Page 2 of 2
Re: Placeholders in assembly: How is it done?
Posted: Wed Aug 02, 2017 3:33 pm
by N2TheRed
whartung wrote:
The only real problem with pushing the elements on the stack is that it's not really a viable option on the 6502, not on the system stack at least, and especially not string values. You can push them on A stack (Forth uses the top of Zero page and indexes with X), but that's using X as your stack pointer, vs the systems. You also still have the problem with stack scarcity for something large like a string.
You could still use the stack if you just push addresses (address of the pattern string, address of the list of arguments (which can be 2 byte integers, or pointers), and the address of the destination buffer).
I see that being a problem when I try this on the 6502 as I'm having to juggle registers on x86.
What I've done on my x86 project is push the address of the pattern string and all string arguments onto the stack. Value arguments are just passed as such.
Posted: Wed Aug 02, 2017 5:35 pm
by N2TheRed
I find it hard to believe that I was able to get part of it to work.
Posted: Wed Aug 02, 2017 6:08 pm
I think the 6502 stacks treatise will be very helpful, especially the following chapters (although it's good to read it all, in order):
Posted: Wed Aug 02, 2017 6:23 pm
by N2TheRed
I have that saved to my favorites!
