf
RalfK wrote:
In 1987 I bought an accelerator board for my Apple IIe.
Somebody has that hardware.
Somebody really has that hardware !
Ralf, _thanks_ for posting the pictures, haven't expected to see them in my lifetime.
That's a high density PCB layout, and to me the PCBs look multilayer.
Looks like the registers were implemented by using 74ACT374 chips.
6* 74F181 4 Bit ALU. Maybe arranged as an 8 Bit ALU for data calculations and a 16 Bit ALU for address calculations ?
17 PALs.
4* Cypress CY7C291, 35ns 2k*8 PROM.
1* MMI 83S881, a (30ns?) 1k*8 PROM.
This implicates that the designers might have known more tricks than we know now when it comes to decoding the 6502 instruction set.
Aha: the advertisement says:
"3 million instructions per second". Wikipedia says 6502 has 0.43 MIPs per MHz.
"100ns cycle time", this would be 10MHz. 3 MIPs, 0.43MIPs per MHz, gives ca. 6.98 MHz. Hmm...
"80kB of 55ns on board RAM", but in the picture we see 9* M5M5165P-70L (9* 8k*8 = 72kB, 70ns).
Maybe there probably were different revisions\versions of the PCBs, so the hardware in the pictures just doesn't fit the advertisement, that's normal.
"Fully 6502 compatible", so it seems to have decimal mode, but we can't tell for sure if it supports the UFOs (instructions UnForseen by the designers).
"Optional extention for the 65C02 instruction set", so it only does the NMOS6502 instruction set, and running the 65C02 instruction set might require some additional hardware.
//Drass, any plans for building a chess computer ?
Oh, with 72k of RAM, I wonder if the machine has special handling for zero page, and/or page one, to offer a 16-bit wide path for pointers and stacked addresses? And with a 16-bit ALU for address calculation, as you suggest, no need for extra cycles on page crossing.
Maybe it makes a copy of the external ROM which is located in the host computer at power_on, this would explain the 72kB RAM.
From the PCB layout, we have 4* 74181 plus only a few registers on one PCB, and 2* 74181 plus some more registers on the other PCB.
But saying anything more about it would be highly speculative until somebody has reverse_engineered the PCBs into schematics
and until we have a read_out of the GALs and PROMs...
Now for tossing in something different:
Somewhere up in the thread, we had a few words about how difficult the 6502 instruction decoding is,
and this had brought me to the idea of playing the "what if" game:
6502 has a 16 Bit address bus and an 8 Bit data bus, and that's what adds a lot to the complexity of the 6502.
What, if the address bus _and_ the data bus for a "6502 styled CPU" would be both 16 Bit ?
Had tinkered for a week with this idea, and here the results:
PC is a 16 Bit counter, all the other registers are just registers.
The blue shaded registers are not visible to the end user.
The blue bus line is the internal data bus of the CPU.
Now for the state machine diagram:
No more zero page addressing, but all the other addressing modes seem to be there
(just had to add stack relative data and pointers, you sure can imagine how to implement
stack relative pointer with Y register as an offset).
For Bxx false, the ALU does nothing in step 5 while the next instruction word is fetched,
for BXX true the 16 Bit immediate value fetched in step 0 is added to PC in step 5.
Compare this to a rapid transit map:
In step 5, the train is at the station, and "something" happens to the chargo (data).
Adding PEA, PEI and PER to the state machine diagram is left as a homework assignment to the experienced reader.
Point is: we now have a 16 Bit instruction word,
and if one would be using mostly the lower part of the instruction word for controlling the sequencer (telling it which steps to skip),
while using most of the upper part of the instruction word for controlling ALU, registers and flags in step 5,
the layout of the opcode map somehow would resemble a bit the layout of the opcode map of the 6502.
For a 65C02 (and for our TTL CPU), a state machine flow diagram would be at least 4 times as big,
and a lot more complicated because a 16 Bit address has to be calculated with an 8 Bit ALU,
one needs to test for edge cases like page crossings etc.
When trying to implement an instruction decoder\sequencer for the 65C02 functionality plus some extras
by using 74138 decoders, 74151 multiplexers and logic chips, I think this would take more than 150 chips in total,
limiting the speed of a design which has a 2 level pipeline to maybe less than 10 MHz.
Downside of the state machine flow diagram is, that all of the instructions take at least two memory words and two machine cycles.
If one would add a little bit logic which detects single word instructions in step 0, then prevents that PC+ is written into PC at the end of cycle 0 if this is the case
(like in the NMOS 6502 and in our TTL CPU), single word instructions would work, but they still take two machine cycles.
Questions to Drass:
First:
We currently seem to generate the control signals for step 0 by hardware.
If _all_ of the microcode sequences would contain that [PC+] read for step 0, is there a chance for simplifying this circuitry ?
Second:
We now do ALU operation and flag evaluation in the EXECUTE machine cycle.
In which cycle the status register P is pushed on stack when the CPU responds to an interrupt ?
In theory, it might be possible to do just the ALU operation in the EXECUTE machine cycle, while latching the ALU outputs into a temporary register
for doing the flag evaluation and the status register update in the machine cycle that follows EXECUTE.
But I think this would complicate implementing cycle exact BXX false.
Questions to Drass:
First:
Second:
ttlworks wrote:
<musings>
Good luck people, but don't forget to KISS !
The code from the (slow) motherboard ROMs is copied to the fast RAM onto the DC65. This code for copying is in the pre-boot ROM (the 2716 seen on the pics). The same does i.e. the Transwarp accelerator from Applied Engineering (real 65C02 or 65802 @3,6MHz). I disassembled this code too. But I knew this before because the ROM code (i.e. Basic interpreter) runs also at full speed. After the copy loop the fast pseudo ROM seems to be disabled for writing.
The other questions:
Mr Schaetzle and Mr. Bsteh seem to live at their former town near Stuttgart in the southwest of Germany, 70km from me. I'm planning to contact them when I start to reassemble my Apple IIe. I found their address, and it seems that they are busy with electronics development.
The ad and the versions of that accelerator board for use in an Apple II:
- 10,0MHz, optional 12,5MHz, 100nsec cycle time means 10MHz, 12,5MHz -> 80nsec. They told me, that my board has "selected" chips. Means: these are 70nsec types but they are faster.
- Apple II: 80kB are 64kB plus 12kB for the pseudo ROM, but they use 8kB RAM chips
- Apple IIe: 144kB are 128kB plus 16kB for the pseudo ROM
- "Einfache Bedienung durch Menu-Steuerung" means simple menu for configuration or somethinng like this. But you need no config. This does not exist.
- Instruction set NMOS or CMOS: yes, I had the choice
I mostly ran the UCSD p-System with my own BIOS and interpreter which were highly optimized for CMOS instructions. The acceleration was min. 15* in comparison to the normal 1MHz Apple IIe just for code. I mentioned the speed of the RAM disks in 1987: 500 or 333kB/sec. A standard Apple II or IIe equipped with two or three floppy drives lasts 8.5hours to run the assembler for a new BIOS and p-code interpreter. Using the RAM disks and the DC65 board the same ran in 2.5 minutes
Plans for the future: a high speed serial card based on technology of the 1980s. The main goal is to replace floppies. I also need a server for the file system via serial line. No technical problem
The decimal mode with the DC65: the UCSD p-System does not use this mode, so I never tested it. But I'm planning to do that since I learnt some tricky pieces of code in the last years.
Regards
Ralf
I'm not sure if the hardware is ok after years in the storage. I'm preparing this Apple IIe carefully.
Would you like to get the pics direct from the scanner (10MB per pic)? Or would you like to get the code (disassembled or binary)?
Regards
Ralf
1) If the opcode is a single byte-opcode, PC + 1 is inhibited
2) If the opcode is a single-cycle NOP, the currently executing FetchOperand micro-instruction is changed on the fly to a FetchOpcode, and a FetchOperand is scheduled for the following cycle.
3) If the opcode is a branch, it evaluates the branch condition. If false, it triggers a FetchOpcode to execute in the next cycle, and schedules a FetchOperand to execute in the cycle after that. This is the “Branch Exit”, which is invoked when a branch is not taken.
FetchOperand is an all-zeroes micro-instruction, and FetchOpcode has only two control bits high, so both microinstructions are trivial to synthesize on the fly. One flip-flop is used to trigger a FetchOpcode in the next cycle, and another to schedule FetchOperand thereafter. So, one 74AC74 does the trick. The real gate count is all about decoding the opcode. This is one reason I suggested using a RAM to decode the opcode in the new pipeline. Another alternative is using something like a PAL, 16V8 would do.
This is the critical point. The branch test occurs during the FetchOperand cycle of a branch instruction, but it happens in the second half of the cycle. The flags would also be evaluated during that cycle, but in the first half. They can be ready in time for the branch test. I’ll post up the timing analysis on this when I get a chance. It’s very tight, but I believe it can be done.
Drass wrote:
There’s a bit of logic which kicks in during the FetchOperand cycle (cycle after FetchOpcode).
Additional hardware forces a "read from PC+" into the control signals during step 0, overriding the microcode.
And I just can't remember why we had added that hardware...
I think that there is an alternative for writing the flags at the end of that cycle, but it would add some chips to the design:
Drass wrote:
The MT15 carry chain looks great, and it’s much faster for 16 bits. Does it help with an 8-bit ALU?
Hmm... with 8ns 512kB RAMs, one sure could build a fast 8 Bit adder, but initializing that RAM after power up would require some additional circuitry.
My first TTL CPU had two EPROMs working as 4 Bit ALUs...
I assume that the two PCBs were sold without any schematics...
RalfK wrote:
That's nearly right. The Apple II and II+ have 12kB of ROM from $D000 to $FFFF.
RalfK wrote:
Mr Schaetzle and Mr. Bsteh... [snip] it seems that they are busy with electronics development.
ttlworks wrote:
For the microcode sequences of all 6502 instructions, microcode ROM places a "read from [PC+]" into the control pipeline during an instruction fetch for the next cycle (which would be step 0).
Btw, the new microcode is coming along. Needs more work, but I’m beginning to see how it’s going to play out. So far, so good.
Cheers.
ttlworks wrote:
Sorry that: I grew up with Commodores, but I'm not familiar with Apples.
I just mentioned these addresses for the readers like you and for their understanding this TTL cpu within the world of Apples.
RalfK wrote:
What UART chip you are going to use ?
In 1988 I soldered this during a rainy weekend (or so
The base was an EPROM card AP64e with a 6821. Several pins are similiar to the 6850. That card was good for 38400 and 57600Baud depending on the oscillator.
Regards
Ralf
