"With its flat face facing you, and pins pointed down, it's E-B-C."
I am afraid its slightly worse than that, Garth. (Do I dare confess?). For a fella who wants to learn electronics, I am not very good with transistors! HA! Quite a confession!
I know a fair amount about the history, and even quite a bit about the theory of transistors; but PRACTICAL info! REAL info about how to use them! Forget about it!
I am out of practice on the whole "NPN", "PNP" thing. Some of it is my fault (i.e. lazy; my excuse? Biologist!), but I also blame history and physics! History, since it involves "people", is complex and foolish; physics, since it exists quite separate from the human mind's conception and perception of it, is complex and hidden.
Cryptic comments, you say! YES. I will explain. Conventional current is stupid, and always confuses me. Maybe an engineer from the 6502-forum could set me straight? So, when does positive mean "excess of electrons"? On which schematics? Old? New? Never?
(Technically, I don't care if the electrons are "jealous" and the protons are "vengeful"; so long as they are ALWAYS jealous and vengeful, respectively, and never switch places. I mean, positive and negative are just words, and just as easily can be applied in the opposite fashion. I mean, who could truly complain? Transistors! That's who!)
So, my understanding is that, historically, engineers used + to mean that electrons would flow from that lead, through the circuit, to ground. Is this STILL true, of engineer schematics? I think scientists have ALWAYS used the convention that electrons are negative? Am I wrong there?
So ground is, essentially, neutral, or, rather, a good "electron sink". But, wait? Ground is also, a good source of electrons, is it not? (I almost need a meteorologist book to remember what lightning is? But, doesn't lightning have currents that flow up in order to meet the currents flowing down?)
My physics book says that Voltage = Electrical Potential Energy per unit charge. (i.e. delta-W/electron, I think?). Voltages, as measured with leads, is relative. But, perhaps the silicon, phosphorous, and boron atoms do not "believe" in relativity (relativity of voltage)? Perhaps, THEY "know" what ground state is!
So, I do have the pin diagram for the single transistor, but it recommends a negative voltage, leaving me scratching my head in embarrassed confusion? My "wall wart", 6V AC-to-DC converter (is it 300mA rating? I forget?) feeds into a 7805, with a couple of electrolytic capacitors in the circuit, giving my project board what I have, thus far, considered to be a stable source of +5 volts, and a decent GND rail. Has my reason failed me, so far?
OK, I have rambled WAY TOO long on this subject; this topic is not immediately relevant to my "6502 madness", but instead is for my fiber optic transmitter/receiver circuits. (Maybe later, I will post my circuit diagrams for that FO project, and you can set me straight on "the fundamentals"). Just know, I have a second circuit that uses a 2N2222 (NPN) instead of a 2907 (PNP), and perhaps I'll just revert to using that one (rather than feebly obsessing over electrons, protons, "the nature of existence" and "the sound of one hand clapping".).
(I guess I shouldn't mock philosophy, or science, since CMOS--its invention and its use--is predicated upon the proper understanding of the movement of electrons and holes. These ideas are essential to proper design and to the functioning of the hardware.).
Moving on to the topic of my "6502 madness", I will post, below this post, the PCB plan, so far. You have my permission to laugh, as I have broken every rule that I know I shouldn't break (very similar to my "9-image-sensor" project, a few years ago). My goals, as always, are (1) construct something that MIGHT work, (2) if it doesn't, try to get it to work and (3) if it still doesn't work, admire it as art, and finally (4) learn something.
(Hey, here is a silly question. How come CMOS chips have only one power and one ground pin? I mean, they don't generally have a + 5V and a -5 V and a GND? I guess, with all measurements of voltages being relative, the NPNs and the PNPs can "split the difference" and find a voltage that "looks" negative to the one type of trans., while "looking" positive to the other? Or is this, too, a foolish question?)
