Re: Advice needed on SBC
Posted: Thu Jul 26, 2018 11:07 pm
GaBuZoMeu wrote:
Hi Floopy,
I don't want to sound sarcastic but me thinks your computer is very hard to use: you have no input nor output provided
So far it is just capable of drawing current
(OK, there is something, but I believe that is not your intention
Next your reset circuitry won't work (IMHO). As I see it, C6 pulls /RESET high briefly after power on and is then charged through R2 causing /RESET to see 0V. IOW you need to switch R2 and C6 to have a brief "0" at /RESET and then a "1" during runtime. I would suggest that you add a diode (1N4148 o.e.) parallel to R2 (cathode at +5V). The diode would allow C6 to discharge quickly into Vcc when you turn Vcc off. Otherwise all charge went through /RESET and internal protection diodes into Vcc.
If you use a 74HC139 (instead of your 138) your map would consist of four 16K blocks. Using 8K RAM/EEPROM they would simply appear twice in their 16K block. Using 32K devices you could use just one half (you need to strap the A14 pin of that devices to either GND or Vcc). You had then two 16K regions still available, one for onboard I/O, one for your expansion port. The other half of the 139 can be used to generate a qualified /WR (qualified by PHI2) for your RAM.
Good Luck!
Good Luck!
I was just trying to save components. It looked so simple I thought I would do it that way and it worked in the "test" run. I just had a 6502 with a NOP hard wired and it seemed to work. I've seen a 555 being used also.
Floopy wrote:
The memory is sectioned into 8 banks each 8192Bytes. I'm using a De-MUX (74138) to do the selecting. It's using the upper 3 bits of addressing.
http://www.ti.com/lit/ds/symlink/sn74ahct138.pdf
I do have some 139 and Alliance's AS7C256B-15PIN 32k × 8 SRAM. I had picked two options when it came to building. Either make 8Banks or have 2 with one being broken into two 16K.
For now I just want to run this a 1Mhz. Speed performance is not currently in mind. It's just an experimental SBC, meaning it's for learning how to use the 65C02 to control other devices such as a 65C22 or an LCD 16*4.
On yet another note, you should look more closely at the expansion connector... you're not bringing any of the signals used for Reset, IRQ or NMI. So if you plan on using some typical I/O devices, you'll likely need these to get them working properly. I would also suggest using something like a DS-1815 Reset chip instead of the RC setup and add a momentary switch as well so you can easily reset the CPU and any other I/O devices.
Taking the MPU's buses and signals off-board is not recommended. Garth explains why right here.
I should have mentioned that programming is not my strong point either.
-Thank you!
