R6501 Disassembler?
Re: R6501 Disassembler?
Ah OK, very well. Then perhaps you can post the last 6 bytes using a hex viewer/editor ?
Arne
Arne
- GARTHWILSON
- Forum Moderator
martin8or wrote:
If I go to the last 6 bytes at 3ffa..3fff
I see
7f d0 bd d7 4a d0
If I use the R6501 settings in the disassembler I get
If I load using address C000 a load of things happen of their own volition. C000 looks like hex but D000 has this (a small sample)
I see
7f d0 bd d7 4a d0
3fba: L3fba brk
3fbb: 00 00 00 00 00
3fc0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3fd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3fe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3ff0: 00 00 00 00 00 00 00 00 00 00
3ffa: L3ffa bbr7 $d0,L3fba
3ffd: smb5 $4a
3fff: bne L0000
d000: Sd000 lda #$00
d002: sta $14
d004: lda #$04
d006: sta $14
d008: lda #$10
d00a: sta $12
<snip>
(I added the [code] and [/code] tags to get your white space back.)
The reset vector is D7BD. What do you get, starting at that address? (BTW, I suggest capitalizing A-F in hex numerals to make them easier to read, mixing with 0-9 which are never lower-case. Also, a lower-case "f" appears so narrow on my monitor it looks like a 1, so your first vector looks like D071 instead of D07F.) There are some strange things in the code above, like two LDA's in a row, and LDA #$FF twice without altering A in between.
In looking at my Rockwell data book, I was surprised to find that in this non-CMOS part, they added the SMB, RMB, BBS, and BBR instructions without the other CMOS instructions. I never knew they did that; so I was wondering why they had RMB2 but used LDA #0, STA instead of STZ. Now I know.
White Flame
martin8or wrote:
I don't know what the load address is so I just used 0000.
I think my binary might be able to work with 2 different processors. The first bytes are 02 85.
02 as far as I can tell doesn't do anything for the R6501 but does with the 65c02. With settings for 65c02 I get this ( I used 'A' on selected bytes instead of 'Shift A' )
0000: L0000 nop #$85
0002: nop
0002: nop
I can't always make that assumption about the ROM location, though, because when disassembling cartridge ROMs the host machine can have its own ROM at the top of memory, and the cart ROM is elsewhere. But butting it up against the top of memory smells like a good default value for the load address prompt.
Opcode $02 is undefined in the base 6502 and R6501, but the 65c02 states that all undefined opcodes become a valid NOP. That's why the R6501 doesn't generate any assembly code starting from a $02 byte, and 65c02 does.
As far as LDA #$ff; STA somewhere; LDA #$ff; STA elsewhere, that's pretty common if you're using macros to set registers, or if you have comments between small blocks of code. It's just safer hand-coding to keep code snippets independent of each other, unless you're really cramped for space or speed. The posted code reads sensibly IMO.
Also, I'll note to add an option for uppercase or lowercase hex digits in the disassembler. I personally prefer lowercase.
EDIT: The load address prompt now defaults to placing the ROM at the top of memory.
EDIT2: Added labels for the R6501 zeropage I/O stuff. I'm slightly hesitant as this currently obscures the actual address in the current UI, and the names are a little funky because there's quite a contrast between read & write behavior of the counters. I made up names from the descriptions listed in the datasheet I found. Better label handling & tooltips revealing the underlying bytes will come later.
By the way, I'd love to get a copy of the ROM you're disassembling for my own testing, if you're willing to share.
Did the site have a little meltdown then? I couldn't post.
Hi Garth,
If you mean starting at D7BD as in loading the code from that location then It doesn't disassemble anything. I think because there's an $02 in the way?
Sorry about the formatting, it wasn't the disassembler's fault, honest.
If it's OK to post the rom here I will. Thanks for your help White Flame.
Martin
Hi Garth,
Martin
Hi Martin,
I´ve just used White Flames very fine disassembler with your .bin file and say it´s start @ $C000 :
Just the first few instructions after RESET looks very well. Init Flags, init Stack, then 3 subroutine calls probably do further inits.
At $D7CE it looks as if the program enters an infinite loop - perhaps it is ok, if all further action is event driven (due to timer interrupts or external irq´s) - BUT THIS INVESTIGATION IS UP TO YOU
Good Luck
Arne
p.s.: nice piece of SW this disassembler
d7b0: 97 d8 85 66 bd 98 d8 85 67 6c 66 00
d7bc: Ld7bc rts
d7bd: Reset_Handler lda #$04
d7bf: pha
d7c0: plp
d7c1: ldx #$fe
d7c3: txs
d7c4: jsr Sd000
d7c7: jsr Sd02b
d7ca: jsr Sd484
d7cd: cli
d7ce: Ld7ce jmp Ld7ce
d7d1: Ld7d1 stx $cd
d7d3: lda $53
d7d5: bne Ld7f1
d7d7: lda $65
d7d9: eor #$80
d7db: sta $65
d7dd: bmi Ld7ed
d7df: sty $cf
d7e1: jsr Sd336
d7e4: jsr Sd1f1
d7e7: ldy $cf
d7e9: ldx #$00
d7eb: beq Ld801
d7ed: Ld7ed ldx #$04
d7ef: bne Ld801
d7f1: Ld7f1 clc
Good Luck
Arne
White Flame
No, thank YOU guys for using it.
That's what makes it better.
I'd like to thank everyone for their help and interest.
The disassembler looks nice with the labels (Thanks White Flame).
It makes sense that it enters a loop. It's waiting for two things, either a command from the Atari software which makes the R6501 output SMPTE timcode, or a SMPTE timecode input which makes the R6501 output a Roland sync pulse and synchronise the midi sequencer software on the Atari to the incoming SMPTE stream.
The R6501 is constantly outputting a clock of around 15.75khz on one of its pins. (which is an old video horizontal scanning frequency, wonder if this is deliberate?)
This clock drives one of the PAL16R8 chips that the SMPTE comes into (the straight SMPTE signal also goes into the R6501), and inside the PAL16R8 there is some counting etc that takes the bi-phase signal and splits a clock signal away from the bits. If there's a stream of 1's an output pin on the PAL goes high and this along with the split off clock go to the second PAL16R8 were if the correct input conditions occur a count of 0 to 79 occurs and this is output to the R6501. 80 bits is how many bits there are in a packet of SMPTE data. (I think that's how it works anyway).
Thanks
Martin
Thanks
Martin
I tried to make a schematic and footprint symbol for the R6501 using kicad. If you use it you will have to check it's OK because I gave up trying to use that dreadful software. I'm going to try geda or orcad386.
- Attachments
- R6501 Symbols.zip
- (2.05 KiB) Downloaded 138 times
- GARTHWILSON
- Forum Moderator
- barrym95838
... For something as simple as a 40-pin DIP, it should only take a jiffy to make a new component—at least my 22-year-old Easy-PC Pro does which runs under DOS ...
Mike B.
- GARTHWILSON
- Forum Moderator
Yes, I forgot. So it should take 1.6 jiffies.
- GARTHWILSON
- Forum Moderator
There's a comparison of EDA software at https://en.wikipedia.org/wiki/Compariso ... A_software . Most of it is free. I'm sure others will be interested to hear what you experience with whatever else you try.
is exists instruction set for testing disassembler?
White Flame
The instruction set is just 6502, without 65c02 extensions, but with the bit operations that other 6502 variants have had (SMB, RMB, BBS, and BBR).
The link to the data sheet above doesn't work anymore, probably because the ID in there ended up being a session ID, not a document ID. Look at the 2nd section of this page to get a fresh link to the datasheet again.
If you want a binary to test out disassembly, martin8or's TL12.zip attachment up higher in this page is one. You can compare your output to using the disassembler in my signature link below, just make sure to set the CPU Model to R6501 first.
The best test of a disassembler is to disassemble code that you have the source code to and check that it matches.
