Regarding the remarks of "not everything back in the day wasn't so good".
So, how true is that really? My first computer was the TI 99-4/a. Which had 16K of RAM. My second computer was the C64. I did so much programming on those machines! One thing it taught me was to be sparse with memory. Be efficient.
Nowadays, I see Java developers (and JavaScript) release *GIGANTIC* modules simply because "we all have broadband and 16GB of RAM". It's pathetic.
How was memory decoded in the 6052's heyday
Re: How was memory decoded in the 6052's heyday
I love the 6502 but I don't think I'd give up being able to write a piece of code in Ruby to iron out the bugs first before porting it to 6502 assembly.
- GARTHWILSON
- Forum Moderator
I have benefited a ton from being able to process pictures on the computer and incorporate them in emails, watch YouTube videos on computer history, aircraft, science, health, etc.; but as long as I can still see more optimization to be had on the 8-bitters in both hardware and software, I'm committed to the little guys, and I'll leave the 32- and 64-bit stuff for someone else and ask them to make more efficient use of the resources and not expect us all to have this year's latest computer like their bosses give them since it's their living and they can't be wasting time. They forget that.
I remember many years ago (late 1980's?) when a new technology was introduced that improved memory prices and speed a lot in one step, and immediately Microsoft was saying, "This is great because now we don't have to be as careful and we can get new software out faster," and what happened is that the user never got the benefit. Boot-up times made no net improvement, the "disc full" messages came up just as often, and there were just as many bugs.
Today's technology has brought about a lot of conveniences, but I have to say it has not improved the "happiness factor" of life.
- BigDumbDinosaur
They used more cascaded logic, further cutting into the access time, and further holding the clock speed down in a day when memory was slow already. One IC I wish were available in the faster families (like 74AC__ and 74VHC__) is the '154. It's like a '138 but has four address (in addition to G1\ and G2\) inputs, and 16 outputs.
- GARTHWILSON
- Forum Moderator
I have not looked at the current speeds of GALs, but last I did look, they were still pretty slow, like 10-15ns. Are there faster 22V10's now that don't require an expensive programmer? (I'm party thinking about the brand of programmable logic that most programmers won't program correctly. Was that Atmel?) 74LVC1G__ gates are in the 3-5ns (max) times for cascaded gate pairs @ 5V. The '139 has 3.6ns max PD @ 5V. They can't lose their programming either like EPROM which is only guaranteed to hold it for ten years. They're pretty attractive.
http://www.ti.com/paramsearch/docs/para ... 8nom=0.8;5
AldoBrasil
Dan Moos wrote:
OK, I've got a single dip with 32k of RAM on it. But that wasn't available back on the early eighties, and the RAM was spread over many chips.
Did those chips work just like the modern ones, but just have less address lines? So instead of the simple decode we do to select the entirety of RAM on one chip, did they have a pile more glue logic to decode that same 32k spread over many chips?
Just curious. It would explain why old 8 bit computer's boards were so heavily populated.
The ones I have in abundance are between 5 and 10ns. Lattice is the name on all mine, and the ones most readily available on eBay. This compares well with the typical 74LS138 at ~20ns and its in in the range of ACT logic.
Fast enough for most of my purposes since I would typically need additional logic to the '138 (whatever family) to get what I need. The GAL usually does it all. Single chip glue.
Programmers are embarrassingly cheap. Well under $100 US. I use a "Genius G540" that cost me less than $45 delivered to my door. I bought it 6 years ago and it's worked flawlessly since. It programs a huge array of devices including EPROMs, EEROMs, GALs, CPLDs, Microcontrollers, ... and more, much more.
I know that 10ns, or even 5ns is considerable if your working on a 15MmHz system, but consider that the GAL is configurable to suite specific needs and can usually be employed without too much other logic. It usually works fine with room to spare.
The biggest factors for me are their programability, their availability and their low price. Typically less than $2 a piece .. if you are diligent about looking for deals.
One more thing. They are reusable. You can muck around with some idea, and once tired of it, use the GAL(s) for something entirely different. Overall, not a bad tool to have in the box.
